Hulp gevraagd met DVD Brander
  • 207 views
Beste allemaal,
Graag jullie hulp en advies. Ik krijg geen films meer op DVD gebrandt. Bijgaand het foutrapport.
Alvast grote dank voor evt. hulp.
Grt,
Mediaman74
1C82-0000-19E5-MAAX-4000-8186-****
Windows XP 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.10.1.2
Internal Version: 7, 10, 1, 2
(Nero Express)
Recorder: <TSSTcorp CDDVDW SH-S203D>Version: SB01 - HA 1 TA 0 - 7.10.1.2
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <VB9427Z XBF530S >Version: 1.01 - HA 1 TA 2 - 7.10.1.2
=== Scsi-Device-Map ===
CdRomPeripheral : VB9427Z XBF530S 1.01 agr6j7dr Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CDDVDW SH-S203D D: CdRom0
TSSTcorp DVD-ROM SH-D163B E: CdRom1
VB9427Z XBF530S H: CdRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095484kB)
Free physical memory: 1133MB (1160768kB)
Memory in use : 44 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
23.12.2008
ISO-compilatie
22:20:35 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
22:20:35 #2 Text 0 File Isodoc.cpp, Line 6666
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
22:20:35 #3 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
22:20:35 #4 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
22:20:36 #5 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1847007 (410:26.57, 3607MB)
22:20:36 #6 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
22:20:36 #7 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: TSSTcorp CDDVDW SH-S203D, Media type: DVD+R
Disc Manufacturer ID: SONY, Media Type ID: D21, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
22:20:36 #8 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
22:20:36 #9 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1847008 (1847008) = #1847008/410:26.58
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1847008 blocks [D: TSSTcorp CDDVDW SH-S203D]
22:20:36 #10 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [D: TSSTcorp CDDVDW SH-S203D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3782672384, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1847008 | 0 | 0x00
1847008 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
22:20:36 #11 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
22:20:36 #12 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
22:20:36 #13 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
22:20:36 #14 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
22:20:36 #15 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
22:20:36 #16 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 16x (22.160 kB/sec)
22:20:38 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
22:20:38 #18 Text 0 File Cdrdrv.cpp, Line 9872
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: SONY....
Media type ID: D21
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 53 4F 4E 59 00 - 00 00 00 44 32 31 00 38 ...SONY....D21.8
23 54 37 14 00 28 6E 00 - 80 69 17 19 0C 0C 0A 0B #T7..(n..i......
01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................
22:20:38 #19 Text 0 File Cdrdrv.cpp, Line 9872
Media type ID: D21
22:20:38 #20 Text 0 File Cdrdrv.cpp, Line 9872
Media type ID: D21
22:20:38 #21 Text 0 File DVDR.cpp, Line 8376
Drive: TSSTcorp CDDVDW SH-S203D
Book Type request [TSST]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
22:20:38 #22 CDR -1207 File DVDR.cpp, Line 6481
Book Type automatically set to: DVD-ROM
22:20:38 #23 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
22:20:38 #24 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
22:26:52 #25 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 A0 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x190f0180: Len x10000
0xB9 A5 21 C1 8D B7 BC 31 E7 DF 85 1B 4C E1 90 0B
0xF4 BA 7D E7 9F 70 45 02 67 FF FB EF BE A8 21 95
0xEA ED 70 67 04 E1 89 54 3E AC 5B 18 6F AA 55 F5
22:26:52 #26 CDR -1135 File Writer.cpp, Line 303
Write error
22:26:53 #27 SPTI -1046 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x06
CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 06
22:26:53 #28 Phase 127 File dlgbrnst.cpp, Line 1762
Generating DVD high compatibility borders
22:26:53 #29 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 160
22:26:53 #30 CDR -1046 File WriterStatus.cpp, Line 162
Illegal disc
22:26:53 #31 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
22:26:53 #32 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 16x (22.160 kB/sec)
22:26:53 #33 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
22:27:03 #34 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
22:27:03 #35 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
  • Microkid
  • Laatst online: 22:37
Microkid
Smile
Welkom op GoT. GoT is een forum voor de gevorderde computeraar en het forum is derhalve geen helpdesk. Voordat je een topic post wordt er van je verwacht dat je eerst zelf het nodige vooronderzoek doet. Geef duidelijk aan wat het probleem is, wat je zelf al gedaan hebt en wat de resultaten waren.
Het zomaar plaatsen van een vraag met een gigantische hoeveelheid niets-zeggende informatie zoals jij nu doet wordt niet echt gewaardeerd. Ik raad je dus ook aan om de voorwaarden even door te nemen hoe je hier op GoT moet posten.
[ Voor 11% gewijzigd door Microkid op 23-12-2008 23:01 ]
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
En op het verhaal van Microkid heb ik eigenlijk weinig meer toe te voegen behalve een slotje.
