Een bios-update is beschikbaar voor mijn plank, waarin staat dat er een optie, of iig feature PCI-Fetch disabled is. Na een snelle zoektocht op het net over de invloed van PCI-Fetch kwam ik uit op de volgende site:
It has come to our attention that Nvidia has ended up in more product trouble, although this time it's with regard to Nvidia's chipset division and it's not related to a manufacturing issue, but rather a lawsuit from OPTi Inc.
As the story goes, Nvidia has infringed a patent regarding to PCI prefetch that OPTi holds and although OPTi no longer makes PC chips, they now license intellectual property. The problem in this case is that Nvidia didn't come out on agreeable terms with OPTi and has to remove the PCI prefetch feature from its chipsets.
The problem with this is twofold. Firstly, it means that just about every single Nvidia chipset from the nForce 500-series and onwards is affected and as such, PCI prefetch has to be removed from all retail boards and every single BIOS upgrade that contains the PCI prefetch code has to be removed from the Web. This also means that all Nvidia partners have to release BIOS updates for every single Nvidia motherboard from the nForce 500-series and onward.
For consumers, this means that they'll get very poor PCI performance, so if you're using any PCI cards in your Nvidia-based motherboard, don't upgrade to the latest BIOS, as it will reduce the performance of the PCI bus. This isn't going to be popular with a lot of users out that that have already upgraded their BIOS, as this "feature" has already been implemented by some motherboard manufacturers going back a couple of months.
Bah. Dat heb ik weer. Ondanks dat ik 2 sloten heb waarvan 1 voor een S-ata controller, is het verstandig te upgraden, en zowiezo als er straks ondersteuning is voor mijn plank voor de nieuwe Phenom X2, moet ik dan inleveren? Als geen enkele bios met PCI-Fetch meer mag, dan kan ik er lik op stuk nemen dat mijn controllertje het ineens een stuk minder doet.
Misschien dat je het gaat merken als je een PCI grafische kaart gebruikt, of opnames maakt met een PCI geluidskaart?
Wat draait er verder nog via de PCI-bus?
(ik heb zelf gelukkig een intel chipset)
Nou zo'n beetje alles :P
Geluid, NIC, S-ata controller, PCI-express, onboard dus kortom als ik het zo mag horen mis ik een stukje prestatie straks.
Het enige wat nu werkzaam op de PCI-bus is is een S-ata controller.
[ Voor 25% gewijzigd door Verwijderd op 19-12-2008 01:53 ]
Weet je zeker dat dit ook van toepassing is op PCI-E?
Onboard SATA-controllers gaan denk ik niet via PCI (133MB/s?)
Die zitten toch echt op de PCI-bus hoor.
Net zoals Sound, Nic, en andere perhepials. Hoe wil je anders communiceren met de rest van je hardware?
  • Admiral Freebee
In appraatbeheer lijkt het altijd inderdaad alsof alles via PCI gaat maar dat lijkt me gewoon een driverconstructie. Mijn onboard NIC hangt toch echt aan de PCI-E bus en ook de extra onboard S-ATA controller hangt aan die bus. Het geluid weet ik niet maar ik dacht dat die een eigen verbinding had naar de southbridge.
In ieder geval gaat je PCI-E bus niet fysiek over je PCI-bus. Hoe wil je anders die hoge bandbreedte halen?
  • kalizec
  • Laatst online: 25-08 18:47
PCI-E is voor software identiek aan PCI. Echter is het wel stukken sneller. Voor drivers maakt het niet uit. Van het lijstje van de TS gaan de NIC, SATA en PCI-E insteekkaarten zeker over PCI-E en niet over PCI. Verder is het aannemelijk dat alles dat geintegreerd zit in het chipset over PCI-E gaat. Alleen losse insteekkaarten niet.
Core i5-3570K/ASRock Z75 Pro3/Gigabyte Radeon HD7850/Corsair XMS3 2x4GB/OCZ Vertex2 64GB/3x640GB WD Black/24" B2403WS Iiyama x2/Nec 7200S
  • jan99999
  • Laatst online: 07-10 17:04
Alleen een bios update doen indien je het nodig hebt, omdat er iets niet werkt bijvoorbeeld.
Indien het fout gaat is je mainbord defect.
Voor mij maak het niet zo veel uit.
De laatste nvidia plank was de nvidia 650 chip
Vind nvidia toch al slecht prestatie leveren.
Gelukkige kunnen de nieuwe borden ook sli en crossfire draaien met een intel cpu.
Alleen voor amd moederborden is het jammer.
verder ik ben benieuwt of de pci-e inderdaad niet slecht gaat performens gaat geven omdat het een update is voor pci .
  • The Third Man
  • Laatst online: 21:05
The Third Man
The Third Jellyfish
Verwijderd schreef op vrijdag 19 december 2008 @ 02:05:
Tegenwoordig zit steeds meer direct in de southbridge van de chipset geïntegreerd en dus niet meer op de 'open' PCI-bus die gedeelde wordt met de insteekkaarten. Wat dat betreft zijn de gevolgen waarschijnlijk kleiner dan bij PC's out de Pentium 1/2/3 tijd.
Blijft gissen, maar de enige reden waarom ik een Bios-update zou willen doen is omwille de Phenom X2. Sneller als de X2 met gelijke clocks maar helaas niet sneller verkrijgbaar als een 6400+ X2 :+
Dus het is een 5000+ X2 2.6GHz geworden die ik 1 deze dagen 'safe' op 3GHz wil hebben draaien :P
