[Ervaringen] Fujitsu M1010
Afbeeldingslocatie: http://www.fujitsu.com/sg/services/computing/pc/notebooks/mseries/m1010/gallery.html
Never have to leave your life behind when you’re out and about living it. The Fujitsu M1010 is all you need to stay connected to your Internet world. With an 8.9-inch wide screen, the M1010 features the Intel® Atom™ processor N270 and is loaded with Genuine Windows® XP Home Edition for a full Internet-centric experience. Users can surf the net, listen to music, watch videos, play games and even perform basic word processing - perfect for school, work or play! To top it all, you can flash your ever-changing colourful personality with optional clip-on Colour Lids.
Specifications:
Platform - Intel® Atom™ processor Technology
- Intel® Atom™ processor N270 (1.6GHz, 512 L2 Cache, 533 MHz)
- Intel® 945 GSE Chipset
- Intel® ICH7M Controller Hub
Operating System Genuine Windows® XP Home Edition
Display 8.9-inch WSVGA back-light LED6, 1024 x 600 pixels
Memory 1GB DDR2 533MHz
Hard Disk 60GB
Bluetooth® v2.1
Battery Up to 4hrs1 (4-cell Li-Ion 14.4V 2200mAh)
Weight Approx. 1kg
Detailed Specifications
Hard Disk Drive 1.8-inch PATA (4200rpm), Two Partitions-50/502
Graphics Intel® Graphics Media Accelerator 950
Audio RealTek ALC269 HD audio codec with two built-in speaker and two digital microphones
Communication Bluetooth® v2.1, Fast Ethernet 10/100 Mbps, Wireless LAN 802.11b/g, 1.3 Mega Pixel camera
User Interface Keyboard: 85-key
Touch Pad with left and right mouse buttons
3 LEDs Indicator: Power-LED, Battery Status-LED, WLAN or Bluetooth®;
Card Slots SD/ SDHC/ MMC/ MS/ MS PRO, 34mm ExpressCardTM Slot
Connector Interface USB 2.0x2, VGA (external display), RJ45 (LAN), Audio-In, Audio-Out, Power Adapter DC-In
Quick Launch Panel Fn Key button, Web Camera ON/OFF with LED light
Security3 User and Supervisor BIOS password
Dimensions Approx. 232.4mm (W) x 175mm (D) x 29/35.8mm (H)
Bundled Accessories
AC Adapter Input AC 110~240V, Output DC 20V 40W
Bundled Softwares Acronis Recovery, ArcSoft Camera Capture, Adobe Acrobat Reader, Sun Microsystems
Java Runtime, ThinkFree Mobile4
Other Softwares 1 year Full Licensed Norman Virus Control
Carrying Case5 Portable Slip Case
