[Obj-C/Cocoa] NSKeyedArchiver of NSCoder
  • punishedbrains
  • Laatst online: 23-08 15:59
Beste mensen,
Excuses voor hetgeen hiervoor stond, nalezen van een Apple document bracht mij stukken verder. Nu heb ik echter NSCoding geimplementeerd in een NSObject en probeer ik een object te saven mbv NSKeyedArchiver. Hier gaat echter iets mis met het daadwerkelijke schrijven. Zien jullie de fout toevallig? <NSCoding> staat aangegeven in de header-file.
De implementatie:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
@implementation AppController
- (void)awakeFromNib
    speechSynthesizer  = [[NSSpeechSynthesizer alloc] init];
    /* Make the Window object the responder to NSSpeechSynthesizer delegate methods */
    [speechSynthesizer setDelegate:self];
    [speechSynthesizer setVoice:NULL];
    SpeechList *temp = [[SpeechList alloc] init];
    Voices = temp.speechList;
    [temp release];
    temp = nil;
    [tableView reloadData];
#pragma mark Dealloc
-(void)dealloc {
    [Voices release];
    Voices = nil;
    [super dealloc];
#pragma mark Loading/Savings
- (IBAction)saveMyTable:(id)sender {
    NSMutableData *data;
    data = [NSMutableData data];
    archiver = [[NSKeyedArchiver alloc] initForWritingWithMutableData:data];
    panel = [NSSavePanel savePanel];
    [panel setDirectory:@"~/Library/"];
    int panelResult = [panel runModal];
    BOOL result;
    if (panelResult == NSOKButton) {
        [archiver encodeObject:Voices forKey:@"Voices"];
        [archiver finishEncoding];
        result = [data writeToFile:@"~/Users/Vinz/Desktop" atomically:YES];
        if (result == NO)
            NSBeep();
            [archiver release];
            return;
        [archiver release];
#pragma mark Action methods
- (IBAction)startSpeaking:(id)sender {
    NSString *speechText = [textField stringValue];
    [speechSynthesizer startSpeakingString:speechText];
#pragma mark Datasource methods
- (int)numberOfRowsInTableView:(NSTableView *)tv
    return [Voices count];
- (id)tableView:(NSTableView *)tv
                objectValueForTableColumn:(NSTableColumn *)tableColumn
                row:(int)row
    NSString *voice = [Voices objectAtIndex:row];
    NSDictionary *dict = [NSSpeechSynthesizer attributesForVoice:voice];
    return [dict objectForKey:NSVoiceName];
#pragma mark Delegate methods
- (void)tableViewSelectionDidChange:(NSNotification *)notification
    int row = [tableView selectedRow];
    if (row == -1) {
        return;
    NSString *selectedVoice = [Voices objectAtIndex:row];
    [speechSynthesizer setVoice:selectedVoice];
#pragma mark Coder methods
- (void)encodeWithCoder:(NSCoder *)coder
    [coder encodeObject:Voices forKey:@"Voices"];
- (id)initWithCoder:(NSCoder *)coder
    [super init];
    Voices = [[coder decodeObjectForKey:@"Voices"] retain];
    return self;
@end
[ Voor 83% gewijzigd door punishedbrains op 25-11-2008 16:22 ]
  • Depress
  • Laatst online: 22-10 22:13
Waar ben je gekomen met debuggen?
Bestaat je bestand waar je het naar wil wegschrijven? Schrijf je niet weg naar een plek waar het niet mag van OSX? Wordt het ook wel daadwerkelijk aangeroepen?
  • punishedbrains
Depress schreef op dinsdag 25 november 2008 @ 22:10:
Het bestand bestaat nog niet, dat zou op deze manier (naar ik aanneem) aangemaakt moeten worden en ik probeer op o.a. de desktop te schrijven wat geen probleem is... mocht dat overigens wel een probleem zijn dan zou OSX mij automatisch om toestemming moeten vragen. Dat lijkt het probleem dus niet te zijn, ik vermoed zelf dat de fout in de implementatie van NSCoder zit, ik zie alleen niet waar. Het geheel compileert prima, geen fouten, ook niet tijdens run-time, het schrijf-commando gaat alleen de mist in.
  • punishedbrains
Iemand anders die zijn licht over de code kan schijnen?
