Vmware player installeen op ubuntu 8.10
  • happyguppy
  • Laatst online: 29-09 13:52
Besten,
Ik probeer de hele middag al vmware player te installeren op 8.10, maar krijg steeds de volgende error bij het configureren van het pakket:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
Trying to find a suitable vmmon module for your running kernel.
None of the pre-built vmmon modules for VMware Player is suitable for your
running kernel.  Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes]
Using compiler "/usr/bin/gcc". Use environment variable CC to override.
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.27-7-generic/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Entering directory `/tmp/vmware-config6/vmmon-only'
make -C /lib/modules/2.6.27-7-generic/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.27-7-generic'
  CC [M]  /tmp/vmware-config6/vmmon-only/linux/driver.o
In file included from /tmp/vmware-config6/vmmon-only/./include/vmware.h:25,
                 from /tmp/vmware-config6/vmmon-only/linux/driver.c:83:
/tmp/vmware-config6/vmmon-only/./include/vm_basic_types.h:170: error: conflicting types for ‘uintptr_t’
include/linux/types.h:40: error: previous declaration of ‘uintptr_t’ was here
In file included from /tmp/vmware-config6/vmmon-only/./include/x86.h:23,
                 from /tmp/vmware-config6/vmmon-only/linux/driver.h:15,
                 from /tmp/vmware-config6/vmmon-only/linux/driver.c:84:
/tmp/vmware-config6/vmmon-only/./include/x86cpuid.h:383:1: warning: "BIT_MASK" redefined
In file included from include/linux/kernel.h:15,
                 from /tmp/vmware-config6/vmmon-only/linux/driver.c:11:
include/linux/bitops.h:7:1: warning: this is the location of the previous definition
In file included from /tmp/vmware-config6/vmmon-only/./include/x86.h:24,
/tmp/vmware-config6/vmmon-only/./include/x86paging.h:61:1: warning: "PTE_PFN_MASK" redefined
In file included from include/asm/paravirt.h:7,
                 from include/asm/irqflags.h:55,
                 from include/linux/irqflags.h:57,
                 from include/asm/system.h:11,
                 from include/asm/processor.h:17,
                 from include/linux/prefetch.h:14,
                 from include/linux/list.h:6,
                 from include/linux/module.h:9,
                 from /tmp/vmware-config6/vmmon-only/linux/driver.c:12:
include/asm/page.h:22:1: warning: this is the location of the previous definition
In file included from /tmp/vmware-config6/vmmon-only/./include/vmci_kernel_defs.h:26,
                 from /tmp/vmware-config6/vmmon-only/./common/vmciContext.h:19,
                 from /tmp/vmware-config6/vmmon-only/linux/driver.h:21,
/tmp/vmware-config6/vmmon-only/./include/compat_wait.h:37:5: warning: "VMW_HAVE_EPOLL" is not defined
/tmp/vmware-config6/vmmon-only/./include/compat_wait.h:43:5: warning: "VMW_HAVE_EPOLL" is not defined
/tmp/vmware-config6/vmmon-only/./include/compat_wait.h:60: error: conflicting types for ‘poll_initwait’
include/linux/poll.h:65: error: previous declaration of ‘poll_initwait’ was here
In file included from /tmp/vmware-config6/vmmon-only/linux/vmhost.h:13,
                 from /tmp/vmware-config6/vmmon-only/linux/driver.c:115:
/tmp/vmware-config6/vmmon-only/./include/compat_semaphore.h:5:27: error: asm/semaphore.h: No such file or directory
/tmp/vmware-config6/vmmon-only/linux/driver.c:197: error: unknown field ‘nopage’ specified in initializer
/tmp/vmware-config6/vmmon-only/linux/driver.c:198: warning: initialization from incompatible pointer type
/tmp/vmware-config6/vmmon-only/linux/driver.c: In function ‘LinuxDriver_Ioctl’:
/tmp/vmware-config6/vmmon-only/linux/driver.c:1802: error: too many arguments to function ‘smp_call_function’
make[2]: *** [/tmp/vmware-config6/vmmon-only/linux/driver.o] Error 1
make[1]: *** [_module_/tmp/vmware-config6/vmmon-only] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.27-7-generic'
make: *** [vmmon.ko] Error 2
make: Leaving directory `/tmp/vmware-config6/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
Iemand enig idee hoe ik dit kan oplossen? Ik loop de hele middag het internet al af te struinen maar ik kan geen werkende oplossing vinden.
  • gertvdijk
  • Laatst online: 00:19
Ik gok dat VMWare's virtualisatie nog niet klaar is voor 2.6.27. Is in Virtualbox ook nog maar pas aanwezig.
[ Voor 20% gewijzigd door gertvdijk op 27-10-2008 21:40 ]
Kia e-Niro 2021 64kWh DynamicPlusLine. 3x Victron MP-II op 15kWh US5000 3f thuisbatterij met 3x25A→3x40A PowerAssist, Victron EVCS, 3200Wp HoyMiles zp. my GitHub, my blog
  • happyguppy
gertvdijk schreef op maandag 27 oktober 2008 @ 21:39:
thanks! wel erg jammer, ik hoop dat ze er snel mee komen aangezien het ook niet meer al te lang duurt voordat 8.10 final is.
Als je de Vmware Image echt hard nodig hebt zijn er manieren om deze te converteren naar VirtualBox:
http://dossy.org/2008/05/...rom-virtualbox-to-vmware/
VirtualBox werkt wel (naar mijn weten) met de laatste fancy pancy kernel :)
  • robbert
  • Laatst online: 23:32
Vmware player 2.5.0 werkt hier anders prima onder Ubuntu Intrepid Ibex x86_64 met 2.6.27-7 kernel.
Het enige wat niet meer werkt is vmware-package, waardoor je dus geen mooie .deb pakketjes kunt maken.
[ Voor 20% gewijzigd door robbert op 28-10-2008 00:06 ]
  • gertvdijk
@TS: hoe installeer je VM Player (indien niet uit repo's: waar vandaan dan wel), welke versie is het?
  • Elijan9
  • Laatst online: 12-10 13:05
Jammer dat je niet aangeeft dat je zelf al hebt gezocht naar oplossingen. Maar misschien heb je wel gezocht, maar met de verkeerde termen. Zoals al genoemd, geeft de error aan dat de kernel modules van vmware nog niet voorbereid zijn op de 2.6.27 kernel.
Met een beetje zoeken vind je voor dit soort problemen meestal wel een oplossing, ik heb eenzelfde soort probleem gehad met de 2.6.26 kernel, maar vond na kort googelen destijds ook een oplossing.
Google komt bijvoorbeeld hiermee: https://bugs.launchpad.net/ubuntu/+bug/263837
War is when the young and stupid are tricked by the old and bitter into killing each other. - Niko Bellic
  • happyguppy
gertvdijk schreef op dinsdag 28 oktober 2008 @ 00:11:
Het is de nieuwste versie:
Mware Player 2.0.5
Version: 2.0.5 | 8/28/2008 | Build: 109488
Direct van de vmware site gedownload.
Elijan9 schreef op dinsdag 28 oktober 2008 @ 13:59:
Ik had dat wel aangegeven ;) :
MAARRRR de laatste link had ik niet gevonden :) en dit is inderdaad de oplossing, super bedankt!!
  • happyguppy
hmmm de installatie gaat nu goed, maar krijg in de player zelf nog een error:
Version mismatch with vmmon module: expecting 167.0, got 169.0.
You have an incorrect version of the `vmmon' kernel module.
Try reinstalling VMware Player.
Werk nu aan een oplossing:
http://ubuntuforums.org/showthread.php?t=916238
Ik laat weten of het werkt voor mij.
// update:
Het installeren van vmware server gaat prima, ik moest wel weer in de install de bestanden van het linkje eerder genoemd gebruiken.. Alles start prima alleen krijg ik nu het volgende:
vmxvmdb: Index name being generated from config file
POST(no connection): Version mismatch with vmmon module: expecting 138.0, got 169.0.
You have an incorrect version of the `vmmon' kernel module. Try reinstalling VMware Server.
Meer van hetzelfde dus :(
[ Voor 106% gewijzigd door happyguppy op 28-10-2008 21:48 ]
  • gertvdijk
Wacht nou maar gewoon tot er degelijke ondersteuning komt voor 2.6.27. :) Of bak even zelf een 2.6.x kernel, tijdelijk, tot de ondersteuning er is.
