Nog steeds niet branden...Logical Unit Communication CRC Err
Na een weekje te hebben geklooid met verschillende oplossingen kan ik dus nog steeds niet branden...
heb firmware geupdate, sp3 andere writer eruit gegooid(ide).
########################### System Information ###########################
Windows XP Professional 5.1 Service Pack 3 (Build 2600)
Processor info: Intel(R) Pentium(R) 4 CPU 3.00GHz x 2 (2992MHz)
Memory Available to Windows: 2.096.620 KB
############################ Program Information ###########################
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\_Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: Alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2008 Alcohol Soft Development Team
Version: 1.9.7 ( Build 6221 )
Date: 2008/02/22
Hash: ee833b4b446b7fa2e05541d4090f3c33
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Company Name: Alcohol Soft Co., Ltd.
Description: Alcohol virtual device control library
Original: alcoholx.dll
Product: Alcohol
Copyright: Copyright (C) 2000-2008
Version: 4.12.0 ( Build 0 )
Date: 2008/01/18
Hash: f1274ca402d9296cd31eacc34a88bbea
File Name: C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Copyright: Copyright(C) 2002-2006 Alcohol Soft Development Team
Version: 2.5.4 ( Build 222 )
Date: 2008/02/22
Hash: 4b22ef831539d9f5b6923d3d286141e7
########################### User Information ###########################
Licensed to: UN-REGISTERED
Registered User ID: UN-REGISTERED
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 256
Examine the accuracy of data read from physical device: Yes
Enable Enhanced Weak Sector Scanner during dumping: No
Overburn disc(s): No
Turn off "Auto-Select best write speed" function if possible: No
Fill memory buffer before recording discs: Yes
Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No
Ignore Media Type: No
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: Dutch
############################ Device(s) List ############################
(G:) Optiarc DVD RW AD-7203S (si3112r, Port 2, Bus 1, Target 0, Lun 0)
(I:) IY4431E JOQ537H (abk9gp2k, Port 3, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
1394BUS.SYS abk9gp2k.SYS ACPI.sys afd.sys agp440.sys
arp1394.sys atapi.sys ATMFD.DLL audstub.sys bcmwl5.sys
Beep.SYS BOOTVID.dll BthEnum.sys bthpan.sys bthport.sys
BTHUSB.sys Cap7134.sys Cdfs.SYS cdrom.sys CLASSPNP.SYS
cmuda.sys ctxs51.sys disk.sys dmio.sys dmload.sys
drmk.sys dump_diskdump.sys dump_si3112r.sys Dxapi.sys dxg.sys
dxgthk.sys eamon.sys easdrv.sys epfw.sys Epfwndis.sys
epfwtdi.sys Fastfat.SYS fdc.sys fetnd5bv.sys Fips.SYS
fltMgr.sys Fs_Rec.SYS ftdisk.sys hal.dll hardlock.sys
HTTP.sys i8042prt.sys imapi.sys intelide.sys intelppm.sys
ipnat.sys ipsec.sys isapnp.sys kbdclass.sys KDCOM.DLL
kmixer.sys ks.sys KSecDD.sys mnmdd.SYS Modem.SYS
mouclass.sys MountMgr.sys mrxsmb.sys Msfs.SYS msgpc.sys
msmpu401.sys mssmbios.sys Mup.sys NDIS.sys ndistapi.sys
ndisuio.sys ndiswan.sys NDProxy.SYS netbios.sys netbt.sys
nic1394.sys Npfs.SYS ntdll.dll Ntfs.sys ntoskrnl.exe
Null.SYS nv4_disp.dll nv4_mini.sys ohci1394.sys parport.sys
PartMgr.sys ParVdm.SYS pci.sys PCIIde.sys PCIIDEX.SYS
PhTVTune.sys portcls.sys psched.sys ptilink.sys PxHelp20.sys
rasacd.sys rasl2tp.sys raspppoe.sys raspptp.sys raspti.sys
rdbss.sys RDPCDD.sys rdpdr.sys redbook.sys rfcomm.sys
SCSIPORT.SYS serenum.sys serial.sys si3112r.sys SiWinAcc.sys
spri.sys sr.sys srv.sys STREAM.SYS swenum.sys
sysaudio.sys tcpip.sys TDI.SYS termdd.sys update.sys
usbccgp.sys USBD.SYS usbehci.sys usbhub.sys USBPORT.SYS
usbprint.sys usbscan.sys USBSTOR.SYS usbuhci.sys vga.sys
VIDEOPRT.SYS VolSnap.sys wanarp.sys watchdog.sys wdmaud.sys
win32k.sys WMILIB.SYS x10ufx2.sys
################## Detailed Information of Device(s) ##################
(G:) Optiarc DVD RW AD-7203S(2:0) detail information.
Vendor Identification: Optiarc
Product Identification: DVD RW AD-7203S
Production Revision Level: 1.06
Support recording method: DAO, RAW SAO, RAW SAO+SUB, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: Supported ( Unknown )
Auto-Select best write speed: Not Supported
*** NOT listed in Alcohol's database. Please report to development team
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: Yes/Yes
Audio Play: No
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: No
Separate channel mute: No
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
###################### Source Disc/Image Information ######################
Type: Standard ISO image-bestand
Lokatie: C:\-=downloads=-\inventor 2009\aip_2009_1\
Naam: aip_2009_1.iso
Grootte: 3576.67 MB
Sessie: 1
Track: 1
Sessie 01:
Track 01: DVD, Lengte: 1831255(3.49 GB), Adres: 000000
####################### Dumping/Recording Progress Log #######################
********* Time stamp of this log file: 13-10-2008 22:54:19 *********
22:54:19 Processor info : Intel(R) Pentium(R) 4 CPU 3.00GHz x 2 (2992MHz)
22:54:19 Hoeveelheid geheugen beschikbaar voor Windows: 2.096.620 KB
22:54:19 Geheugen Buffer gebruik: 256 MB
22:54:19 Image-bestand bezig met laden: C:\-=downloads=-\inventor 2009\aip_2009_1\aip_2009_1.iso
22:54:19 DVD Source Info : Sessie: 1, Track: 1, Lengte: 3.49 GB / 1831255
22:54:25 (G:) Optiarc DVD RW AD-7203S(2:0): Brand methode/snelheid
22:54:25 Branden - DAO - 16.0X (22160 KB/Sec)
(G:) Optiarc DVD RW AD-7203S(2:0) - Media format: DVD+R
22:54:42 (G:) Optiarc DVD RW AD-7203S(2:0) - [Write ERROR] LBA: 28192, Length: 32
S:KEY - 04/08/03 - "Logical Unit Communication CRC Error (Ultra-DMA/32)"
22:54:42 (G:) Optiarc DVD RW AD-7203S(2:0): Branden mislukt!
22:54:42 Fout bericht : [04/08/03] - Logical Unit Communication CRC Error (Ultra-DMA/32)
22:54:42 Image-bestand laden geannuleerd!
22:54:44 Er is iets mis met de brand-procedure!
Bekijk de log-bestand en vertel de Technical Support over de fouten die erin staan.
Wie weet wat het probleem is...???
Nero eraf gegooid, UltraIso eraf, Alcohol erop, alles geupdate, kabels gecheck'd, sata kabels gewisseld 0<->1 hdd/dvd enz. enz...
alvast bedankt
Gebruik trouwens nog altijd dezelfde dvd's, 80plg kabel is n.v.t. ivm sata, Het is gekomen na de re-install van XP
verschillende images en dvd-files gebruikt...
  • MAX3400
  • Laatst online: 24-06 21:28
MAX3400
XBL: OctagonQontrol
OM FAQ / Beleid ?
Ik vermoed dat je een driver van je moederbord niet goed hebt geupdate of dat sommige software het niet snapt. Kan je met "de ingebouwde XP brandsoftware" wel branden; kan je in ieder geval uitsluiten of het aan andere software ligt of aan je PC+OS/
Voor de re-install deed alles het perfect... kon 2 dvd's tegelijk branden... vermoed dus zelf ergens een sw fout.. heb al 4 verschillende progs gebruikt om te branden dus denk ergens een instelling....maar welke ???
  • jan99999
  • Laatst online: 09-07 09:28
Op nero site de "nero remove" programma downloaden, en nero verwijderen(eerst uninstall doen).
Dan alle andere software die iets met branden te maken hebben, verwijderen, ook deamon tools of iets vergelijkbaar.
Dan op je moederbord site de chipset drivers downloaden en installeren.
Dan nero installeren en testen, indien niet goed dan toch andere dvd's proberen, of de kabel van de brander verwijderen.
Of windows weer schoon installeren,
1 windows
2 chipset driver installeren
3 videokaart
4 andere hardware
Dit is de verplichte volgorde, en nu weer testen of het werkt.
Ben er weer,
weet het nog steeds niet.. Alle drives al eens uitgetrokken en gewisseld inc. kabels.
Gereboot van de oude hdd, (staat nog alles op.) zelfde probleem.. andere brander geprobeert (ide) nog steeds niets.. de bios instellingen teruggezet...
onderhand meer dan 20 dvd's verkloot.. begin me er flink aan te ergeren...
Het komt er dus op neer dat alles wat ik brand via s-ata of ide met welk systeem dan ook misloopt....
kan dus niet ineens alle2 de branders kapot gaan, 2 verschillende controllers (ide onboard en sata pci), moederbord misschien ???
iemand nog wat meer tips... ???
  • jan99999
Windows schoon installeren, zo min mogelijk software erop zetten.
Heb je veschillende merken dvd's geprobeerd.
