Kan disc at once niet uitvoeren
  • Tumb
  • Laatst online: 02-10 13:11
Bij het brander van een DVD'tje met nero 8.1.1.0. krijg ik telkens de fout melding kan disc at once niet uitvoeren.
Zie hieronder de log file:
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.1.1.0
Internal Version: 8, 1, 1, 0
Recorder: <LITE-ON DVDRW LH-20A1S> Version: 9L08 - HA 1 TA 0 - 8.1.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <LITE-ON DVDRW LH-20A1S >Version: 9L08 - HA 1 TA 0 - 8.1.1.0
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG HD753LJ atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW LH-20A1S atapi Port 2 ID 0 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVDRW LH-20A1S F: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2047MB (2097151kB)
Free physical memory: 1912MB (1958852kB)
Memory in use : 35 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.10.2008
DVD-image branden
19:00:12 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
19:00:12 #2 Text 0 File Burncd.cpp, Line 3530
Turn on Disc-At-Once, using DVD media
19:00:17 #3 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286041 (508:00.41, 4464MB)
19:00:17 #4 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
19:00:17 #5 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: LITE-ON DVDRW LH-20A1S, Media type: DVD+RW
Disc Manufacturer ID: <SONY>, Media Type ID: <S11>, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 1
19:00:17 #6 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: DVD+RW. Medium required by compilation: DVD R/RW; DVD DL; DVD-RAM.)
This disc is not empty.
Accessing disc...
19:00:17 #7 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 2286042 (2286042) = #2286042/508:0.42
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286042 blocks [F: LITE-ON DVDRW LH-20A1S]
19:00:17 #8 Text 0 File ThreadedTransferInterface.cpp, Line 986
Prepare [F: LITE-ON DVDRW LH-20A1S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681814016, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2286042 | 2286042 | 0x00
2286042 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
19:00:17 #9 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
19:00:17 #10 Text 0 File Burncd.cpp, Line 4316
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
19:00:17 #11 Phase 24 File dlgbrnst.cpp, Line 1764
Caching of files started
19:00:17 #12 Text 0 File Burncd.cpp, Line 4435
Cache writing successful.
19:00:17 #13 Phase 25 File dlgbrnst.cpp, Line 1764
Caching of files completed
19:00:17 #14 Phase 36 File dlgbrnst.cpp, Line 1764
Burn process started at 4x (5.540 kB/sec)
19:00:17 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2735
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
19:00:17 #16 Text 0 File Cdrdrv.cpp, Line 10026
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-ROM (0), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
Data in Burst Cutting Area (BCA) does not exist
Twin Format Flag: 0
Media Specific [16..783]:
00 00 01 53 4F 4E 59 00 - 00 00 00 53 31 31 00 39 ...SONY....S11.9
23 00 B4 72 68 02 24 00 - AE 75 58 02 28 00 B2 73 #..rh.$..uX.(..s
62 02 24 04 12 10 E0 10 - F0 00 00 00 00 00 00 00 b.$.............
01 00 17 38 00 2F 8A 52 - 02 1C 00 33 84 36 02 28 ...8./.R...3.6.(
00 2E 8D 48 02 28 64 26 - 20 00 20 E0 40 00 00 00 ...H.(d&....@...
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
19:00:31 #17 Text 0 File DVDR.cpp, Line 7047
Drive: LITE-ON DVDRW LH-20A1S
Book Type request [LO], rev 3: DVD-ROM
Changing the Book Type was finished successfully, return code 0, Mode 2 return code 0
19:00:31 #18 CDR -1207 File DVDR.cpp, Line 6452
Book Type automatically set to: DVD-ROM
19:00:31 #19 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
19:00:31 #20 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
19:05:54 #21 SPTI -1033 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x5C 00 00 00 00 00 00 00 0C 00 00 00
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01
Buffer x04ecb640: Len xc
19:05:54 #22 SPTI -1033 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x2A 00 00 0B 58 A0 00 00 20 00 00 00
Buffer x09063a80: Len x10000
0x00 00 01 BA 44 2A 6D 20 04 21 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 81 72 69 E2 43 37 2E 1B 71
0x74 49 A9 F4 9B AC 39 74 48 5C 53 26 FA 0E 6B 5C
19:05:54 #23 CDR -1033 File Writer.cpp, Line 306
Drive not ready
19:05:55 #24 SPTI -1033 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00
19:05:55 #25 SPTI -1033 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x04
Sense Qual: 0x01
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Buffer x07cf3500: Len x20
19:05:55 #26 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 743584
19:05:56 #27 CDR -1033 File WriterStatus.cpp, Line 162
Drive not ready
19:05:56 #28 TRANSFER -24 File WriterStatus.cpp, Line 162
Could not perform end of Disc-at-once
19:05:57 #29 Phase 38 File dlgbrnst.cpp, Line 1764
Burn process failed at 4x (5.540 kB/sec)
19:05:57 #30 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
19:06:02 #31 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
19:06:02 #32 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Ik heb geprobeerd de firmware te update, maar dit lukt niet.
Zie melding.
Afbeeldingslocatie: http://img253.imageshack.us/img253/9800/liteonof0.th.jpg
Volgens mij heb ik de juiste versie geselecteerd.
Het mislukt zowel op een +RW als een DVD-R schijfje.
Imgburn krijgt hem ook niet gebrand.
De image brander met een andere pc lukt wel.
Iemand enige idee wat de oorzaak is ?
Heb zo een vermoeden dat het een hardware probleem is.
  • Caveman
  • Laatst online: 28-09 19:42
Caveman
whahoehaha
Dat is grappig, firmware is alleen voor LH-20A1S....detected LH-20A1S 8)7
Maar goed, om verder uit te sluiten of het aan de hardware of aan je OS ligt zou ik ff een andere drive erin hangen, doet die het wel goed dan heb je het probleem al boven water. DVD branders kosten nu ook weer niet de wereld.
I don't need to "Get a Life." I'm a Gamer. I 've lots of Lives !
  • Fish
Fish
How much is the fish
gebruik je dan ook dezelfde dvd ?
Accessing disc...
Iperf
  • Tumb
fish schreef op zaterdag 11 oktober 2008 @ 11:55:
De DVD van de logfile is een RW.
Heb het nog geprobeerd met een normale DVD maar dit mislukte.
@Caveman
Even een andere brander erin stoppen is nog wel een idee'tje.
Er zit op deze overigens nog wel garantie.
Vraag me af hoe ze die testen in de winkel.
