HP 2810-48G: out of packet buffer
  • Foeijonghaai
  • Laatst online: 07-07 12:29
Ik heb een stuk of 8 HP 2810-48G's en 2 HP 24810-24G's.
De laatste tijd krijg ik zo nu en dan de melding (in de switchlogs, via syslog):
W 10/07/08 08:11:38 system: Out of pkt buffers; miss count: 216683
(Het aantal achter count: loopt steeds op).
Voor zover ik weet, is de packet buffer vol en kan de switch dan geen inkomende pakketten meer aanpakken, waardoor hij wel moet gaan droppen. Als ik de packet buffers bekijk, zie ik dat er regelmatig nog oude packets in de buffer staan. Een voorbeeldje:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
pktpoolshow
Checking buffer pool structures... PASSED
             total   free  allocated  min-free  missed  corrupt
  MSG_BUF     1800   1754       46       1713        0       0
  PKT_BUF     3072   2824      248         48    216960       0
PKT buffer pool:
Current system time: 10/10/08 12:00:41
  Buffer addr  OwnerName   OwnerID     When Allocated   Lives  Operation  Alarm
   0xa37fc0c0       bcmRX  81f51cf0  10/10/08 10:38:38    0    00000000   F
   0xa366adb0       bcmRX  81f51cf0  10/10/08 10:47:39    0    00000000   F
   0xa2b9b5b0       bcmRX  81f51cf0  10/10/08 10:49:58    0    00000000   F
   0xa2ad65d0       bcmRX  81f51cf0  10/10/08 10:52:26    0    00000000   F
   0xa2893660       bcmRX  81f51cf0  10/10/08 10:54:42    0    00000000   F
   0xa2f71ea0       bcmRX  81f51cf0  10/10/08 10:57:07    0    00000000   F
   0xa277f210       bcmRX  81f51cf0  10/10/08 10:58:20    0    00000000   F
   0xa30f97f0       bcmRX  81f51cf0  10/10/08 10:59:34    0    00000000   F
   0xa2f16a00       bcmRX  81f51cf0  10/10/08 10:59:34    0    00000000   F
   0xa281daf0       bcmRX  81f51cf0  10/10/08 11:04:15    0    00000000   F
   0xa36ae1f0       bcmRX  81f51cf0  10/10/08 11:07:42    0    00000000   F
   0xa2f7ded0       bcmRX  81f51cf0  10/10/08 11:07:42    0    00000000   F
   0xa2a26fe0       bcmRX  81f51cf0  10/10/08 11:07:42    0    00000000   F
   0xa2c4f880       bcmRX  81f51cf0  10/10/08 11:11:08    0    00000000   F
   0xa3a0a290       bcmRX  81f51cf0  10/10/08 11:12:18    0    00000000   F
   0xa305fbf0       bcmRX  81f51cf0  10/10/08 11:12:18    0    00000000   F
   0xa31cce70       bcmRX  81f51cf0  10/10/08 11:14:36    0    00000000   F
   0xa32ed2f0       bcmRX  81f51cf0  10/10/08 11:14:36    0    00000000   F
   0xa3cdd440       bcmRX  81f51cf0  10/10/08 11:17:39    0    00000000   F
   0xa35e9210       bcmRX  81f51cf0  10/10/08 11:18:42    0    00000000   F
   0xa252b590       bcmRX  81f51cf0  10/10/08 11:18:42    0    00000000   F
   0xa3cc53e0       bcmRX  81f51cf0  10/10/08 11:21:00    0    00000000   F
   0xa3c050e0       bcmRX  81f51cf0  10/10/08 11:23:14    0    00000000   F
   0xa3db0ac0       bcmRX  81f51cf0  10/10/08 11:23:14    0    00000000   F
   0xa3642040       bcmRX  81f51cf0  10/10/08 11:24:27    0    00000000   F
   0xa2b2f400       bcmRX  81f51cf0  10/10/08 11:27:57    0    00000000   F
   0xa28802e0       bcmRX  81f51cf0  10/10/08 11:29:07    0    00000000   F
   0xa3b8cf00       bcmRX  81f51cf0  10/10/08 11:30:21    0    00000000   F
   0xa3cf7b10       bcmRX  81f51cf0  10/10/08 11:30:21    0    00000000   F
Je ziet dus dat de huidige tijd 12:00:41 is, maar dat er nog pakketten in de buffer staan van 10:38. Over het algemeen zie ik de pakketten na 2 uur verdwijnen in de buffer.
Ik kan me voorstellen dat als er maar genoeg (oude) packets in de buffer staan, dat er op den duur ook geen ruimte meer is voor nieuwe packets en dat er dus gedropt moet worden op drukke tijden.
Ik dacht dat het leven van een Ethernet Frame niet lang beschoren was: eenmaal afgeleverd heeft het geen nut meer in de buffer toch?
Als ik de "Out of pkt" melding vergelijk met de andere meldingen in de switchlogs, dan zie ik dat de melding voornamelijk optreedt als machines rebooten (maakt niet uit of die machine op dezelfde switch zit of op een andere switch).
Ik heb reeds met HP gebeld maar die zeiden doodleuk dat ik de firmware moest upgraden zonder te vragen wat het probleem was (beetje eigen schuld natuurlijk, want geen care pack). Uiteraard wil ik wel upgraden, maar dat moet ik eerst plannen (downtime aankondigen, klanten op de hoogte brengen enz) dus het duurt even voordat dat uitgevoerd kan worden, dus vandaar dat ik aan het kijken ben of ik op de korte termijn het een en ander kan oplossen.
Ik heb de vraag ook al uit staan op het HP support forum, maar tot op heden geen reactie. Op dat forum vond ik wel soortgelijke meldingen, en de adviezen daar waren Mac-age timeout verhogen, QoS-settings wijzigen en dat het te maken zou hebben met een convergerende Spanning-Tree.
Volgens mij is dat laatste niet het geval (getuige de logs van alle switches). De topologie is behoorlijk statisch. Mac-age timeout staat nu op 300 (default) en dit lijkt me niet een verkeerde waarde. QoS-settings stonden default al op de aangeraden waarden.
Mijn vragen:
- weet iemand hoe het kan dat er zolang nog packets blijven staan in de buffer?
- Wat kan een reden hiervoor zijn?
- Zijn het foutieve pakketten?
- Ligt het aan de hosts?
- Moet ik de fout zoeken in de switch?
- Of is dit volledig normaal gedrag?
Ik zou graag de blijvende packets/frame willen inzien, maar dat laat de CLI van de switch niet toe.
- zijn er mogelijkheden om de inhoud van de packets die blijven staan te inspecteren zonder al te dure apparatuur?
  • jvanhambelgium
  • Laatst online: 17:52
>Mijn vragen:
Wat bedoel je met "de laatste tijd begin ik deze problemen te zien" ???
Is er iets gewijzigd ?? (vb gigabit poorten in gebruik tov vroeger fast-ethernet, dus meer load op de backplane)
Config-wijzigingen ??
Sowieso lijkt me dit een bug te zijn (of tekortkoming) en de repliek van HP is niet abnormaal. (krijg je ook te horen bij Cisco, Nortel etc)
Eerst upgraden naar de laatste stable versie! (tenzij je een verdomd goede reden hebt dit niet te doen?)
Neen dit is dus niet normaal, en nee, het ligt niet aan de hosts. Een switch moet verdorie zijn werk doen, ongeacht wat er achter hangt ;-)
  • CyBeR
CyBeR
Loop even de release notes na van de software van de 2810 en kijk of dit probleem erin voorkomt? (Gewoon de meest recente pakken, staat alles van vorige versies ook in.)
  • KoeKk
  • Laatst online: 30-06 19:26
CyBeR schreef op zaterdag 11 oktober 2008 @ 14:49:
Er worden ook bugfixes uitgevoerd in de HP software updates die niet vermeld worden in de release notes, dus dat geeft geen garantie. Dat is tevens ook de reden dat HP je vraagd eerst de firmware te updaten, het kan makkelijk zijn dat een firmware update dit verhelpt.
Als ik kijk in een 2810-24:
29
pktpoolshow
  MSG_BUF     1800   1755       45       1691        0       0
  PKT_BUF     3072   2952      120       2913        0       0
PKT buffer pool:
Current system time: 10/11/08 14:47:11
   0xa3fab910       bcmRX  81f8aba0  10/11/08 14:46:51    0    00000000   F
   0xa3e75aa0       bcmRX  81f8aba0  10/11/08 14:46:51    0    00000000   F
   0xa3e99b30       bcmRX  81f8aba0  10/11/08 14:46:51    0    00000000   F
   0xa3ec0230       bcmRX  81f8aba0  10/11/08 14:46:51    0    00000000   F
   0xa3fa92a0       bcmRX  81f8aba0  10/11/08 14:46:51    0    00000000   F
   0xa3ed5c20       bcmRX  81f8aba0  10/11/08 14:46:51    0    00000000   F
<<SNIP>>
   0xa3ee6930       bcmRX  81f8aba0  10/11/08 14:47:11    0    00000000   F
   0xa3ef9cb0       bcmRX  81f8aba0  10/11/08 14:47:11    0    00000000   F
   0xa3ebdbc0       bcmRX  81f8aba0  10/11/08 14:47:11    0    00000000   F
   0xa3f50470       bcmRX  81f8aba0  10/11/08 14:47:11    0    00000000   F
  Note: (null) indicates buffer allocated at init time (not used since).
  Use  bufShow(pkt_addr or msg_addr) for data on single pkt or msg
Dan zie ik iets totaal anders. Voor zover ik weet is er geen (gedocumenteerd) commando om iets aan de buffer instellingen aan te passen. En als dat wel bestaat zou is zou je dat in de handleiding en je config file moeten kunnen terugvinden.
Welke firmware versie gebruik je nu? De laatste versie is N.11.09: http://www.hp.com/rnd/software/switches.htm
  • CyBeR
CyBeR
KoeKk schreef op zaterdag 11 oktober 2008 @ 16:57:
Dat is waar, maar als 't er wel in staat is 't helemaal duidelijk, niet? ;)
  • Foeijonghaai
jvanhambelgium schreef op zaterdag 11 oktober 2008 @ 14:47:
Mijn werkzaamheden bestaan uit systeembeheer en netwerkbeheer. Vandaar dat ik niet altijd 100% aandacht voor het netwerk kan hebben en niet 100% aandacht voor de systemen. Recentelijk hebben we alle oude switches (ander merk) uitgefasseerd en langzaam vervangen voor HP's. Omdat ik voornamelijk mijn aandacht gericht had op het migratietraject heb ik tot voor kort geen aandacht gericht op deze meldingen. Ik dacht namelijk dat eea met de migratie naar de nieuwe switches te maken had.
Nu draait het netwerk al enkele weken stabiel (als in: geen nieuwe switches meer toegevoegd en geen oude componenten meer verwijderd) en nu begint de melding mij op te vallen.
Nee. Verder is de load niet noemenswaardig (denk ik). Cpu-belasting van de switches ligt rond de 10 a 15 procent. Port-utilization is bij de meeste poorten rond de 5%, enkele poorten doen rond de 10% (bij Gigabit 100Mbit dus).
Neen.
Ik snap de repliek van HP natuurlijk wel ;) . Ik ga ook wel upgraden, maar dat duurt gewoon wat langer.
Ok.
Bedankt voor je input!
  • Foeijonghaai
Ik had ze al bekeken, maar ik was er nog niet overuit of de "RX Counters" of de "sFlow" fix met dit probleem te maken heeft. Hoe dan ook, we gaan binnenkort upgraden. Gelukkig heb ik voor dat soort gevallen een testswitch en zijn deze switches in staat om tegelijkertijd twee software-versies naast elkaar geinstalleerd te hebben :D.
For the record: Software fixes:
Release N.11.07
Problems Resolved in Release N.11.07
RX Counters (PR_1000458490) The "Drops RX" counters increment on spanning treeblocked ports.
Release N.11.08
Problems Resolved in Release N.11.08
IGMP (PR_1000466842) IGMP (PR_1000466842) - IGMP drops multicast streams at random intervals, if there are two or more streams. The first stream is not affected.
Release N.11.09
Problems Resolved in Release N.11.09
Mirroring (PR_1000460844) Packets to other VLANs are mirrored when the vlan x monitor command is used.
SNMP (PR_1000715545) The switch sends unconfigured traps upon boot.
DST (PR_1000467724) The DST change-over dates are incorrect for the Western-European time zone.
xSTP (PR_1000330684) The spanning-tree command help text has been updated.
Sflow (PR_1000749192) When ports are configured as a trunk, traffic may not be sampled or may be sampled incorrectly.
Counters (PR_1000756649) The switch is incorrectly incrementing the IfInDiscard error counter.
  • Foeijonghaai
<snip>
Typisch dat er bij jou geen hele oude frames instaan.
Welke software draai jij? Ik draai nog N.11.06.
  • jvanhambelgium
Zijn er eigenlijk gebruikers die er last van hebben ? Applicaties die minder responsief worden of andere dingen die je nu aan de "systems" kan beginnen op vallen ??
Indien niet valt het gelukkig mee ... dan heb je even ademruimte ;-)
  • KoeKk
Foeijonghaai schreef op maandag 13 oktober 2008 @ 09:35:
NNLDORSWS01-1# sho ver
Image stamp:    /sw/code/build/bass(bh2)
                Sep 27 2007 10:02:23
                N.11.06
                730
Boot Image:     Primary
NNLDORSWS01-1#
Volgensmij moet ik ze ook weer eens gaan updaten :D. En nog even on the side, een Carepack biedt over het algemeen alleen hardware support, daar wordt je door procurve support niet sneller of langzamer door geholpen :)
[ Voor 14% gewijzigd door KoeKk op 13-10-2008 11:28 ]
  • Foeijonghaai
jvanhambelgium schreef op maandag 13 oktober 2008 @ 11:01:
Tot nu toe hebben we geen klachten van klanten gehad (ik werk voor een hostingbedrijf) maar een aantal beheerders hadden soms dat het netwerk wat langzamer was dan dat ze gewend waren. Omdat ze verder niet hebben uitgezocht waar dat aan zou kunnen liggen (netwerk thuiswerkplek, op kantoor, etc) weten we niet of het echt te herleiden is tot 'ons' netwerk.
Ik heb downtime gepland en ga volgende week woensdagnacht de software vervangen. Vanochtend heb ik dit getest met onze testswitch en dat werkt.
Ik zal tzt ook laten weten of het probleem daarmee is opgelost.
  • Foeijonghaai
Een update:
Sinds mijn laatste post heeft de melding zich niet meer voorgedaan. :*) Toch maar besloten om de upgrade door te zetten, om bij te blijven met de software en mocht het zich toch weer voordoen.
Gisterennacht alle switches geupgraded naar N_11_09, de laatste versie van de software voor dit type switch.
Helaas zag ik zonet al weer oude frames in de buffer en ook weer een flink aantal misses. :/
29
30
31
32
33
34
  MSG_BUF     1800   1755       45       1693        0       0
  PKT_BUF     3072   2823      249         48     3142       0
PKT buffer pool:
Current system time: 10/22/08 11:37:45
   0xa36a9510       bcmRX  81f51cf0  10/22/08 10:09:02    0    00000000   F
   0xa38bea30       bcmRX  81f51cf0  10/22/08 10:40:03    0    00000000   F
   0xa3eb8ee0       bcmRX  81f51cf0  10/22/08 10:40:03    0    00000000   F
   0xa3769810       bcmRX  81f51cf0  10/22/08 10:44:47    0    00000000   F
   0xa3f82ba0       bcmRX  81f51cf0  10/22/08 10:44:47    0    00000000   F
   0xa3b74ea0       bcmRX  81f51cf0  10/22/08 10:54:02    0    00000000   F
   0xa2ffd400       bcmRX  81f51cf0  10/22/08 10:56:07    0    00000000   F
   0xa3876910       bcmRX  81f51cf0  10/22/08 10:57:31    0    00000000   F
   0xa371f080       bcmRX  81f51cf0  10/22/08 10:58:35    0    00000000   F
   0xa3dde510       bcmRX  81f51cf0  10/22/08 10:59:34    0    00000000   F
   0xa3ccc730       bcmRX  81f51cf0  10/22/08 10:59:34    0    00000000   F
   0xa3cb93b0       bcmRX  81f51cf0  10/22/08 10:59:34    0    00000000   F
   0xa3c9c670       bcmRX  81f51cf0  10/22/08 10:59:34    0    00000000   F
   0xa2d8f0b0       bcmRX  81f51cf0  10/22/08 11:01:02    0    00000000   F
   0xa3983a10       bcmRX  81f51cf0  10/22/08 11:01:02    0    00000000   F
   0xa3a33000       bcmRX  81f51cf0  10/22/08 11:02:02    0    00000000   F
   0xa36c3be0       bcmRX  81f51cf0  10/22/08 11:02:02    0    00000000   F
   0xa24c8da0       bcmRX  81f51cf0  10/22/08 11:02:02    0    00000000   F
   0xa319a740       bcmRX  81f51cf0  10/22/08 11:03:03    0    00000000   F
   0xa3324700       bcmRX  81f51cf0  10/22/08 11:04:30    0    00000000   F
   0xa2fc5ff0       bcmRX  81f51cf0  10/22/08 11:05:32    0    00000000   F
   0xa36c88c0       bcmRX  81f51cf0  10/22/08 11:05:32    0    00000000   F
   0xa38e5130       bcmRX  81f51cf0  10/22/08 11:06:58    0    00000000   F
Misschien maar weer eens bellen met HP.
  • jvanhambelgium
Yep, tijd voor een case te openen ;-)
Mischien een stuk slecht geheugen in de switch (datgene dat voor de packet buffer gebrukt is) ofzo ?
Of mischien bestaan er wel CLI-commado's om die pool groter te maken (met begrenzing fysisch geinstalleerd geheugen natuurlijk) of bepaalde "flushing" tweaks oid.
  • grimson
  • Laatst online: 09-07 19:20
grimson
domeingrommer
Foeijonghaai schreef op maandag 13 oktober 2008 @ 16:13:
Ik heb het topic ook even doorgelezen en ben wel benieuwd hoe het afgelopen is?
  • Foeijonghaai
grimson schreef op zaterdag 17 januari 2009 @ 16:08:
Ik krijg de meldingen niet meer in de logs maar ik zie nog steeds wel oude frames in de buffer blijven staan (bijv. het is nu 9:02uur en er staat nog een frame in van 7:50uur).
De laatste tijd is de verkeersdrukte in ons netwerk wel toegenomen door het in gebruik nemen van nieuwe diensten (o.a. iscsi) maar heb nog steeds geen foutmeldingen gezien :)
Binnenkort ga ik upgraden naar N_11_15 omdat hier ook weer wat problemen zouden zijn opgelost (o.a. de vraag of je de config wil bewaren, terwijl je niets hebt veranderd, en dat de uptime na 50 dagen weer op 0 dagen springt en de switch meldt dat ie gecrashed is geweest, terwijl dat niet zo was).
Overigens heb ik wat gemengde gevoelens over HP support. Al met al toch wel wat handige tips van gekregen, maar ze weigerden bijv. naar het probleem te kijken omdat ze de topologie niet snapten terwijl ik er een duidelijk diagram en begeleidend schrijven bij had gedaan en ze bleven maar vallen over dat er twee trunks liepen naar het SAN.
  • stefklep
  • Laatst online: 15:54
stefklep
((Stefklepje))
Foeijonghaai schreef op woensdag 21 januari 2009 @ 09:12:
Ik mag hopen voor je dat je Iscsi verkeer scheidt en niet allemaal via 1 switch doet ? Ofwel een aparte switch alleen voor Iscsi verkeer.
  • Foeijonghaai
stefklep schreef op woensdag 21 januari 2009 @ 15:08:
Momenteel gaat het nu wel via dezelfde switch. Totale verkeer NFS + ISCSI heb ik nog niet boven de 250Mbit uit zien komen, dus het valt nog mee.
  • stefklep
stefklep
((Stefklepje))
Foeijonghaai schreef op donderdag 22 januari 2009 @ 09:58:
Ik raad je dit echt aan om dit te scheiden, dit wordt dan ook echt overall aangeraden. Omdat er namelijk heel veel problemen mee onstaan als je dit allemaal over 1 switch gooit. Wij hebben namelijk een Equallogic wij waren al van plan om dit iscsi verkeer te scheiden, toen we ook nog contact gehad hebben met een san expert. Werd ons verhalen verteld dat je het zeker moet doen vooral het bekende buffer verhaal, waar jij lijkt ook last van te hebben omdat je alles over 1 switch gooit. Dus ik raat je echt aan om zeker hier even naar te kijken.
[ Voor 7% gewijzigd door stefklep op 22-01-2009 21:40 ]
  • jvanhambelgium
stefklep schreef op donderdag 22 januari 2009 @ 21:39:
Scheiding in de zin van "andere VLAN" zou ik sowieso ook overwegen. Maar een "dedicated" switch hiervoor neerzetten ? Ik denk gewoon een deftige switch in huis nemen voor zoiets...
Je moet kijken welke traffiek gaat gaat verwachten, je kijkt wat de switch over z'n fabric kan trekken, wat de verschillende pps-forwarding rates zijn onder bepaalde omstandigheden.
  • Foeijonghaai
jvanhambelgium schreef op donderdag 22 januari 2009 @ 22:04:
Iscsi-verkeer zit bij ons idd in een ander VLAN. We hebben een hierarchische topologie met een access-laag, een distributielaag/core-laag (we hebben nog niet zoveel apparatuur dat we die extra tier al kunnen maken) en de trunks naar de laag erboven komen momenteel nog niet boven de 250Mbit uit, terwijl het Gbit-links zijn.
  • ijdod
  • Laatst online: 17:11
Foeijonghaai schreef op vrijdag 23 januari 2009 @ 08:39:
250 Mbps met welke meetinterval? In de min-of-meer standaard 5 minuten zie je een volle belasting van 10 seconden niet terug, terwijl er een reeele kans is dat gebruikers dat wel degelijk gemerkt hebben (of dat er inderdaad packets gedropt zijn).
iSCSI is een vervelende. Men wil block based storage over LAN apparatuur, omdat SAN appartuur te duur wordt gevonden. Tegelijk wil men de lossless features van fibrechannel toevoegen aan ethernet. En dat zijn nu net de features die het zo duur maken :P. Vanuit dat perspectief is alleen het onderbrengen in een vlan niet voldoende. Ik weet dat er meerdere fabrikanten kijken naar relatief eenvoudige maar efficiente switches die dan dedicated worden ingezet voor dit soort toepassingen, juist niet het tot FC verbouwen van ethernet. Effectief heb je dan nog steeds een 'los' SAN, maar een stuk goedkoper.
