dancis
  • 275 views
  • Dancis
  • Laatst online: 19:03
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
    while ($i < $qty) {
        if($y == 5) {
            echo '<td width="5">&nbsp;</td></TR>'."\r\n\r\n";
            $y = 0;
        if ($y == 0) {
            if ($i > 0) { echo '<tr><td height="10"></td></tr>'; }
            echo "\r\n".'<TR><td width="5">&nbsp;</td>';
        $trucknr =  mysql_result($outcome, $i, "trucknr");
        $soort =    mysql_result($outcome, $i, "soort");
        $merk =     mysql_result($outcome, $i, "merk");
        $type =     mysql_result($outcome, $i, "type");
        $bj =       mysql_result($outcome, $i, "bj");
        $km =       mysql_result($outcome, $i, "km");
        $opbouw =   mysql_result($outcome, $i, "opbouw");
        $lvm =      mysql_result($outcome, $i, "lvm");
        $fotonaam = mysql_result($outcome, $i, "fotonaam");
        $furl = CreateFriendlyUrl($trucknr, $merk.' '.$type);
        echo '
        <td width="135" valign="top"><a name="'.$soort.'">
        <table style="BORDER-COLLAPSE: collapse" borderColor="#ebe9ea" cellSpacing="0" cellPadding="0" width="135" border="1">
            <tr>
                <td align="middle"><div style="margin: 5px;"><a href="/usedtrucks/info/'.$furl.'"><img border="0" src="pictures/truckbase/thumbnails/'.$fotonaam.'" width="125" height="94"></td>
            </tr>
            <tr>';
                echo '<td align="middle"><div style="margin: 5px; background-color: #EFF4FA; padding:3px;"><font face="Arial" style="font-size: 8pt">';
                    echo "<B><font color=\"#003366\">".ucwords($merk.' '.$type)."</font></B>, ".Soort2String($soort)."<br>Bouwjaar: ".$bj."<br>";
                    echo rtrim(CreateInfoText(number_format($km, 0, "", "."), 'Km.Stand: ', " km<br>"), ', ');
                    echo rtrim(CreateInfoText($_SESSION['my_opbouw'][$opbouw], 'Opbouw: ', "<br>"), ', ');
                    echo rtrim(CreateInfoText(number_format($lvm, 0, "", "."), 'Laadverm.: ', " kg"), ', ');
                    echo '</a></div></td>
            </tr>
        </table>
        </td>';
        if ($y < 4) { echo '<td width="22">&nbsp;</td>'; }
        $i++;
        $y++;
        $kleurkiezer=!$kleurkiezer;
    if ($y <= 5) {
        $x = 0;
        while ($x < (5 - $y)) {
            echo '
            <table style="BORDER-COLLAPSE: collapse" borderColor="#E4E3E4" cellSpacing="0" cellPadding="0" width="135" border="1">
                <tr>
                    <td align="middle"><p style="margin: 5px;"><img border="0" src="images/spacer_gray.gif" width="125" height="94"></td>
                </tr>
            </table>
            </td>';
            if ($x < ((5 - $y) -1)) { echo '<td width="22">&nbsp;</td>'; }
            $x++;
        echo '<td width="5">&nbsp;</td></TR>';
    mysql_free_result($outcome);
Klanten kunnen dus maximaal 5 foto's toevoegen. Maar als men het komplete overzicht opvraagt van een klant dan krijgt men de foto tezien die als laatste is toegevoegd terwijl dat gewoon de eerste foto moet zijn. Ik ben al met ASC en DESC aan het stoeien geweest maar dat leverde niet het gewenste resultaat op. En ik heb dit stukje code al een aantal keren door gespit maar kan niet vinden waar het fout gaat , jullie misschien nog tips?
[ Voor 0% gewijzigd door Dancis op 06-10-2008 12:08 . Reden: topic titel aanpassen hoe?? ]
  • BtM909
BtM909
Watch out Guys...
Geef eens een titel suggestie door middel van de Topic Report bovenin. dancis zegt namelijk niet zoveel over je probleem ;)
Nogal onoverzichtelijk met de weinige info die je bij de code geeft en het gepruts met al die tables. Heb je in ieder geval gekeken of de result set van je query er in ieder geval in juiste volgorde uitkomt?
Is dit nou al het derde topic voor je probleem :X
[ Voor 11% gewijzigd door Verwijderd op 06-10-2008 12:12 ]
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Lees RobIII in "eerste foto tonen" en BtM909 in "eerste foto tonen" nog eens rustig door... dit is niet de manier. Meer leesvoer: Je topic is dicht en het is onterecht? Lees hier!
Dancis schreef op maandag 06 oktober 2008 @ 12:06:
Waar dan? Ik zie geen query in je code :?
Wat dan wel? Foutmelding? Verkeerde output? Wat?
[ Voor 39% gewijzigd door RobIII op 06-10-2008 12:22 ]
Je eigen tweaker.me redirect
Over mij
  • whoami
  • Laatst online: 30-10 12:27
Het is niet de bedoeling dat je meerdere topics opent voor hetzelfde probleem.
Daarbij wil ik je ook eens wijzen op *** Over topictitels in PRG - lezen voor topic openen!!! *** & op onze Quickstart.
Probeer zelf eens de code te debuggen, stap voor stap te doorlopen, en probeer na te gaan waar er wat precies foutloopt.
Zoals je het topic nu opent, komt het neer als 'hier, een lap code, dit is het probleem, los het ff voor mij op. Alstublieft, danku', en dat is nu net niet de manier waarop het hier werkt.
We willen dat je zelf al één en ander geprobeerd hebt om je probleem op te lossen, en dat je ook in je topicstart aangeeft wat je geprobeerd hebt. Voor meer info: zie de quickstart.
[ Voor 13% gewijzigd door whoami op 06-10-2008 12:24 ]
https://fgheysels.github.io/
  • BtM909
BtM909
Watch out Guys...
Kleine kanttekening: ik heb de TS toestemming gegeven om het nogmaals te problemen mits aan alle voorwaarden zoals wij met z'n drieën hebben aangegeven :)
Doet niet af van het feit dat dit topic wederom niet de way to go is :)
