Telenet moden -> Router -> Digicorder
Hello,
Zoals titel al zegt is dat men netwerk setup. Nu lees ik overal dat de digicorder rechtsstreeks op de modem moet.
Dit aan de hand van een switch'ke. Nu probleem is, kabelmatig is dat heel moeilijk.
Dus wens ik het toch werkend te krijgen via de router.
Nu kan ik surfen op de digicorder maar geen interactive toepassingen gebruiken. Dus moeten er toch een paar poorten opgezet worden of dergelijke maar ik vind nergens de welke.
Iemand hier die deze info heeft?
Thx
  • Ra_gdd
  • Laatst online: 13-10 14:05
Ra_gdd
-= Nigga on tha Trigga =-
Met m'n Linksys WRT54GL en Thibor Hyperwrt 15C firmware kan ik poorten van deze router rechtstreeks met internet verbinden.
Zo moet je geen extra modem of extra switch gebruiken met je digibox/corder.
Hoe?
http://www.dd-wrt.com:80/wiki/index.php/Switched_Ports
Switched Ports
[edit] Usage examples
With an older router, you can make for instance ports 3 and 4 to reside outside the router's NAT. Devices attached to these ports will request an own IP address from the ISP instead of getting a private IP address from your WRT. One might want to have such behaviour when having unsorted firewall issues with a SIP operator.
nvram set vlan0ports="1 2 5*"
nvram set vlan1ports="0 3 4 5"
nvram commit
reboot
According to the user reports, this is confirmed to work at least with a WRT54GSv1.1 after power cycling the router.
If you want to recover the default settings, write the following within ssh session:
nvram set vlan0ports="1 2 3 4 5*"
nvram set vlan1ports="0 5"
nvram commit
reboot
[edit] Disable LAN ports
Another usage would be to disable the LAN ports exept the one that connects you to the rest of the world . You can use your router as an access point and nobody can plug in his network cable to get around your Radius authentication (requested in the German DD-WRT forum http://www.dd-wrt.com/phpBB2/viewtopic.php?p=26821)
Tested with a WRT54G v5
nvram set vlan0ports="3 5*"
nvram set vlan1ports="5"
nvram commit
reboot
will make only LAN port 1 work. So you can plug in cables to the other ports and try to hijack the internet connection but will not even get to the firewall.
[edit] The Port Numbering Explained
The numbers mean the following:
WRT54G v4 & WRT54GS v3
0 = port 4
1 = port 3
2 = port 2
3 = port 1
4 = WAN
5 = CPU internal
5* = CPU internal default
WRT54G v2/v3 & WRT54GS v1/v2
0 = WAN
1 = port 1
2 = port 2
3 = port 3
4 = port 4
5 = CPU internal
WRT54GL v1.1
0 = port 4
1 = port 3
2 = port 2
3 = port 1
4 = WAN
5 = CPU internal
The variable vlan0ports equals to the natted LAN side. Correspondently vlan1ports refers to the WAN side, outside the router's internal NAT addressing scheme.
A little extra explanation regarding port 5: the switch that is built in to the router is a 6 port switch. The sixth port (numbered 5) is the only port not connected to an outside connector. Instead, it is directly connected to the et0 interface on the motherboard. Port 5 must be included on any VLAN that must be visible to the CPU. The asterisk (*) signifies that the VLAN it is attached to is the default VLAN: if the switch receives a packet on port 5 that is not tagged it is put into the VLAN where the * is configured. Always make sure this is vlan0.
The WLAN interface does not support VLANs. It is, however, usually bridged to vlan0. It's possible to bridge virtual wireless interfaces to different VLANs VLAN Detached Networks each with Wireless and Internet
Categories: English documentation | Basic tutorials
WRT54GL met poort 3 & 4 voor Digicorder
nvram set vlan0ports="0 1 5*"
nvram set vlan1ports="2 3 4 5"
nvram commit
reboot
http://www.tweakers.net/gallery/92748/sys / http://www.tweakers.net/gallery/sys/11563" / http://www.tweakers.net/gallery/sys/11561
