[Cisco] 2801 upgrade probleem
  • Ducktape
  • Laatst online: 15-07 00:50
Na het uvervangen van de compactflash kaart met de zelfde IOS (andere load files voor ephones) krijg is een melding na het uitpakken van de IOS:
Wrong system software for this hardware
Diverse IOS versies op verschillende CF kaartjes geprobeerd, maar elke keer komt deze melding terug. Het enige wat ik nu nog kan is rondloeren in de rommon.
wat info:
System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 2004 by cisco Systems, Inc.
Initializing cache
Initializing TLB and required TLB entries
Reading monitor variables from NVRAM
Init Rommon Upgrade NVRAM Vars
Init Rommon Upgrade startPLD version 0x10
GIO ASIC version 0x127
Reset IO
Enabling interrupts
Reading cookie
Initializing main memory
Sizing NVRAM
Initializing PCI subsystem
Exiting init
c2801 processor with 393216 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
flash: CompactFlash not present.
Initializing cache
Reset IO
Enabling interrupts
Reading cookie
Sizing NVRAM
Exiting init
rommon 1 > meminfo
Current Memory configuration is:
Onboard SDRAM: Size = 128 MB : Start Addr = 0x10000000
-----Bank 0 128 MB
-----Bank 1 0 MB
Dimm 0: Size = 256 MB : Start Addr = 0x00000000
-----Bank 0 128 MB
-----Bank 1 128 MB
Main memory size: 384 MB in 64 bit mode.
Available main memory starts at 0xa0015000, size 393132KB
Smart Init is enabled.
NVRAM size: 191KB
Na het invoeren van het boot commando krijg ik dit:
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
program load complete, entry point: 0x8000f000, size: 0x2e596f4
Stack pointer : 0x87FFFF80
monstack : 0x8000EFC0
monra : 0xBFC01664
edata : 0x80014E00
magic : 0xFEEDFACE
memsize : 0x08000000
uncomp_size : 0x060B24C8
comp_size : 0x02E538DD
STACK_BYTES : 0x00008000
COPY_CODE_BUF : 0x00000800
_end : 0x8003D6A0
comp_checksum : 0x01301571
uncomp_checksum : 0xC1CD2B95
Self decompressing the image : #################################################
############################################ [OK]
[.....] hoop debug info[.....]
En dan een reset.
Volgens Cisco.com:
1. A "wrong system software" message is displayed when a router attempts to boot an incorrect image. In this case, the router is being booted from the ROM monitor.
Beetje raar. Het heeft gewoon gewerkt met deze versie.
Maar het schijnt iets met de cookie te maken te hebben?
Iemand enig idee hoe dit op te lossen??? help :)
[ Voor 4% gewijzigd door Ducktape op 26-09-2008 18:31 ]
  • Leon T
Leon T
Ni!
Op deze link wordt precies uitgelegd wat je moet doen.
  • Ducktape
Ja die had ik al gevonden. Alleen:
Cisco 1600 Series, Cisco 2500 Series, Cisco 4500 Series
en ik heb geen CCO account om dat cookie te downloaden.
Maar kan het cookie corrupt raken? Waarom werkt het in een keer niet meer?
heb nog dit gevonden: http://www.ciscohq.com/fo...01-boot-problem-1205.html
wss heb ik het cf kaartje te vroeg verwijderd.
[ Voor 25% gewijzigd door Ducktape op 27-09-2008 08:10 ]
  • Ducktape
ok ik ben er waarschijnlijk uit.
De eerste regel van het cookie is beschadigd.
Nu moet ik alleen nog even de cookie opnieuw in zien te voeren. Iemand idee of dit softwarematig kan? Op de PCB zit een JTAG aansluiting. Die maar eens proberen?
Iemand ervaring met cookies?
  • Equator
  • Laatst online: 15:31
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Ik vind dit nou niet echt een PNS probleem.. Move naar Netwerken
