Server 2008 Group policy problemen
Op een Windows 2008 Server die functioneerd als domain controller Server krijg ik steeds de volgende melding:
Log Name: System
Source: Microsoft-Windows-GroupPolicy
Date: 9/18/2008 7:37:59 AM
Event ID: 1128
Task Category: None
Level: Warning
Keywords:
User: SYSTEM
Description:
The Group Policy Client Side Extension Security may have caused the Group Policy Service to terminate unexpectedly. To prevent further failures in the Group Policy Service, this extension has been temporarily disabled until after the next system restart. Group Policy settings managed by this extension may no longer be enforced until the system is restarted. The vendor of this extension should be contacted if this issue recurs.
Ik kan hier geen oplossing voor vinden.
Wat heb ik gecontroleerd/geprobeerd/gevonden:
Sysvol is geshared
Microsoft zegt hier het volgende over.
Eventid.net zegt hier niks over.
Google geeft ook niet het gewenste resultaat
DCdiag output
Doing primary tests
Starting test: DFSREvent
There are warning or error events within the last 24 hours after the
SYSVOL has been shared. Failing SYSVOL replication problems may cause
Group Policy problems.
......................... servername01 failed test DFSREvent
Starting test: SystemLog
An Warning Event occurred. EventID: 0x00000468
Time Generated: 09/18/2008 07:12:39
EvtFormatMessage failed, error 15100 The resource loader failed to f
ind MUI file..
(Event String (event log = System) could not be retrieved, error
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:17:43
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:22:47
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:27:51
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:32:55
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:37:59
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:43:04
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:48:08
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:53:12
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 07:58:16
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
Time Generated: 09/18/2008 08:03:20
ind MUI file..
0x3afc)
ind MUI file..
0x3afc)
LocatorCheck
[ Voor 28% gewijzigd door Verwijderd op 18-09-2008 08:33 ]
  • Zoetjuh
  • Laatst online: 10-01-2024
Wat is het resultaat van rsop.msc vs het geplande policy-resultaat?
Heb je verder additionele policy-templates ingeladen?
Ik zou vermoeden dat je dan toch zo ziet welke policy voor het probleem zorgt.
Zoetjuh schreef op donderdag 18 september 2008 @ 08:33:
Als ik rsop.msc draai zie ik het volgende
Daci failed:
Thursday, September 18, 2008 9:00:27 AM
Daci failed due to the error listed below.
An attempt was made to load a program with an incorrect format.
Security failed:
Security failed due to the error listed below.
Hoe kan ik nu achterhalen welke gpo een probleem veroorzaakt ?
ja ik heb aan bepaalde ou's policy's gekoppeld
[ Voor 41% gewijzigd door Verwijderd op 18-09-2008 09:23 ]
  • alt-92
alt-92
ye olde farte
Verwijderd schreef op donderdag 18 september 2008 @ 08:41:
Gpresult -v draaien lijkt me ook wel handig, desnoods leg je via gpmc de resultaten daarvan naast je modeling uitdraai.
alt-92 schreef op donderdag 18 september 2008 @ 14:56:
De foutmelding lijkt me niet te komen door een verkeerde gpo policy instelling?
Wat kan ik opmaken uit de gpresult.
GPO: Default Domain Controllers Policy
Policy: ShutdownPrivilege
Computer Setting: Administrators
Backup Operators
Server Operators
Print Operators
Policy: AuditPrivilege
Computer Setting: LOCAL SERVICE
NETWORK SERVICE
Policy: InteractiveLogonRight
Backup Operators
Account Operators
Server Operators
Print Operators
Policy: CreatePagefilePrivilege
Policy: BatchLogonRight
Computer Setting: IIS_IUSRS
DYNAMIEK\SQLServer2005MSSQLUser$DYNAMIEK01$DE
SKTOPAUTHORITY
Administrators
Backup Operators
Performance Log Users
Policy: NetworkLogonRight
Computer Setting: Everyone
Administrators
Authenticated Users
ENTERPRISE DOMAIN CONTROLLERS
Pre-Windows 2000 Compatible Access
Policy: SystemProfilePrivilege
Policy: RemoteShutdownPrivilege
Server Operators
Policy: BackupPrivilege
Backup Operators
Server Operators
Policy: EnableDelegationPrivilege
Policy: UndockPrivilege
Policy: SystemEnvironmentPrivilege
Policy: LoadDriverPrivilege
Print Operators
Policy: IncreaseQuotaPrivilege
NETWORK SERVICE
Administrators
SKTOPAUTHORITY
Policy: ProfileSingleProcessPrivilege
Policy: AssignPrimaryTokenPrivilege
NETWORK SERVICE
SKTOPAUTHORITY
Security Options
GPO: Default Domain Policy
Policy: PasswordComplexity
Computer Setting: Not Enabled
Policy: ClearTextPassword
Policy: ForceLogoffWhenHourExpire
Policy: RequireLogonToChangePassword
Policy: LSAAnonymousNameLookup
Policy: TicketValidateClient
Computer Setting: Enabled
Policy: @wsecedit.dll,-59059
ValueName: MACHINE\System\CurrentControlSet\Control\Lsa\
LmCompatibilityLevel
Computer Setting: 3
Policy: @wsecedit.dll,-59013
ValueName: MACHINE\System\CurrentControlSet\Services\NTD
S\Parameters\LDAPServerIntegrity
Computer Setting: 1
Policy: @wsecedit.dll,-59043
ValueName: MACHINE\System\CurrentControlSet\Services\Lan
ManServer\Parameters\RequireSecuritySignature
Computer Setting: 1
Policy: @wsecedit.dll,-59044
ManServer\Parameters\EnableSecuritySignature
Computer Setting: 1
Policy: @wsecedit.dll,-59058
NoLMHash
Computer Setting: 1
Policy: @wsecedit.dll,-59018
ValueName: MACHINE\System\CurrentControlSet\Services\Net
logon\Parameters\RequireSignOrSeal
Computer Setting: 1
Event Log Settings
N/A
Restricted Groups
N/A
System Services
N/A
Registry Settings
N/A
File System Settings
N/A
Public Key Policies
N/A
Administrative Templates
N/A
USER SETTINGS
CN=Clooser.nl,CN=Users,DC=dynamiek,DC=dynamiek,DC=nu
Last time Group Policy was applied: 9/18/2008 at 7:31:58 PM
Group Policy was applied from: dynamiek01.dynamiek.dynamiek.nu
Group Policy slow link threshold: 500 kbps
Domain Name: DYNAMIEK
Domain Type: Windows 2000
Applied Group Policy Objects
Local Group Policy
The following GPOs were not applied because they were filtered out
Filtering: Not Applied (Empty)
The user is a part of the following security groups
Domain Users
Everyone
BUILTIN\Administrators
Remote Desktop Users
BUILTIN\Users
Certificate Service DCOM Access
BUILTIN\Pre-Windows 2000 Compatible Access
REMOTE INTERACTIVE LOGON
NT AUTHORITY\INTERACTIVE
NT AUTHORITY\Authenticated Users
This Organization
LOCAL
Domain Admins
Group Policy Creator Owners
Enterprise Admins
Schema Admins
Denied RODC Password Replication Group
High Mandatory Level
The user has the following security privileges
Bypass traverse checking
Manage auditing and security log
Back up files and directories
Restore files and directories
Change the system time
Shut down the system
Force shutdown from a remote system
Take ownership of files or other objects
Debug programs
Modify firmware environment values
Profile system performance
Profile single process
Increase scheduling priority
Load and unload device drivers
Create a pagefile
Adjust memory quotas for a process
Remove computer from docking station
Perform volume maintenance tasks
Impersonate a client after authentication
Create global objects
Change the time zone
Create symbolic links
Enable computer and user accounts to be trusted for delegation
Increase a process working set
Add workstations to domain
Resultant Set Of Policies for User
Software Installations
N/A
Logon Scripts
Logoff Scripts
GPO: Local Group Policy
Parameters:
LastExecuted: This script has not yet been executed.
Public Key Policies
N/A
N/A
Folder Redirection
N/A
Internet Explorer Browser User Interface
N/A
Internet Explorer Connection
N/A
Internet Explorer URLs
N/A
Internet Explorer Security
N/A
Internet Explorer Programs
N/A
  • alt-92
alt-92
ye olde farte
Nou, dan maar even zo (aangezien alleen lange lijstjes met output posten zonder er ook zelf naar te kijken weinig nut heeft)..
Je krijgt een CSE foutmelding.
Dan ga je kijken welke GPO CSE enabled is, en schakel je die tijdelijk uit.
Lijkt me niet dat we voor jou moeten gaan troubleshooten, dat mag je gerust zelf doen.
Na het disableen van diverse policies heb alle zelf aangemaakte group policies verwijderd.
Hierna de default group policies gerestored via de volgende optie: dcgpofix /target:both
Toch blijft de melding terugkomen, heeft iemand nog een idee ?
[ Voor 11% gewijzigd door Verwijderd op 24-09-2008 12:13 ]
nog iemand een idee ?
  • Koffie
  • Laatst online: 21:39
Koffie
Koffiebierbrouwer
Braaimeneer
Move PNS > WSS
Braaikamer - Smoke&BBQ - Huis
Ook hier niemand ?
