• jonaskellens
  • Laatst online: 30-05-2011
ik wil een directory kopiëren van de server 'poseidon' naar een andere server 'newposeidon'.
Ik log in op de remote server via ssh, geen enkel probleem. Dan wil ik via rcp iets kopïeren...
[root@poseidon root]# scp -vrp root@192.168.2.2:/var/tomcat5/webapps root@192.168.4.8:/var/tomcat5
Executing: /usr/bin/ssh -v -x -o'ClearAllForwardings yes' -n -l root 192.168.2.2 scp -v -r -p /var/tomcat5/webapps 'root@192.168.4.8:/var/tomcat5'
OpenSSH_3.4p1, SSH protocols 1.5/2.0, OpenSSL 0x0090602f
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug1: Rhosts Authentication disabled, originating port will not be trusted.
debug1: ssh_connect: needpriv 0
debug1: Connecting to 192.168.2.2 [192.168.2.2] port 22.
debug1: Connection established.
debug1: identity file /root/.ssh/identity type -1
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: Remote protocol version 1.99, remote software version OpenSSH_3.4p1
debug1: match: OpenSSH_3.4p1 pat OpenSSH*
Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_3.4p1
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug1: dh_gen_key: priv key bits set: 129/256
debug1: bits set: 1556/3191
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Host '192.168.2.2' is known and matches the RSA host key.
debug1: Found key in /root/.ssh/known_hosts:37
debug1: bits set: 1633/3191
debug1: ssh_rsa_verify: signature correct
debug1: kex_derive_keys
debug1: newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: waiting for SSH2_MSG_NEWKEYS
debug1: newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: done: ssh_kex2.
debug1: send SSH2_MSG_SERVICE_REQUEST
debug1: service_accept: ssh-userauth
debug1: got SSH2_MSG_SERVICE_ACCEPT
debug1: authentications that can continue: publickey,password,keyboard-interactive
debug1: next auth method to try is publickey
debug1: try privkey: /root/.ssh/identity
debug1: try privkey: /root/.ssh/id_rsa
debug1: try privkey: /root/.ssh/id_dsa
debug1: next auth method to try is keyboard-interactive
debug1: next auth method to try is password
root@192.168.2.2's password:
...ik tik het correcte password in...
debug1: ssh-userauth2 successful: method password
debug1: fd 4 setting O_NONBLOCK
debug1: channel 0: new [client-session]
debug1: send channel open 0
debug1: Entering interactive session.
debug1: ssh_session2_setup: id 0
debug1: Sending command: scp -v -r -p /var/tomcat5/webapps root@192.168.4.8:/var/tomcat5
debug1: channel request 0: exec
debug1: channel 0: open confirm rwindow 0 rmax 32768
debug1: channel 0: read<=0 rfd 4 len 0
debug1: channel 0: read failed
debug1: channel 0: close_read
debug1: channel 0: input open -> drain
debug1: channel 0: ibuf empty
debug1: channel 0: send eof
debug1: channel 0: input drain -> closed
Executing: program /usr/bin/ssh host 192.168.4.8, user root, command scp -v -r -p -t /var/tomcat5
debug1: Connecting to 192.168.4.8 [192.168.4.8] port 22.
debug1: Remote protocol version 2.0, remote software version OpenSSH_4.7
debug1: match: OpenSSH_4.7 pat OpenSSH*
debug1: dh_gen_key: priv key bits set: 136/256
debug1: bits set: 1048/2048
debug1: Host '192.168.4.8' is known and matches the RSA host key.
debug1: Found key in /root/.ssh/known_hosts:38
debug1: bits set: 1010/2048
debug1: authentications that can continue: publickey,gssapi-with-mic,password
Permission denied, please try again.
debug1: no more auth methods to try
Permission denied (publickey,gssapi-with-mic,password).
debug1: Calling cleanup 0x80674b0(0x0)
lost connection
debug1: channel 0: rcvd eof
debug1: channel 0: output open -> drain
debug1: channel 0: obuf empty
debug1: channel 0: close_write
debug1: channel 0: output drain -> closed
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug1: channel 0: rcvd close
debug1: channel 0: almost dead
debug1: channel 0: gc: notify user
debug1: channel 0: gc: user detached
debug1: channel 0: send close
debug1: channel 0: is dead
debug1: channel 0: garbage collecting
debug1: channel_free: channel 0: client-session, nchannels 1
debug1: Transferred: stdin 0, stdout 0, stderr 0 bytes in 0.2 seconds
debug1: Bytes per second: stdin 0.0, stdout 0.0, stderr 0.0
debug1: Exit status 1
De foutmelding dus :
En ik snap niet wat er mis is...
  • Kees
  • Laatst online: 19:05
Kees
Serveradmin / BOFH / DoC
Ik neem aan dat de wachtwoorden voor de verschillende servers niet hetzelfde zijn? Of krijg je twee password prompts? Het lijkt erop dat hij het wachtwoord dat je in eerste instantie opgeeft ook wil gebruiken voor de tweede server. Of dat op de tweede server rootlogins uitstaan.
Gaat het wel goed als je van server1 naar lokaal kopieert, en dan van lokaal naar server2?
  • jonaskellens
De wachtwoorden zijn op beide servers hetzelfde.
Maar dat zou geen rol mogen spelen, hij moet normaal gezien 2 maal om een paswoord vragen. Echter reeds bij het eerste paswoord loopt het fout.
Voor alle duidelijkheid :
ik ben lokaal ingelogd op newposeidon.
Ik meld me via ssh aan op poseidon. (dat lukt)
Vanop poseidon wil ik kopiëren naar newposeidon.
(newposeidon staat op m'n bureau, poseidon staat in de server-ruimte)
[ Voor 9% gewijzigd door jonaskellens op 01-09-2008 12:12 ]
  • Kettrick
  • Laatst online: 22:16
Kettrick
Rantmeister!
Je geeft nu twee remote locaties op, als je bent ingelogd op de nieuwe server kan (moet) je 2e parameter een lokaal pad zijn.
  • jonaskellens
RoeLz schreef op maandag 01 september 2008 @ 12:12:
Inderdaad... bedankt, nu lukt het. Stom dat ik 2 maal inlog op dezelfde server....
