[opensuse11.0] Brandt niet goed op CD/DVD-writer
  • 150 views
  • huijaa
  • Laatst online: 20-05-2024
Ik heb een brandprobleem (K3b) met mijn linuxbak OpenSuSE 11.0 64bits. Het brandt wel, maar leest het niet. Aan de IDE wordt Samsung TSSTcorp CD/DVDW SH-S182M gekoppeld als /dev/sr0
Hoe moet er dit probleem opgelost worden? Voorbaat dank.
# hwinfo
27: udi = '/org/freedesktop/Hal/devices/storage_model_CD/DVDW_SH_S182M'
block.is_volume = false
org.freedesktop.Hal.Device.Storage.method_signatures = { 'as', 'as' }
storage.bus = 'scsi'
org.freedesktop.Hal.Device.Storage.method_argnames = { 'extra_options', 'extra_options' }
storage.no_partitions_hint = true
org.freedesktop.Hal.Device.Storage.method_execpaths = { 'hal-storage-eject', 'hal-storage-closetray' }
storage.media_check_enabled = true
storage.automount_enabled_hint = true
info.product = 'CD/DVDW SH-S182M'
resmgr.class = 'cdrom'
storage.drive_type = 'cdrom'
info.udi = '/org/freedesktop/Hal/devices/storage_model_CD/DVDW_SH_S182M'
info.callouts.add = { 'hal-resmgr' }
storage.model = 'CD/DVDW SH-S182M'
info.interfaces = { 'org.freedesktop.Hal.Device.Storage', 'org.freedesktop.Hal.Device.Storage', 'org.freedesktop.Hal.Device.resmgr', 'org.freedesktop.Hal.Device.Storage.Removable' }
storage.vendor = 'TSSTcorp'
info.vendor = 'TSSTcorp'
org.freedesktop.Hal.Device.resmgr.method_names = { 'Grant', 'Revoke' }
org.freedesktop.Hal.Device.resmgr.method_signatures = { '', '' }
storage.firmware_version = 'SB03'
org.freedesktop.Hal.Device.resmgr.method_argnames = { '', '' }
storage.cdrom.write_speeds = { }
storage.lun = 0 (0x0)
org.freedesktop.Hal.Device.resmgr.method_execpaths = { 'hal-resmgr-grant', 'hal-resmgr-revoke' }
storage.originating_device = '/org/freedesktop/Hal/devices/computer'
linux.hotplug_type = 3 (0x3)
storage.removable.support_async_notification = false
storage.removable.media_available = false
storage.cdrom.cdr = true
storage.removable = true
info.addons = { 'hald-addon-storage' }
storage.cdrom.cdrw = true
storage.size = 0ull (0x0ull)
info.category = 'storage'
storage.cdrom.dvd = true
storage.hotpluggable = false
info.capabilities = { 'storage', 'block', 'storage.cdrom' }
storage.requires_eject = true
storage.cdrom.dvdr = true
storage.cdrom.dvdrw = true
storage.removable.media_size = 4700372992ull (0x1182a0000ull)
storage.cdrom.dvdram = true
storage.partitioning_scheme = ''
storage.cdrom.dvdplusr = true
block.storage_device = '/org/freedesktop/Hal/devices/storage_model_CD/DVDW_SH_S182M'
storage.cdrom.dvdplusrw = true
storage.cdrom.dvdplusrwdl = false
storage.cdrom.dvdplusrdl = true
storage.cdrom.bd = false
storage.cdrom.bdr = false
storage.cdrom.bdre = false
storage.cdrom.hddvd = false
storage.cdrom.hddvdr = false
storage.cdrom.hddvdrw = false
storage.cdrom.mo = false
storage.cdrom.mrw = true
storage.cdrom.mrw_w = true
linux.sysfs_path = '/sys/devices/pci0000:00/0000:00:0f.1/host1/target1:0:1/1:0:1:0/block/sr0'
storage.cdrom.support_media_changed = true
info.parent = '/org/freedesktop/Hal/devices/pci_1106_571_scsi_host_0_scsi_device_lun0'
storage.cdrom.support_multisession = true
block.device = '/dev/sr0'
storage.cdrom.read_speed = 11080 (0x2b48)
block.major = 11 (0xb)
storage.cdrom.write_speed = 0 (0x0)
block.minor = 0 (0x0)
org.freedesktop.Hal.Device.Storage.method_names = { 'Eject', 'CloseTray' }
since 21aug'04: Asus K8VSE Deluxe, AMD Athlon 64 3400+, Twimos 1 GB PC3200, Maxtor U133/7200 160GB+120GB, Asus V9999GE and SunBeam Aryclic Case
  • sam.vimes
  • Laatst online: 30-05 11:33
huijaa schreef op woensdag 27 augustus 2008 @ 15:13:
(hwinfo output gesnipt)
Het is niet duidelijk wat je probleem is. Beschrijf:
  • wat deed je?
  • wat verwachtte je?
  • wat gebeurde in plaats daarvan?
Zonder die informatie kunnen de collega-tweakers niet zoveel.
  • zomertje
  • Laatst online: 17-02 12:22
zomertje
Barisax knorretje
Met zo'n startpost kunnen we inderdaad niet zoveel. We verwachten wat eigen inzet en als je gezocht hebt dan is het handig om te vermelden wat je al geprobeerd hebt of tenminste foutmeldingen.
Op deze manier gaat ie in ieder geval dicht.
het ultieme jaargetijde.... | #!/usr/bin/girl | Art prints and fun
