[Ubuntu] Eth0 word constant in- en uitgeschakeld
  • Gehakt
  • Laatst online: 15-10 22:34
Om de een of andere reden word mijn nic constant uitgeschakeld en weer ingeschakeld. Heeft iemand enig idee hoe dit komt en verholpen kan worden?
Moederbord: Abit AB9
Driver:
    via-rhine.c:v1.10-LK1.4.3 2007-03-06 Written by Donald Becker
    via-rhine: Broken BIOS detected, avoid_D3 enabled.
Afbeeldingslocatie: http://images.anandtech.com/reviews/motherboards/abit/ab9pro-preview2/intel965chipset.png
Gehakt@server:~$ cat /var/log/syslog | grep kernel
Aug  6 07:02:54 server kernel: [111339.466146] eth0: link down
Aug  6 07:02:56 server kernel: [111341.773114] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 07:10:12 server kernel: [111777.597112] eth0: link down
Aug  6 07:10:14 server kernel: [111779.892688] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 07:29:35 server kernel: [112939.744005] eth0: link down
Aug  6 07:29:37 server kernel: [112942.050970] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 07:37:17 server kernel: [113401.501813] eth0: link down
Aug  6 07:37:19 server kernel: [113403.808784] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 07:48:24 server kernel: [114068.332187] eth0: link down
Aug  6 07:48:26 server kernel: [114070.829727] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 08:18:07 server kernel: [115850.834965] eth0: link down
Aug  6 08:18:09 server kernel: [115853.140895] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 08:20:52 server kernel: [116015.420883] eth0: link down
Aug  6 08:20:54 server kernel: [116017.715423] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 11:59:20 server kernel: [129118.168223] eth0: link down
Aug  6 11:59:23 server kernel: [129120.724800] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 13:40:46 server kernel: [135201.370904] eth0: link down
Aug  6 13:40:49 server kernel: [135203.737946] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 13:44:09 server kernel: [135403.708822] eth0: link down
Aug  6 13:44:11 server kernel: [135406.027185] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 13:50:53 server kernel: [135807.555384] eth0: link down
Aug  6 13:50:55 server kernel: [135809.862356] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Aug  6 13:51:10 server kernel: [135824.744891] eth0: link down
Aug  6 13:51:12 server kernel: [135827.098466] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
  • Snow_King
  • Laatst online: 03-11 16:59
Snow_King
Konijn is stoer!
Even iets stoms, niet toevallig een kapotte UTP kabel?
  • Gehakt
Had ik ook al aan zitten denken maar ik heb geen idee hoe ik dat ga checken.
Het is een kabel ik recent door een nogal nauw gat naar de kelder heb getrokken.
Makkelijkste manier om te checken die mij nu te binnen schiet is om de pc met een gekochte kabel direct aan de router te hangen en dan te kijken of het over is?
Nog andere suggesties waar ik aan zou kunnen denken?
  • Vicarious
  • Laatst online: 24-06-2024
Vicarious
☑Rekt | ☐ Not rekt
Ja, gewoon in een andere router of switch prikken. Die hoeft niet eens te werken, zolang hij maar link levert. En dan kijken of hij nog steeds klappert. Je router/switchpoortje kan ook kapot zijn namelijk...
Vicariously I live while the whole world dies
  • Gehakt
Ik heb mijn macbook er direct aangehangen met een crosskabel die uit de winkel komt. Vervolgens een iso van 500mb overgepompt en een aantal minuten ping berichten verstuurd.
De verbinding werd niet uit en ingeschakeld dus ook ik vermoed nu dat ik de kabel moet opnieuw moet gaan maken die er ligt.
