Moederbord compatible met geheugen
  • 289 views
ik lees al geruime tijd mee, en kan op alles een antwoord vinden, behalve de volgende vraag.
Een vriend van mij z'n moederbord is gecrasht, deze moet dus worden vervangen. Het gaat hierbij om de volgende: Motherboard specifications table
Part / Feature Specification / Support
Motherboard description Motherboard manufacturer's name: ASUS P5LP-LE
HP/Compaq name: Lithium-UL8E
CPU/Processor Socket: 775
Supports Pentium D (Smithfield) up to 3.2 GHz and Pentium4 (Prescott) up to 580 and 670
System bus 533 MHz, 800 MHz, 1066 MHz
Chipset Northbridge: Intel 945P
Southbridge: Intel I/O Controller Hub 7
BIOS features The mainboard BIOS provides “Plug & Play” BIOS which detects the peripheral devices and expansion cards of the board automatically
The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications
Form factor Micro-ATX: 9.6 in X 9.6 in
Memory Four 240-pin DDR2 DIMM sockets
Supports PC2 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs
Supports 1.8v DDR2 SDRAM
Maximum HP/Compaq approved memory is 4 GB*
NOTE: *Actual available memory may be less
Expansion slots One PCI Express x16 graphics
Three PCI
Video graphics External only
Serial ATA 4 SATA connectors
Each connector supports 1 serial ATA-150 disk drive
Onboard audio or audio card Integrated Intel High Definition (TM) audio (Azalia)
Realtek ALC 882 CODEC
THX certification support
8-channels for Full Dolby 5.1/6.1/7.1 surround sound support with Dolby Pro Logic IIx
Onboard LAN Intel 82562GT
10/100 Mbps Fast Ethernet
Back panel I/0 One PS/2 keyboard
One PS/2 mouse
One Parallel
One IEEE 1394
One RJ-45 networking port
Four USB 2.0
One coaxial SPDIF in
One coaxial SPDIF out
Six audio connectors: side speaker out, rear speaker out, center/subwoofer, line in, line out, and microphone
Internal connectors One floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
One IDE
One 24-pin ATX power
One 4-pin ATX 12 V power
Four serial ATA
Four USB 2.0 ports on two connectors
Two internal audio
One front headphone and microphone
One IEEE 1394a
One CPU fan
One system (chassis) fan
(http://h10025.www1.hp.com...n&product=1815537&lang=en)
Hier heeft hij twee geheugenbankjes van 524MB PC2 4200 DDR2 bankjes in zitten. Ook heeft hij hierop de standaard processor. Deze bankjes + processor wil hij gewoon kunnen overzetten op z'n nieuwe moederbord, om het zo goedkoop mogelijk te houden :P
Mijn vraag aan jullie: Passen deze componenten op de volgende moederboarden (staat wel 533MHZ, maar staat dit gegarandeerd gelijk voor PC2 4200)?
http://www.komplett.nl/k/ki.aspx?sku=345597
http://azerty.nl/8-89-35622/946gz7ma-8ks2h.html
Mochten jullie zelf er nog een hebben, dan wel mATX, met PCI express 16x, en uiteraard de DDR2 en ondersteuning van de PC2 4200, socket 775, laat het weten! Hoeft absoluut geen snelle of overclockte te zijn.
Als je de Pentium D CPU houdt moet het gewoon kunnen. ;)
Maar heb je voor de grap al eens gekeken op de site van de mobo fabrikant.
Edit: Welkom op GoT. :w
Misschien handig dat je voordat je een topic opent even de FAQ's door leest. Een topic maken kost namelijk meer moeite dan dit zelf opzoeken op de site van de fabrikant. ;)
[ Voor 83% gewijzigd door Verwijderd op 04-08-2008 19:55 ]
Bedankt!
Heb gekeken op de sites v/d fabrikanten, maar ze vermelden niet specifiek of het PC2 4200 geheugen aankan. Wilde het toch even zeker weten.
  • gambieter
gambieter
Just me & my cat
Asus heeft QVL lijsten voor geheugen en chips, zie de FAQ. Verder gewoon de manual doorlezen :) .
  • dion_b
  • Laatst online: 13:12
dion_b
say Baah
Los van het QVL verhaal staat duidelijk genoeg in het beleid van dit subforum dat een waslijst aan uitdraai van een of ander tooltje iets anders is dan een gedegen topicstart en dat we daar niet vrolijk van worden. Een topicstart hoort eigen inzet te bevatten, niet blaat van een apparaat waar je niets van begrijpt.
Oslik, blyat! Oslik!
