Ftp server probleem (dynamic ip)
hi ppl
just had an question about the ftp server g6...
i installed the prog. and it work's fine but if somebody is in and dl then when the ip change's (DHCP) the can't go on.
How can i fix this problem so anybody can log on to it even when the ip changes.
(excuse the english)
Tnx in advance
ShArKeY
  • Mar
  • Registratie: September 1999
  • Laatst online: 26-05-2025
Mar
TCF
in de menu go to Setup, Main, Dynamic IP
:P
DPC Team ColdFusion
ok i already got that but then i have to phone my friend everytime the ip changes.....
so that doesn't help much to or not??
but Tnx anyway
ShArKeY
Probably you're out of luck. It's either calling or getting a fixed-ip line.
a fixed-ip line???
how does that work???
ShArKeY
  • BitByter
  • Registratie: Juli 1999
  • Laatst online: 13-08 07:38
BitByter
Prutst dit forum
goto www.dhs.org
you can get a fixed host on internet
if you're computer gets another ip adress
a client will upload you're ip address
immediately, so you're friends can always connect to ftp://blabla.dyn.dhs.org
if you're computer changes of ip adress, they'll have to reconnect only,
  • Hazzz-E
  • Laatst online: 11-09-2025
Hazzz-E
Que?
neen, http://www.yi.org/
(en wat een verschrikkelijk brak engels wordt hier gesproken - allemaal nederlandse windows-gebruikers i presume? :))
  • jvdmeer
  • Laatst online: 16:31
Laat ik er ook maar 1 toevoegen:
http://www.dyndns.org/
  • violator_
  • Laatst online: 19-01 01:18
All the above options are indeed very usable for your kind of purpose. dhs.org is probably the best option as it is for free and reliable. If you however want to link a straight .com .net .org .nl etc. domain name to your host , you can link the .com for instance to your dhs address , which will dynamically refer to your actual IP address which you have at that moment. This way you can run a steady web server even with a modem connection (not that anybody would want this .. ) 8-)
Zwei Dinge sind unendlich, das Universum und die menschliche Dummheit, aber beim Universum bin ich mir nicht ganz sicher. -Albert Einstein
