[PHP/XML] - Weergeven van specifieke node *
  • bakakaizoku
  • Laatst online: 26-10 20:24
Voor een pagina heb ik een volgende XML file:
XML:
<content>
    <pagetitle>Recente Projecten</pagetitle>
    <blok titel="Blok titel" datum="Donderdag 24 juli 2008" id="1">
        <intro><p>Lorem Ipsum is simply dummy text of the printing and typesetting industry. Lorem Ipsum has been the industry's standard dummy text ever since the 1500s, when an unknown printer took a galley of type and scrambled it to make a type specimen book.</p>
               <p>It has survived not only five centuries, but also the leap into electronic typesetting, remaining essentially unchanged. It was popularised in the 1960s with the release of Letraset sheets containing Lorem Ipsum passages, and more recently with desktop publishing software like Aldus PageMaker including versions of Lorem Ipsum.</p>
        </intro>
        <tekst><p>Contrary to popular belief, Lorem Ipsum is not simply random text. It has roots in a piece of classical Latin literature from 45 BC, making it over 2000 years old. Richard McClintock, a Latin professor at Hampden-Sydney College in Virginia, looked up one of the more obscure Latin words, consectetur, from a Lorem Ipsum passage, and going through the cites of the word in classical literature, discovered the undoubtable source. Lorem Ipsum comes from sections 1.10.32 and 1.10.33 of "de Finibus Bonorum et Malorum" (The Extremes of Good and Evil) by Cicero, written in 45 BC. This book is a treatise on the theory of ethics, very popular during the Renaissance. The first line of Lorem Ipsum, "Lorem ipsum dolor sit amet..", comes from a line in section 1.10.32.</p>
               <p>The standard chunk of Lorem Ipsum used since the 1500s is reproduced below for those interested. Sections 1.10.32 and 1.10.33 from "de Finibus Bonorum et Malorum" by Cicero are also reproduced in their exact original form, accompanied by English versions from the 1914 translation by H. Rackham.</p>
        </tekst>
    </blok>
    <blok titel="Lorem Ipsum" datum="Donderdag 24 juli 2008" id="2">
        </intro>
        <tekst><p>Jwt. Contrary to popular belief, Lorem Ipsum is not simply random text. It has roots in a piece of classical Latin literature from 45 BC, making it over 2000 years old. Richard McClintock, a Latin professor at Hampden-Sydney College in Virginia, looked up one of the more obscure Latin words, consectetur, from a Lorem Ipsum passage, and going through the cites of the word in classical literature, discovered the undoubtable source. Lorem Ipsum comes from sections 1.10.32 and 1.10.33 of "de Finibus Bonorum et Malorum" (The Extremes of Good and Evil) by Cicero, written in 45 BC. This book is a treatise on the theory of ethics, very popular during the Renaissance. The first line of Lorem Ipsum, "Lorem ipsum dolor sit amet..", comes from a line in section 1.10.32.</p>
        </tekst>
    </blok>
</content>
Deze render ik met PHP dmv:
PHP:
            $xslt = new XSLTProcessor();
            $xsl = new DOMDocument();
            $xsl->load($layout);
            $xslt->importStylesheet($xsl);
            $xml = new DOMDocument();
            $xml->preserveWhiteSpace = false;
            $xml->load($files_path.'content.xml');
            $xsl_output = $xslt->transformToXML($xml);
Dit gaat perfect zoals ik het wil. $layout bevat de path naar een xsl file. Een pagina *kan* 2 xsl files hebben, een layout.xsl en een item.xsl. Layout.xsl bevat de styling voor de hele XML file, en item.xsl bevat de styling voor 1 item. Op basis van een $_GET parameter wordt er bepaald welke XSL file er moet worden geladen. Voorbeeld:
index.php
- content.xml
- layout.xsl
index.php?show=2
- content.xml
- item.xsl
Zoals je al kan begrijpen wil ik dus wanneer $_GET['show'] geset is, hij alleen het <blok/> met desbetreffend ID laat zien. Wat is hiervoor de PHP/XSL oplossing welke ik in bovenstaande code zou kunnen integreren?
rm -rf ~/.signature
  • TeeDee
  • Laatst online: 27-10 23:19
TeeDee
CQB 241
De lompe oplossing:
Met een substring-after, een stukje javascript om de url op te zoeken, kan je in ieder geval al aan de parameter komen. Vervolgens dit combineren met een standard test om de parameter uit te lezen (evt. in combinatie met een for-each).
Uit mijn hoofd is er ook nog zoiets als request-param.
En als laatste redmiddel: Google.
* TeeDee vraagt zich trouwens ook af of dit niet in PHP te regelen is. Desnoods geef je de parameter mee via php.
[ Voor 11% gewijzigd door TeeDee op 29-07-2008 15:17 ]
Heart..pumps blood.Has nothing to do with emotion! Bored
  • foliant
  • Laatst online: 19-01-2022
Je kunt parameters gebruiken in XSLT (xsl:param).
De parameter is dan mee te geven m.b.v http://nl.php.net/manual/en/xsltprocessor.setparameter.php
  • r0bert
  • Laatst online: 11-08 16:19
Dynamische includes in XSLT lijkt me moeilijk. Ik pak het dan meestal andersom aan. Ik laat 'layout.xsl' c.q. 'item.xsl' het bestand 'content.xml' includen, aangezien dat statisch is.
Een ander alternatief zou zijn om via PHP DOM je XSLT stylesheet te veranderen (je mag alternatief ook een <?xml-stylesheet?> in je XML DOM invoegen geloof ik).
  • bakakaizoku
foliant schreef op dinsdag 29 juli 2008 @ 15:24:
Dat heeft het bij mij opgelost, bedankt!
PHP:
PHP:
            if (isSet($_GET['show'])) {
                $xslt->setParameter('','showID',$_GET['show']);
XSL (test code):
<xsl:param name="showID" />
<xsl:template match="/">
    <p>ID: <xsl:value-of select="$showID" /></p>
    {$showID}
    <xsl:for-each select="content/blok">
        <xsl:if test="$showID=@id">
            <p><xsl:value-of select="@titel" /></p>
        </xsl:if>
    </xsl:for-each>
rm -rf ~/.signature
