burn proces faild ?
  • 333 views
sinds kort heb ik vaker (dus niet altijd) dat het brand proces niet goed word geëindigd en krijg dit onderstaand log report, heeft iemand een idee ?
MvrGr. Marcel
1A23-0809-4130-2465-1377-1050
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26-10-2004 18:35:34
Nero Version: 6.6.0.18
Internal Version: 6, 6, 0, 18e
(Nero Express)
Recorder: <TSSTcorp CD/DVDW SH-S182M>Version: SB04 - HA 4 TA 4 - 6.6.0.18
Adapter driver: <viamraid> HA 4
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <PIONEER DVD-RW DVR-112D>Version: 1.15 - HA 0 TA 0 - 6.6.0.18
Adapter driver: <atapi> HA 0
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-RW DVR-112D atapi Port 0 ID 0 DMA: On
DiskPeripheral : SAMSUNG HD753LJ atapi Port 1 ID 0 DMA: On
DiskPeripheral : Maxtor 6V250F0 atapi Port 1 ID 1 DMA: On
DiskPeripheral : WDC WD1200JD-00FYB0 atapi Port 2 ID 0 DMA: On
DiskPeripheral : SAMSUNG HD753LJ atapi Port 2 ID 1 DMA: On
CdRomPeripheral : TSSTcorpCD/DVDW SH-S182MSB04 viamraid Port 4 ID 4 DMA: Off
CdRomPeripheral : SCSIVAX DVD/CD-ROM 2.7a Vax347s Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-112D P: CDRom1
TSSTcorp CD/DVDW SH-S182M S: CDRom0
SCSIVAX DVD/CD-ROM V: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2096300kB)
Free physical memory: 1316MB (1348096kB)
Memory in use : 35 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.7.2008
DVD snelkopiëren (on-the-fly)
21:08:08 #1 Text 0 File Reader.cpp, Line 127
Reader running
21:08:08 #2 Text 0 File Writer.cpp, Line 122
Writer TSSTcorp CD/DVDW SH-S182M running
21:08:08 #3 Text 0 File DVDCopy.cpp, Line 293
DVD Track-Information from source disc:
Media Type: DVD+R
S01 T01 Con 0x14 Start 0 Len 2154256 (gap 0) Blank 0 Res 1 Dmg 0 Open Trk 0 Mode TRM_DATA_MODE1 (0)
21:08:08 #4 Text 0 File DVDCopy.cpp, Line 406
Max -1 tracks of 1 allowed to copy
1: 0 - 2154256 = 2154256, TRM_DATA_MODE1, block size 2048, read opt 0 (no read options)
21:08:08 #5 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
21:08:08 #6 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2154255 (478:43.30, 4207MB)
21:08:08 #7 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
21:08:08 #8 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: TSSTcorp CD/DVDW SH-S182M, Media type: DVD+R
Disc Manufacturer ID: INFOME, Media Type ID: R30, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
21:08:08 #9 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
21:08:08 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - Data (modus 1))
2 indices, index0 (150) not provided
original disc pos #0 + 2154256 (2154256) = #2154256/478:43.31
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2154256 blocks [TSSTcorp CD/DVDW SH-S182M]
21:08:08 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [TSSTcorp CD/DVDW SH-S182M] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x40; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4411916288, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2154256 | lead-out | 1 | 0x41 | 0x00
21:08:08 #12 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11.080 kB/sec)
21:08:08 #13 SCSI -1066 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 4, TA 4, LUN 0, buffer 0x03A97C00
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0x40 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
21:08:08 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2661
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
21:08:08 #15 Text 0 File Cdrdrv.cpp, Line 8892
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: INFOME..
Media type ID: R30
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 49 4E 46 4F 4D - 45 00 00 52 33 30 00 38 ...INFOME..R30.8
23 54 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 #T..............
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
21:08:08 #16 Text 0 File DVDPlusRW.cpp, Line 659
Start write address at LBA 0
DVD high compatibility mode: Yes
21:16:00 #17 Text 0 File WriterStatus.cpp, Line 116
<TSSTcorp CD/DVDW SH-S182M> start writing Lead-Out at LBA 2154256 (20DF10h), lenght 0 blocks
21:16:00 #18 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
21:16:05 #19 SCSI -500 File Cdrdrv.cpp, Line 1182
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
21:16:09 #20 SCSI -1114 File Cdrdrv.cpp, Line 1182
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x29 0x00
21:16:09 #21 CDR -500 File ThreadedTransferInterface.cpp, Line 1916
SCSI command aborted
TSSTcorp CD/DVDW SH-S182M\H4 T4
21:16:09 #22 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1916
Could not perform end of Disc-at-once
21:16:29 #23 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
21:16:29 #24 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
21:16:29 #25 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11.080 kB/sec)
Existing drivers:
File 'Drivers\viamraid.sys': Ver=5.1.2600.310, size=74112 bytes, created 18-5-2004 10:55:26 (Adapter driver for rec)
File 'Drivers\atapi.sys': Ver=5.1.2600.5512 (xpsp.080413-2108), size=96512 bytes, created 14-4-2008 0:10:32 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  • sjongenelen
  • Laatst online: 04-10 11:53
wow.. dit is echt niet de bedoeling..
wat is je hardware? is er iets veranderd ? wat is je software? is er iets veranderd..?
you had me at EHLO
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
Misschien handig om eerst eens aan te geven wat er nu precies waar fout gaat (en met welke progs je het al hebt geprobeerd). Een compleet errorlog van nero schiet niemand wat mee op. Post alleen de relevante melding eens en zoek hierop ook eens op google. Er staat in dat log niet direct een error waar we iets mee kunnen. Dus iets meer info is wel gewenst.
  • dion_b
  • Laatst online: 01:14
dion_b
say Baah
Een volledige uitdraai van software is niet hetzelfde als een volwaardige topicstart in een hardwaresubforum :o
Sowieso is Overige Hardware geen dumpbak. Neem eens een kijk in Windows Clients en/of Opslagmedia & I/O Controllers - maar lees daar het beleid en de FAQs door voor je post!
Oslik, blyat! Oslik!
