Sub-folders in DVD-menu MediaCenter/
  • 161 views
English (Dutch is further below):
As proparly many people know there is a sort of hidden feature in MediaCenter, it is called DVD. You can have a DVD menu with your dvd movies in it. just to ad a reg key and then ad your dvd's.
the problem that i have with that is this:
I got several DVD's about 100 movies, 10 serie's (some of the serie's with 4 seasons and each have 6 or 7 dvd's), 50 music DVD's. Is there anyway to put a subfolder in the DVD-menu? So I can sort everything out, because now I have approxomaticly 200 DVD's in 1 directory this is not the easiest to search and pick a DVD in mediacenter.
The first and only thing that I try:
I make a folder structure like;
DVD's
---Serie's
...---Lost
......---Season 1
.........---Disk 1
.........---Disk 2
.........---Disk 3
.........---Disk 4
.........---Disk 5
.........---Disk 6
......---Season 2
.........---Disk 1
.........---Disk 2
.........---Disk 3
.........---Disk 4
.........---Disk 5
.........---Disk 6
......---Season 3
.........---Disk 1
.........---Disk 2
.........---Disk 3
.........---Disk 4
.........---Disk 5
.........---Disk 6
......---Season 4
.........---Disk 1
.........---Disk 2
.........---Disk 3
.........---Disk 4
.........---Disk 5
.........---Disk 6
---Movie's
...---ETC........
---Music
...---ETC........
If I ad the folder "DVD", then all the dvd's appear in 1 directory (in MediaCenter).
If I ad every single folder "Serie's", "movie's" and "Music", the also appear in 1 directory (in MediaCenter).
Does somebody have a solution, to make sub categories / folders in the DVD menu feature?
Nederlands:
Zoals waarschijnlijk vele van jullie weten, is er een verborgen menu in MediaCenter. dit menu is om alle DVD bestanden af te spelen die in een bepaalde map staan (video_ts).
nu heeft het altijd goed gewerkt, maar naar mate ik meer dvd's kreeg is het steeds lastiger om 1 dvd uit al die dvd's te zoeken.
is het mogelijk om een subfolder te maken zodat al mijn serie's, movie's en music dvd's in een andere directory staan in MediaCenter?
dit is wat ik heb geprobeerd:
folder structuur gemaakt:
DVD's
---Serie's
...---Lost
......---Season 1
.........---Disk 1
.........---Disk 2
.........---Disk 3
.........---Disk 4
.........---Disk 5
.........---Disk 6
......---Season 2
.........---Disk 1
.........---Disk 2
.........---Disk 3
.........---Disk 4
.........---Disk 5
.........---Disk 6
......---Season 3
.........---Disk 1
.........---Disk 2
.........---Disk 3
.........---Disk 4
.........---Disk 5
.........---Disk 6
......---Season 4
.........---Disk 1
.........---Disk 2
.........---Disk 3
.........---Disk 4
.........---Disk 5
.........---Disk 6
---Movie's
...---ETC........
---Music
...---ETC........
Als ik de folder "DVD's" toevoeg in MediaCenter, dan zoekt die alle mappen op en dan zet die ze allemaal in 1 grote directory. Dan geeft die dus niet de structuur aan zoals in Windows Explorer.
Als ik de losse folder "Serie's", Movie's" en "Music" toevoeg, dan is het exact hetzelfde... (in 1 grote directory, dus niet de folder structure zoals in Windows Explorer).
heeft iemand een oplossing hoe je wel sub folders / sub catogorien kan aanmaken in het DVD menu?
[ Voor 15% gewijzigd door Verwijderd op 11-07-2008 14:35 ]
Hier ben ik ook wel benieuwd naar. Ik ben ook net bezig met een htpc
waarom plaats je in godsnaam je post in het (brak) engels op een nederlands forum?
  • alt-92
alt-92
ye olde farte
Probeer het even opnieuw in dit keer enkel Nederlands? :)
In de Registratievoorwaarden / korte FAQ staat wel zo'n beetje uitgelegd wat we op het forum zo'n beetje verwachten, ook allemaal in het Nederlands.
Daarnaast staan in Windows Clients - Policy de kleinere huisregeltjes voor dit forumonderdeel, waarin je ook terug kan vinden dat het wel zo handig is om in ieder geval te melden welke Windows versie het om gaat.
Een tweetalige post is niet helemaal de bedoeling, gebruik die ruimte liever om te vertellen wat je zelf hebt geprobeerd (zo is er een registry key waarmee je de pad-diepte kan instellen voor het zoeken naar DVD-vobs)?
[ Voor 84% gewijzigd door alt-92 op 11-07-2008 20:16 ]
