[OSX] Mac OSX -update 10.5.4
  • 248 views
  • Armo
  • Laatst online: 01:09
Kreeg net de melding op mijn MacBook Pro dat er een een nieuwe update is beschikbaar, namelijk OSX 10.5.4. In tegenstelling tot de vorige update is deze net zo groot bij mijn beide mashines (zie sig), namelijk; 87,6 MB.
De changelog zit er zo uit:
The 10.5.4 Update is recommended for all users running Mac OS X Leopard and includes general operating system fixes that enhance the stability, compatibility and security of your Mac.
General
* Includes recent Apple security updates.
* Resolves an issue with saving and reopening Adobe Creative Suite 3 files on a remote server.
* Includes additional RAW image support for several cameras.
* Addresses an issue that may result in a partially installed X11 application.
* Improves L2TP VPN client reliability.
AirPort
* Addresses AirPort reliability issues with 5GHz networks.
* Addresses AirPort issues that may result in slower performance in Logic Studio or MainStage.
iCal
* Improves overall iCal reliability for meeting requests, cancellation notices, delegation, and syncing with iPhone.
* Resolves an issue that prevents deleting an iCal event without notifying the creator.
* Addresses an issue in which events in all calendars affect availability. A checkbox now enables information-only calendars to be transparent from free/busy lookups.
* Resolves a UI issue preventing delegated calendars from showing up as a separate window.
* Addresses an issue with copying and pasting attendees from one event to another.
* Resolves an issue in which iCal may not delete events after a specified time interval, even when set to do so in iCal preferences.
* Addresses an issue in which To Dos cannot be marked private.
Safari
* Addresses a potential performance issue when loading secure web pages.
* Resolves issues that may be encountered when accessing secure web pages with client certificates that reside on a smart card.
Spaces and Exposé
* Addresses an issue in which switching from a space with a Finder window keeps the Finder as the active application instead of the application residing in the destination space.
* Fixes an issue in which dragging an application from the list of application assignments in Spaces System Preferences does not assign the application to the desired space.
* Resolves an Exposé issue that may result in only a subset of windows being shown.
Ben hem zelf nu aan het downloaden op zowel mijn Mac Pro als op MBP :)
Dat was inderdaad 4 dagen geleden :)
Al 2 topics over geweest, allebei op slot gegaan .
[ Voor 42% gewijzigd door Verwijderd op 03-07-2008 16:17 ]
  • Daedalus
Daedalus
Moderator Apple Talk
Keep tryin'
Inderdaad, dus deze gaat ook op slot :) Als er specifieke vragen of problemen zijn mag je daarvoor een topic openen.
[ Voor 49% gewijzigd door Daedalus op 03-07-2008 19:05 ]
“You know what I've noticed Hobbes? Things don't bug you if you don't think about them. So from now on, I simply won't think about anything I don't like, and I'll be happy all the time!” | 宇多田ヒカル \o/
