Cisco PIX 501 portforwarding
Ik wil graag enkele poorten forwarden, waaronder 80 naar mijn webserver.
Nu heb dit ingesteld, maar het lijkt niet te werken. Kan iemand eens kijken naar mijn config file?
Wat doe ik niet goed?
Bedankt!
External interface DHCP 195.240.X.X 255.255.240.0
Internal interface 192.168.1.1 255.255.255.0
Server IP: 192.168.1.10
Config:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password
passwd hostname pixfirewall
domain-name local
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list acl_out permit icmp any any
access-list inbound permit icmp any any
access-list inbound permit tcp any host 195.240.X.X eq www
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 195.240.X.X 255.255.255.255 outside
pdm location 195.240.X.X 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 192.168.1.10 195.240.X.X netmask 255.255.255.255 0 0
access-group inbound in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.20-192.168.1.30 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
[ Voor 4% gewijzigd door Verwijderd op 25-06-2008 23:52 ]
  • Vicarious
  • Laatst online: 24-06-2024
Vicarious
☑Rekt | ☐ Not rekt
Je doet hem verkeerd om. Je moet in de static de ip-adressen omdraaien (eerst de externe, daarna de interne)
Vicariously I live while the whole world dies
Okay bedankt!
static (outside,inside) 195.240.X.X 192.168.1.10 netmask 255.255.255.255 0 0
ik heb tevens een no static (inside,outside) 192.168.1.10 195.240.X.X netmask 255.255.255.255 0 0
uitgevoerd maar nog geen forwarding :(
  • Vicarious
Vicarious
☑Rekt | ☐ Not rekt
Moet je bij je static niet aangeven welk protocol je wilt redirecten?
static (inside,outside) tcp 195.240.X.X www 192.168.1.10 www netmask 255.255.255.255 0 0
En ik zou er maar 1 inzetten, en niet beide richtingen op. De regel die ik hierboven heb staan zou moeten kloppen.
