Compiling ssh2.so
  • 249 views
  • vdvleon
  • Laatst online: 08-06-2023
Het is me tot zo ver gelukt om met 'pear build' ssh2.so te compilen. Dut lukt allemaal:
running: phpize
Configuring for:
PHP Api Version: 20041225
Zend Module Api No: 20060613
Zend Extension Api No: 220060519
building in /var/tmp/pear-build-root/ssh2-0.10
running: /root/libssh/libssh2-0.18/ssh2-0.10/configure
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for a sed that does not truncate output... /bin/sed
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc and cc understand -c and -o together... yes
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for PHP prefix... /usr
checking for PHP includes... -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib
checking for PHP extension directory... /usr/lib/php5/20060613
checking for PHP installed headers prefix... /usr/include/php5
checking for re2c... no
configure: WARNING: You will need re2c 0.9.11 or later if you want to regenerate PHP parsers.
checking for gawk... no
checking for nawk... nawk
checking if nawk is broken... no
checking for ssh2 support... yes, shared
checking for ssh2 files in default path... found in /usr/local
checking for libssh2_banner_set in -lssh2... yes
checking for libssh2_channel_forward_listen_ex in -lssh2... yes
checking for libssh2_userauth_hostbased_fromfile_ex in -lssh2... yes
checking for libssh2_poll in -lssh2... yes
checking for libssh2_publickey_init in -lssh2... yes
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
configure: creating ./config.status
config.status: creating config.h
running: make
/bin/sh /var/tmp/pear-build-root/ssh2-0.10/libtool --mode=compile gcc -I. -I/root/libssh/libssh2-0.18/ssh2-0.10 -DPHP_ATOM_INC -I/var/tmp/pear-build-root/ssh2-0.10/include -I/var/tmp/pear-build-root/ssh2-0.10/main -I/root/libssh/libssh2-0.18/ssh2-0.10 -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -I/usr/local/include -DHAVE_CONFIG_H -g -O2 -c /root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c -o ssh2.lo
mkdir .libs
gcc -I. -I/root/libssh/libssh2-0.18/ssh2-0.10 -DPHP_ATOM_INC -I/var/tmp/pear-build-root/ssh2-0.10/include -I/var/tmp/pear-build-root/ssh2-0.10/main -I/root/libssh/libssh2-0.18/ssh2-0.10 -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -I/usr/local/include -DHAVE_CONFIG_H -g -O2 -c /root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c -fPIC -DPIC -o .libs/ssh2.o
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c: In function 'zif_ssh2_methods_negotiated':
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:483: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:484: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:485: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:486: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:487: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:488: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:489: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:490: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:491: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:492: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c: In function 'zif_ssh2_fingerprint':
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:536: warning: assignment discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c: In function 'zif_ssh2_publickey_add':
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:1038: warning: passing argument 1 of '_efree' discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c: In function 'zif_ssh2_publickey_list':
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:1097: warning: passing argument 4 of 'add_assoc_stringl_ex' discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:1098: warning: passing argument 4 of 'add_assoc_stringl_ex' discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:1106: warning: initialization discards qualifiers from pointer target type
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2.c:1107: warning: passing argument 2 of '_zend_hash_add_or_update' discards qualifiers from pointer target type
/bin/sh /var/tmp/pear-build-root/ssh2-0.10/libtool --mode=compile gcc -I. -I/root/libssh/libssh2-0.18/ssh2-0.10 -DPHP_ATOM_INC -I/var/tmp/pear-build-root/ssh2-0.10/include -I/var/tmp/pear-build-root/ssh2-0.10/main -I/root/libssh/libssh2-0.18/ssh2-0.10 -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -I/usr/local/include -DHAVE_CONFIG_H -g -O2 -c /root/libssh/libssh2-0.18/ssh2-0.10/ssh2_fopen_wrappers.c -o ssh2_fopen_wrappers.lo
gcc -I. -I/root/libssh/libssh2-0.18/ssh2-0.10 -DPHP_ATOM_INC -I/var/tmp/pear-build-root/ssh2-0.10/include -I/var/tmp/pear-build-root/ssh2-0.10/main -I/root/libssh/libssh2-0.18/ssh2-0.10 -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -I/usr/local/include -DHAVE_CONFIG_H -g -O2 -c /root/libssh/libssh2-0.18/ssh2-0.10/ssh2_fopen_wrappers.c -fPIC -DPIC -o .libs/ssh2_fopen_wrappers.o
/bin/sh /var/tmp/pear-build-root/ssh2-0.10/libtool --mode=compile gcc -I. -I/root/libssh/libssh2-0.18/ssh2-0.10 -DPHP_ATOM_INC -I/var/tmp/pear-build-root/ssh2-0.10/include -I/var/tmp/pear-build-root/ssh2-0.10/main -I/root/libssh/libssh2-0.18/ssh2-0.10 -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -I/usr/local/include -DHAVE_CONFIG_H -g -O2 -c /root/libssh/libssh2-0.18/ssh2-0.10/ssh2_sftp.c -o ssh2_sftp.lo
gcc -I. -I/root/libssh/libssh2-0.18/ssh2-0.10 -DPHP_ATOM_INC -I/var/tmp/pear-build-root/ssh2-0.10/include -I/var/tmp/pear-build-root/ssh2-0.10/main -I/root/libssh/libssh2-0.18/ssh2-0.10 -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -I/usr/local/include -DHAVE_CONFIG_H -g -O2 -c /root/libssh/libssh2-0.18/ssh2-0.10/ssh2_sftp.c -fPIC -DPIC -o .libs/ssh2_sftp.o
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2_sftp.c: In function 'php_ssh2_sftp_dirstream_read':
/root/libssh/libssh2-0.18/ssh2-0.10/ssh2_sftp.c:271: warning: passing argument 6 of 'php_basename' from incompatible pointer type
/bin/sh /var/tmp/pear-build-root/ssh2-0.10/libtool --mode=link gcc -DPHP_ATOM_INC -I/var/tmp/pear-build-root/ssh2-0.10/include -I/var/tmp/pear-build-root/ssh2-0.10/main -I/root/libssh/libssh2-0.18/ssh2-0.10 -I/usr/include/php5 -I/usr/include/php5/main -I/usr/include/php5/TSRM -I/usr/include/php5/Zend -I/usr/include/php5/ext -I/usr/include/php5/ext/date/lib -I/usr/local/include -DHAVE_CONFIG_H -g -O2 -o ssh2.la -export-dynamic -avoid-version -prefer-pic -module -rpath /var/tmp/pear-build-root/ssh2-0.10/modules ssh2.lo ssh2_fopen_wrappers.lo ssh2_sftp.lo -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lssh2
gcc -shared .libs/ssh2.o .libs/ssh2_fopen_wrappers.o .libs/ssh2_sftp.o -Wl,--rpath -Wl,/usr/local/lib -Wl,--rpath -Wl,/usr/local/lib -L/usr/local/lib /usr/local/lib/libssh2.so -Wl,-rpath -Wl,/usr/local/lib -Wl,-soname -Wl,ssh2.so -o .libs/ssh2.so
creating ssh2.la
(cd .libs && rm -f ssh2.la && ln -s ../ssh2.la ssh2.la)
/bin/sh /var/tmp/pear-build-root/ssh2-0.10/libtool --mode=install cp ./ssh2.la /var/tmp/pear-build-root/ssh2-0.10/modules
cp ./.libs/ssh2.so /var/tmp/pear-build-root/ssh2-0.10/modules/ssh2.so
cp ./.libs/ssh2.lai /var/tmp/pear-build-root/ssh2-0.10/modules/ssh2.la
PATH="$PATH:/sbin" ldconfig -n /var/tmp/pear-build-root/ssh2-0.10/modules
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Build complete.
(It is safe to ignore warnings about tempnam and tmpnam).
running: make INSTALL_ROOT="/var/tmp/pear-build-root/install-ssh2-0.10" install
Installing shared extensions: /var/tmp/pear-build-root/install-ssh2-0.10/usr/lib/php5/20060613/
running: find "/var/tmp/pear-build-root/install-ssh2-0.10" -ls
14140369 4 drwxr-xr-x 3 root root 4096 jun 18 20:50 /var/tmp/pear-build-root/install-ssh2-0.10
14140394 4 drwxr-xr-x 3 root root 4096 jun 18 20:50 /var/tmp/pear-build-root/install-ssh2-0.10/usr
14140395 4 drwxr-xr-x 3 root root 4096 jun 18 20:50 /var/tmp/pear-build-root/install-ssh2-0.10/usr/lib
14140396 4 drwxr-xr-x 3 root root 4096 jun 18 20:50 /var/tmp/pear-build-root/install-ssh2-0.10/usr/lib/php5
14140397 4 drwxr-xr-x 2 root root 4096 jun 18 20:50 /var/tmp/pear-build-root/install-ssh2-0.10/usr/lib/php5/20060613
14140393 204 -rwxr-xr-x 1 root root 201396 jun 18 20:50 /var/tmp/pear-build-root/install-ssh2-0.10/usr/lib/php5/20060613/ssh2.so
Het probleem alleen is dat als hij klaar is gelijk weer het besstand ssh2.so (/var/tmp/pear-build-root/install-ssh2-0.10/usr/lib/php5/20060613/ssh2.so) verwijdert. Ik heb er dus niks aan. Hoe voor kom ik dit. (hoe kan ik de build directory kiezen...)
B.V.D.
Leon
  • lamko
  • Laatst online: 03:47
Wie verwijderd wat ? de makefile ? Kun je de makefile niet editen zo dat het naar nog een locatie als backup gekopieerd wordt. Als je weet wie wat verwijderd zou je op google met een paar searchtermen wel iemand moeten kunnen vinden die ook hetzelfde probleem heeft of probeer eens een oudere versie.
And this !! Is to go even further beyond!!!
  • Creepy
  • Laatst online: 08:17
Creepy
Tactical Espionage Splatterer
Eeeh, in PRG draait het om zelf geschreven software, niet om het compilen van andermans software. Daarnaast heeft PEAR prima docs en is er een hoop te vinden met google. Als laatste wil ik je oko nog meegeven dat je nu je probleem dumpt en niet aangeeft wat je nu zelf al hebt geprobeerd en wat daar niet mee lukte. Dat gecombineerd met een topic dat hier niet hoort lijkt het erop als je het forum hier als helpdesk lijkt te willen gebruiken. Dat is niet de bedoeling van het forum ;)
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
