IOGEAR GUIP201 - netwerk usb hub mac compatible?
Ik spotte laatst dit handig apparaatje voor bijvoorbeeld gebruik van TimeMachine i.c.m. een externe usb schijf aangelsoten op dit apparaat.
Weet iemand of deze compatible is met Leopard / Mac, en TimeMachine?
Ik heb wat gegoogled, maar kom er niet echt uit. Op de site zijn trouwens alleen drivers voor Windows te vinden.
Misschien zijn er onder jullie mensen die dit apparaat gebruiken i.c.m. een Apple computer.
Alvast bedankt.
Meer info:
IOGEAR USB Share Station (Model GUIP201)
Next up for IOGEAR is their new USB Share Station - model GUIP201. You attach the Share Station to your Ethernet network and to a USB device and then share that device with any computer on the network. The Share Station can share up to 4 USB devices using a USB hub throughout your home and is compatible with external hard drives, flash drives, memory card readers, USB webcams, USB speakers, or USB Multi-function printers. In fact, you can attach a USB webcam to the USB Share Station and then get yourself a cheap network attached video monitoring system for your home or small office.
The GUIP201 comes with a built in print server which will automatically identify your printer make/model upon connection, and it complies with USB 2.0 specification. Here’s the full feature list:
* Share up to 4 USB devices through your home or office network by connecting to a USB 2.0 Hub
* Wirelessly share your USB devices through your wireless router.
* Share an external hard drive, flash drive or memory card reader with multiple users over your network
* Share a USB webcam over a network
* Enjoy music stored on any networked PC with a USB speaker
* Allows multiple users to share a Multi-Function Printer (MFP) over a network to print,scan, and fax from any networked computer
* Supported protocols:, LPR/LPD, IPP, Raw TCP / JetDirect, DHCP, UPnP
* Supports USB 2.0 and 1.1 devices
* Works with any home or office Ethernet network ??
  • joeltje
De site heeft het over windows drivers, en geen OSX drivers te vinden daar... Als je het ding eenmaal hebt geconfigged, zou het geen probleem mogen zijn lijkt me, maar dat zul je wellicht met een Windhoos pc moeten doen...
Ik heb niets te melden.
hm dat zou met boot camp niet zo'n probleem hoeven zijn :)
  • remco_k
  • Laatst online: 18:18
remco_k
een cassettebandje was genoeg
Volgens mij moet je dat apparaatje even zien als een USB naar Ethernet converter, waarna hij via TCP/IP in staat is om de data van aangesloten apparaten te transporteren van of naar je computer.
Echter, je computer heeft geen idee wat hij ermee moet, vandaar dat er een driver nodig is. Daarin klop je het IP nummer van de GUIP201 in en de driver emuleerd alsof er een USB poort bijkomt op je computer en lijkt het dus net of het aangesloten apparaat direct aan je computer hangt... En dus is er verplicht een driver nodig op de computer.
Sterker nog, de driver van je (bv. webcam) weet niet beter en denkt dat de webcam lokaal aan is gesloten.
Maar nogmaals, dit is zoals ik denk dat het werkt...
En als het zo werkt en er is geen driver voor de MAC, dan houd het wellicht op.
Alles kan stuk.
  • Absolut
  • Laatst online: 20:07
Weet iemand waar je dit product in de Benelux kan kopen?
  • chem
  • Laatst online: 06-10 20:24
chem
Reist de wereld rond
Verwijderd schreef op vrijdag 23 mei 2008 @ 21:13:
Volgens mij snap je niet wat bootcamp is ;)
Klaar voor een nieuwe uitdaging.
  • ymoona
  • Laatst online: 15:47
chem schreef op maandag 26 mei 2008 @ 09:54:
volgens mij snap JIJ niet wat bootcamp is. ;)
https://f1nerd.nl
  • remco_k
remco_k
ymoona schreef op maandag 26 mei 2008 @ 12:55:
Lekker onderbouwd ook.
Nee, IK snap niet wat bootcamp is. :+ Ik heb zelfs nog nooit een mac aangeraakt. (en ben dat niet van plan ook) ;)
Maar wat ik sinds enkele seconden wel van bootcamp weet (dat staat namelijk op de site van apple):
Bootcamp. Run Windows on your Mac.
Dat wil de TS helemaal niet anders had hij dat wel vermeld. Dus bootcamp is geen oplossing.
[ Voor 14% gewijzigd door remco_k op 26-05-2008 13:57 ]
Alles kan stuk.
Voor de duidelijkheid: boot camp als oplossing gold op de 1e reactie van Joeltje. Die schrijft dat het mogelijk alleen even geconfigureerd/geinstalleerd hoeft te worden onder Windows (eh dus boot camp), en dat het daarna, eenmaal ingesteld, 'werkt' en verder geen omkijken meer nodig heeft. De vraag is of Leopard het apparaat vervolgens ook 'ziet' en of Leopard/Apple compatible is met de functie(s) van dit apparaatje. Je zou het haast wel denken omdat er staat "Allows multiple users to share a Multi-Function Printer (MFP) over a network to print,scan, and fax from any networked computer".
Als Remco_K gelijk heeft zal het waarschijnlijk niet werken onder Leopard, omdat de driver (in dit geval dus alleen beschikbaar voor Windows) er voor zorgt dat het OS weet wat ie moet doen met het apparaat.
EDIT: Weet iemand hier wat zinnigs over te zeggen die verstand heeft van:
en de compatibilty van Apple/Leopard hiervan. Ik ben een complete noob wat dit betreft.
[ Voor 50% gewijzigd door Verwijderd op 26-05-2008 17:15 ]
  • Kapitein Prozac
  • Laatst online: 13-03 19:09
Antwoord van IOGEAR Support;
It is a Windows only device at this time.
Thanks,
Service Support
tja vragen staat vrij.. :) thanks!
[ Voor 15% gewijzigd door Verwijderd op 27-05-2008 20:33 ]
  • woekele
woekele
woekele
Absolut schreef op maandag 26 mei 2008 @ 09:52:
Sorry voor deze bump, maar ik ben op zoek naar dit apparaat. Iemand enig idee of het in Nederland te koop is?
sja, ik weet niet meer waar ik het destijds gezien had... Sorry, ik kan je niet helpen iig. Ik heb het apparaat vanwege twijfels over compatibiliteit met OSX niet gekocht.
  • Mikey NL
  • Laatst online: 08:30
Volgens mij is dit zo'n zelfde hub, alleen dan van Belkin: http://www.belkin.com/nl/networkusbhub/
Deze is mac compatible en iig te koop bij iCentre
  • woekele
woekele
woekele
Mikey NL schreef op zondag 10 augustus 2008 @ 22:52:
Ziet er prima uit. Lijkt inderdaad aan dezelfde eisen te voldoen. Tnx voor de tip!
De guip201 is echter beschikbaar voor 54 dollar (in Amerika tenminste), deze kost minimaal 65 euro. Hmmm.. pricewatch: Belkin Netwerk-USB-hub
[ Voor 20% gewijzigd door woekele op 10-08-2008 23:33 ]
Ter volledigheid: ik heb de Belkin hub en hij werkt precies zoals je zou verwachten. Fijn apparaat. Ik gebruik hem ook om USB-apparaten die erop aangesloten zijn weer in een Windows VM beschikbaar te maken en zelfs dat werkt!
