hallo,
Ik zit sinds 2 weken met een "klein" probleempje. Ik ben patchmanagement aant het implementeren op de SMS 2003 server in het netwerk, maar de unattended synchronisation van de primary site wil maar niet lukken.
de cab file download wel, ma de sql database wordt niet geupdate. Ik ben een beetje ten einde raad.
Ik heb alle rechten ingesteld, de proxy is ingesteld en de firewall laat unauthenticated connections door.
Hier is een uittreksel uit de log file van de laatste synchronisatiepoging.
User Account: NONE
User Profile: C:\Documents and Settings\Default User
Command line specified package to update on DPs as KAT00096
Command line specified folder to update as \\KAT-SMS1\C$\Program Files\SecurityPatch\PkgSource.
Command line specified site code: KAT.
Command line specified site server: KAT-SMS1.
Specified folder is local, changing it to: C:\PROGRAM FILES\SECURITYPATCH\PKGSOURCE
Download completed - http://go.microsoft.com/fwlink/?LinkId=23190
Download completed successfully.
Trying to calculate hash on C:\WINDOWS\TEMP\mssecure.cab. $$<Software Updates Scan Helper><Tue May 13 16:37:28.962 2008 Romance Daylight Time><thread=8348 (0x209C)>
Trying to calculate hash on C:\PROGRAM FILES\SECURITYPATCH\PKGSOURCE\1033\mssecure.cab. $$<Software Updates Scan Helper><Tue May 13 16:37:28.962 2008 Romance Daylight Time><thread=8348 (0x209C)>
C:\WINDOWS\TEMP\mssecure.cab and C:\PROGRAM FILES\SECURITYPATCH\PKGSOURCE\1033\mssecure.cab were found to be same. $$<Software Updates Scan Helper><Tue May 13 16:37:28.978 2008 Romance Daylight Time><thread=8348 (0x209C)>
Distribution points will not be updated.
Checking if patch preapprovals are supported by site KAT-SMS1
Patch preapprovals are supported by site KAT-SMS1, proceeding with catalog updates
Updating site catalog: CATALOG="C:\PROGRAM FILES\SECURITYPATCH\PKGSOURCE\1033\mssecure.cab" TYPE=MBSA SERVER=KAT-SMS1 SITE=KAT PACKAGE=KAT00096 LCID=1033 MAXAGE=30 ADDLOC= LOGFILE="C:\WINDOWS\system32\CCM\Logs\SecuritySyncXML.log" VERBOSE=2
UpdateCatalog: Processing security catalog C:\PROGRAM FILES\SECURITYPATCH\PKGSOURCE\1033\mssecure.cab ...
UpdateCatalog: Connected to \\KAT-SMS1\root\sms
UpdateCatalog: Connected to \\KAT-SMSSQL1\root\sms\site_KAT
UpdateCatalog: error 0x80041002, Not found, Error retrieving object PackageID=KAT00096, returned from GetObject(SMS_Package KAT00096)
Some catalog updates failed. Will retry next time.
Loaded "C:\WINDOWS\system32\CCM\smscstat.dll"; the module handle is 0x18890000. $$<Software Updates Scan Helper><Tue May 13 16:37:29.509 2008 Romance Daylight Time><thread=8348 (0x209C)>
CreateSMSStatusMessage() succeeded; the status message object handle is 0x01FDF7E8. $$<Software Updates Scan Helper><Tue May 13 16:37:29.509 2008 Romance Daylight Time><thread=8348 (0x209C)>
ReportSMSStatusMessage() succeeded. $$<Software Updates Scan Helper><Tue May 13 16:37:29.603 2008 Romance Daylight Time><thread=8348 (0x209C)>
Op internet heb ik de volgende oplossing gevonden, maar ik heb een beetje moeite met deze te begrijpen.:s
want zover ik weet kan je enkel user rights instellen op services. en dit is geen service. of zie ik hier iets over het hoofd?
In order to resolve this issue, you must set the SyncXML.exe to run with
user right.
However just as I had mentioned in the previous, .UpdateCatalog: failed is
not a cirtical error, you still can get the updates in the DB after the
inventory had been run on the client computers. So if you do not want to
set it run with user right, it will aslo be ok.
mvg,
Thomas Maes
User Account: NONE
user right.
mvg,
Thomas Maes
[ Voor 0% gewijzigd door Verwijderd op 14-05-2008 11:49 . Reden: details aangepast^^ ]
