[clarkconnect] Gnome installeren
  • CrankyGamerOG
  • Laatst online: 12-10 12:29
CrankyGamerOG
Assumption is the mother.....
Ik probeer dus gnome te installeren, echter kom ik om in de unmet dependencies..
Hardware
Intel Pentium4 3,05Ghz @ 2,6Ghz
1,5GB DDR333
2x  80GB
1x 500GB
kernel
2.6.18-53.1.13.2.cc
Release
ClarkConnect 4.2 - CentOS release 4.6 (Final)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
[root@thuis ~]# apt-get install gdm
Reading Package Lists...
Building Dependency Tree...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  gdm: Depends: /etc/X11/xdm/Xsession
       Depends: /etc/pam.d/system-auth
       Depends: /sbin/nologin
       PreDepends: /usr/bin/scrollkeeper-update
       PreDepends: /usr/sbin/useradd
       Depends: gtk2 (>= 0:2.2.0) but it is not going to be installed
       Depends: libICE.so.6
       Depends: libSM.so.6
       Depends: libX11.so.6
       Depends: libXext.so.6
       Depends: libXinerama.so.1
       Depends: libbonoboui-2.so.0
       Depends: libgconf-2.so.4
       Depends: libgdk-x11-2.0.so.0
       Depends: libgdk_pixbuf-2.0.so.0
       Depends: libglade-2.0.so.0
       Depends: libglade2 (>= 0:2.0.0) but it is not going to be installed
       Depends: libgnome-2.so.0
       Depends: libgnomecanvas (>= 0:2.0.0) but it is not going to be installed
       Depends: libgnomecanvas-2.so.0
       Depends: libgnomeui (>= 0:2.2.0) but it is not going to be installed
       Depends: libgnomeui-2.so.0
       Depends: libgnomevfs-2.so.0
       Depends: libgtk-x11-2.0.so.0
       Depends: libpam.so.0
       Depends: libpam_misc.so.0
       Depends: libpango-1.0.so.0
       Depends: libpangoft2-1.0.so.0
       Depends: libpangox-1.0.so.0
       Depends: libpangoxft-1.0.so.0
       Depends: librsvg-2.so.2
       Depends: librsvg2 (>= 0:2.0.1) but it is not going to be installed
       Depends: pam (>= 0:0.77-66.7) but it is not going to be installed
       Depends: usermode but it is not going to be installed
       Depends: xinitrc (>= 0:3.33-1) but it is not going to be installed
       Depends: xsri (>= 1:2.0.2) but it is not going to be installed
E: Broken packages
Nu heb ik echter wel een hele zwik ervan WEL op me systeem.
Hoe krijg ik nu die dependencies resolved zonder dat ik ze 1 voor moet nalopen ?
[ Voor 3% gewijzigd door CrankyGamerOG op 01-04-2008 18:58 ]
KPN - Vodafone Ziggo Partner
  • Osiris
Je probeert Gnome te installeren, maar je installeert gdm?
't Lijkt me dat gdm zelf een dep is van het gnome-package?
  • CrankyGamerOG
CrankyGamerOG
nou nee, gnome-package bestaat zowieso niet, ik denk dat je dan op gnome-desktop doelt.
echter ook deze komt om in de unmet dependencies
(alhoewel ik eerst wel gewoon apt-get install gdm kon doen)(vorige install)
  gnome-desktop: PreDepends: /usr/bin/gconftool-2
                 PreDepends: GConf2 but it is not going to be installed
                 Depends: libSM.so.6
                 Depends: libstartup-notification-1.so.0
                 Depends: startup-notification (>= 0.5) but it is not going to be installed
  gnome-desktop-devel: Depends: GConf2-devel (>= 1.2.1) but it is not going to be installed
                       Depends: gnome-vfs2-devel (>= 2.2.0) but it is not going to be installed
                       Depends: gtk2-devel (>= 2.2.0) but it is not going to be installed
                       Depends: libgnome-devel (>= 2.2.0) but it is not going to be installed
                       Depends: libgnomeui-devel (>= 2.2.0) but it is not going to be installed
                       Depends: startup-notification-devel (>= 0.5) but it is not going to be installed
E: Broken packages
Vreemde is dat ik die dependencies wel heb ?
Bijvoorbeeld libICE.so.6
[root@thuis ~]# locate libICE
/usr/X11R6/lib/libICE.so.6
/usr/X11R6/lib/libICE.so.6.3
[root@thuis ~]#
[ Voor 5% gewijzigd door CrankyGamerOG op 01-04-2008 13:46 ]
  • BarthezZ
BarthezZ
anti voetbal en slechte djs!
Als ik met goed herinner (kan er naast zitten) heeft Cent OS standaard toch geen apt-get? Ik dacht dat de standaard manier om packages te installeren was via yum of yast of iets dergelijks. Ik vermoed dat je dus eigenlijk verkeerde packages download voor je systeem.
  • CrankyGamerOG
CrankyGamerOG
jah nee klopt, standaard komt centos met YUM,
met deze CentOS based distro is het apt-get (Clarkconnect)
[ Voor 14% gewijzigd door CrankyGamerOG op 01-04-2008 15:47 ]
  • geez
  • Laatst online: 28-04 20:04
Misschien dat je de package gnome-desktop-environment moet hebben? (Althans zo heet hij bij debian)
  • Miki
  • Laatst online: 23:46
Je kunt volgens mij met APT toch in je cache zoeken naar paketten. Wat levert je de zoektocht "gnome" op? Ik weet wel zeker dat er een zogenaamde "meta package" moet zijn die er voor zorgt dat er een complete gnome desktop wordt geinstalleerd.
[ Voor 41% gewijzigd door Miki op 01-04-2008 15:57 ]
  • CrankyGamerOG
CrankyGamerOG
Het is gnome-desktop bij mij ,
maar zoals boven al aangegeven, ook weer hele waslijst aan unmet dependencies.
Thee following packages have unmet dependencies:
  [b]gnome-desktop[/b]: PreDepends: /usr/bin/gconftool-2
                 Depends: libSM.so.6
E: Broken packages
Maar zoals ik ook al eerder zei, de meeste heb ik wel gewoon (afgezien van die deps met afwijkende versies ofc)
[ Voor 91% gewijzigd door CrankyGamerOG op 01-04-2008 16:22 ]
Hij zegt ook niet dattie die bovenste libraries mist. Een of meer van de dependencies hebben een probleem.
Probeer is van onderaf die probleempakketjes te installen met apt-get install. Dat dependency gedoe gaat als een olievlek door je install heen. Wordt ook wel dependency-hell genoemd.
  • BarthezZ
BarthezZ
CrankyGamerOG schreef op dinsdag 01 april 2008 @ 15:46:
Áha, explains. Zeg dan gewoon dat je Clarkconnect draait. Maar mijn god waarom zou je daar een desktop op willen draaien? 8)7 Het mist een grote hoeveelheid packages in de repo's om degelijk een desktop te kunnen draaien...
Indien je geen vage repo's heb toegevoegd en even
 apt-get update && apt-get dist-upgrade
doet zou het geen probleem moeten zijn om het te installeren ( apt-get install gdm )
  • CrankyGamerOG
CrankyGamerOG
BarthezZ schreef op dinsdag 01 april 2008 @ 18:44:
zeg ik toch ook ?
heb nergens wat anders beweerd :)
En de reden voor Gnome op CC is Xvnc ;)
upgrade etc zal niks uithalen ? daar ik de laastste versie draai ?, maar vooruit :)
edit
Zoals ik al dacht , het lost helaas niks op
Wel heel wat minder dependencie problems :)
[root@thuis ~]# apt-get update && apt-get dist-upgrade
Updating apt-get details: Ok
Get:1 ftp://apt.clarkconnect.com System release [1137B]
Get:2 ftp://rh.apt.clarkconnect.com System release [926B]
Fetched 2063B in 4s (457B/s)
Hit ftp://rh.apt.clarkconnect.com System/extras pkglist
Hit ftp://rh.apt.clarkconnect.com System/extras release
Hit ftp://apt.clarkconnect.com System/os pkglist
Hit ftp://rh.apt.clarkconnect.com System/os pkglist
Hit ftp://apt.clarkconnect.com System/os release
Hit ftp://rh.apt.clarkconnect.com System/os release
Hit ftp://apt.clarkconnect.com System/updates pkglist
Hit ftp://rh.apt.clarkconnect.com System/updates pkglist
Hit ftp://apt.clarkconnect.com System/updates release
Hit ftp://rh.apt.clarkconnect.com System/updates release
Hit ftp://apt.clarkconnect.com System/contribs pkglist
Hit ftp://apt.clarkconnect.com System/contribs release
Hit ftp://apt.clarkconnect.com System/developer pkglist
Hit ftp://apt.clarkconnect.com System/developer release
0 upgraded, 0 newly installed, 0 removed and 0 not upgraded.
[root@thuis ~]#
gdm: Depends: libbonoboui-2.so.0
Depends: redhat-artwork (>= 0:0.112-2) but it is not installable
E: Broken packages
[ Voor 63% gewijzigd door CrankyGamerOG op 01-04-2008 18:58 ]
  • BarthezZ
BarthezZ
Nouja een dependency probleem komt niet zomaar :)
Mag ik vragen wat precies je op Xvnc wilt gaan draaien en waarom je die gui nodig heb? Ik heb namelijk het vermoeden dat je ook veel makkelijker af kan met een lichtere window manager zoals fluxbox/twm/vtwm, etc. :)
  • CrankyGamerOG
CrankyGamerOG
naja , het enigste wat ik eig nodig heb is een browser via Xvnc voor multiple doeleinden zoals maar niet uitsluitend :
1. Instellen apparatuur intern netwerk (denk aan Sip Phone/modem/switches e.d.)
2. Alternatieve test locatie voor internethosts buiten mijn werk isp (Chello)
3. Gallery (deze heb ik thuis draaien voor gemak van vriendin, qua publiceren) <--- dom die kan ik altijd al bereiken :P
Maar misschien kan jij iets voor me verduidelijken tho Barthezz
Waarom zeurt hij over bijv libgnomeui-2.so.0 , als dit bij Gnome hoort ?
(en ik dus apt-get install gnome-desktop doe ?)
Hoort hij deze niet gewoon mee te nemen bij de apt-get ?
De artwork dep snap ik wel ;)
kan dit btw komen doordat ik CC python 2.5 door de strop heb geduwd ? >:)
Verwijderd schreef op dinsdag 01 april 2008 @ 18:40:
ja ik dacht slim te zijn en de rpm te dlen van bijv bonobo , maar dan blijf ik rondjes lopen rond dezelfde unmet deps
bijv
[root@thuis ~]# rpm -ihv gnome-python2-bonobo-2.6.0-3.i386.rpm
warning: gnome-python2-bonobo-2.6.0-3.i386.rpm: V3 DSA signature: NOKEY, key ID 443e1821
error: Failed dependencies:
        bonobo-activation >= 1.0.0 is needed by gnome-python2-bonobo-2.6.0-3.i386
        gnome-python2 = 2.6.0-3 is needed by gnome-python2-bonobo-2.6.0-3.i386
        libbonobo >= 2.0.0 is needed by gnome-python2-bonobo-2.6.0-3.i386
        libbonobo-2.so.0 is needed by gnome-python2-bonobo-2.6.0-3.i386
        libbonobo-activation.so.4 is needed by gnome-python2-bonobo-2.6.0-3.i386
        libbonoboui >= 2.0.0 is needed by gnome-python2-bonobo-2.6.0-3.i386
        libbonoboui-2.so.0 is needed by gnome-python2-bonobo-2.6.0-3.i386
        libgnome-2.so.0 is needed by gnome-python2-bonobo-2.6.0-3.i386
        libgnomecanvas-2.so.0 is needed by gnome-python2-bonobo-2.6.0-3.i386
        libgnomevfs-2.so.0 is needed by gnome-python2-bonobo-2.6.0-3.i386
        pyorbit >= 2.0.l is needed by gnome-python2-bonobo-2.6.0-3.i386
apt-get install gnome-python2
  gnome-python2: Depends: gnome-python2-bonobo but it is not going to be installed
E: Broken packages
Ik denk dat ik iets goed vernaggeld heb 8)7
[ Voor 99% gewijzigd door CrankyGamerOG op 01-04-2008 19:12 ]
  • BarthezZ
BarthezZ
Nouja 2 opties: Of de repo's zijn stuk, of doordat jij python 2.5 "door de strot heb geduwd" (handmatig een rpm installed?) heb je gezeik met de dependencies.
Maar op mijn 'vers' geinstalleerde virtuele image van CC (geen idee welke versie tough) krijg ik het ook niet helemaal goed voor elkaar, met dezelfde errors. En zelfs na even dieper aankloten lukt het mij niet om het goed te installeren.
Ik raad dus aan een andere wm te installeren, en de enige die ik kan vinden die wel in de repo's van CC zitten is twm (xorg-x11-twm) alleen moet je daarbij nog even zorgen dat je vnc het goed launched.
  • CrankyGamerOG
CrankyGamerOG
BarthezZ schreef op dinsdag 01 april 2008 @ 19:32:
Nee ik heb hem zelf gebuild en de symlink aangepast :P
Ik zal eens naar twm kijken.. en de Xvnc zal wel twm-session && oid worden ipv gnome-session &&
[ Voor 32% gewijzigd door CrankyGamerOG op 01-04-2008 19:36 ]
  • BarthezZ
BarthezZ
Gewoon twm in je xstartup/xvncrc (of een willekeurig ander startup script wat aangeroepen word bij het launchen van je vnc :p )
  • CrankyGamerOG
CrankyGamerOG
nee dan denk ik dat je ook 4.2 hebt nu, want onder 4.1 had ik gdm echt zo erop via apt-get.
  • BarthezZ
BarthezZ
Community Edition 4.1
Wednesday April 02, 2008
Alles wijst er naar mijn weten in ieder geval op dat hun iets verklooit hebben in de repo's
  • CrankyGamerOG
CrankyGamerOG
Het lijkt er inderdaad verdacht op dat ze iets goed kaput gemacht haben :o
hummzzz ik weet echt 100% zeker dat ik onder 4.1 destijds met een simpele apt-get install gdm de gnome display manager kon installeren.
  • Alternativ
  • Laatst online: 04-09 16:38
Alternativ
4 8 15 16 23 42
Mag ik vragen waarom je überhaupt op een server een wm gaat installeren? Andersom snap ik het nog wel een desktop met server taken echter voor de drie zaken die jij genoemd hebt zou een VPN-opzet (standaard onderdeel van clarkconnect?) veel geschikter zijn.
alternativ
  • CrankyGamerOG
CrankyGamerOG
Alternativ schreef op donderdag 03 april 2008 @ 18:05:
sinds wanneer moet ik mij verantwoorden voor iets wat ik wil ? :+
nogmaals :
ik wil via vnc op de desktop(gnome,enlightment whatever) kunnen surfen om op interne apparatuur te kunnen komen(config pages), en nee ik heb geen zin om allerlei poorten te forwarden ;)
En de enigste reden voor gnome is dat ik de gnome layout en interface ken >:)
Ik start dan de gdm/Xvnc ook alleen wanneer ik het nodig heb, voor de rest is het gewoon recht toe recht aan een server
[ Voor 19% gewijzigd door CrankyGamerOG op 03-04-2008 18:39 ]
  • Alternativ
Alternativ
4 8 15 16 23 42
CrankyGamerOG schreef op donderdag 03 april 2008 @ 18:36:
Ik vraag niet om verantwoording maar om beweegredenen.
Poorten forwarden hoeft niet zodra je een vpn hebt. Ik neem aan dat je een browser vanuit die interface wilt gebruiken? Lynx :+
alternativ
  • CrankyGamerOG
CrankyGamerOG
lol uiteraard :)
ik kan wel met vpn werken e.d. maar me vriendin niet :+
En zodra ik nog ingewikkeldere protocollen ga opzetten en er gaat iets mis,
krijg ik op me dak als ze opeens geen inet meer heeft, nee dankje :) (vrouwen pffff :Y )
En nee lynx helaas is niet genoeg, ik kan er bijv niet mee in me switch :'(
  • BarthezZ
BarthezZ
ssh tunnels *O* is ook een mogelijkheid ;)
Maar ondertussen al gelukt met twm? :p
  • CrankyGamerOG
CrankyGamerOG
BarthezZ schreef op donderdag 03 april 2008 @ 19:16:
heb twm nog niet geprobeerd, was vannacht pas om 0300 thuis :P dus toen was het ZzZz tijd :)
En vanavond tot 23uur werken dus vanavond word wschlijk ook niks :)
Maar morgen=vrij , dus dan heb ik de hele dag om aan te knommelen
  • CrankyGamerOG
CrankyGamerOG
erg late kick :)
ik ben ondertussen zover dat ik KDE draaiende heb op CC, dus het kan nog wel ;)
Dit dus ook dmv Xvnc werkend zoals ik het destijds ook in gnome had.
Mocht er iemand interesse hebben hoe, dan post ik het wel ,maar ik denk niet dat het nu zoveel zin heeft aangezien er (imho) niet zoveel cc gebruikers hier rondlopen ?
en imho is een X installeren en KDE niet zon rocketscience
[ Voor 65% gewijzigd door CrankyGamerOG op 22-07-2008 20:30 ]
