[Folding@Home] hitparade van 25 maart Vorige deel Overzicht Volgende deel Laatste deel
  • smoking2000
  • Laatst online: 03-11 04:52
smoking2000
DPC-Crew
dpkg-reconfigure reality
Voor hen die het gister nog niet gezien hadden:
Nieuwe F@H Clients
Windows
New Windows SMP client release
by kasson
We are excited to release a new Windows SMP client to beta. This is an *early* beta release--please expect some rough edges.
Read below for details:
*how to get it*
go to the download page: http://folding.stanford.edu/English/Download (substitute your language as appropriate) and look for the 5.92 client
***how to install it***
The installation process is a little complicated. PLEASE READ BELOW.
1. The initial release is a *replacement* for your current 5.91 SMP client. We will have a fresh install version soon.
2. Make a backup of a working FAH Windows/SMP installation. Install into your current SMP working directory
3. Unzip the 5.92 file in your test directory
4. Open a command prompt window (run as administrator if Vista)
5. run install.bat. This will do several things
.. a) install DeinoMPI. You don't need to do anything special here
.. b) create a "credential store" that DeinoMPI will use to authenticate the mpi processes. Important: do not use a passphrase here (just hit return for no passphrase and say yes, you're sure). I recommend encrypting the data and using the registry for storage.
.. c) add your user information to the encrypted credential store. This will prompt you for your username and password.
.. d) run the standard mpiexec -np 2 foo test application to make sure things work. On some WinXP systems, you may see a defective Windows Firewall dialogue box come up. The firewall may also ask you to unblock applications (this is a good idea).
Notes from the forum mods on the above process:
5.d) The Windows Firewall dialog box will pop up twice. The first time, you will be able to see and click Unblock for DeinoMPI. The second time, the pop up window is hosed. However, since the unblock button has a hot key, you can press alt+u to unblock the next item and make it go away. I checked my firewall exceptions list after unblocking both. The second pop up is for fahcore1.exe.
5.d.2) I found a different bypass. After having gotten the hosed windows many times in WinXP I went to Start + ControlPanel + SecurityCenter + WindowsFirewall. On the Exceptions tab I scrolled through the list of names, adding a checkmark to the appropriate boxes.
6. Start fah.exe as normal.
7. Please report problems to this forum.
*what's different in 5.92*
With version 5.92, we have switched to a different MPI implementation (DeinoMPI instead of MPICH). In our testing thus far, this new implementation is *much* more stable for FAH. Performance is roughly comparable, with perhaps a slight speed increase. But stability and reliability is what we're going for here.
DeinoMPI is backwards-compatible with MPICH, so your old core binaries will work. However, most of the benefits come with a new core binary. One is included in the install package; the client should also auto-download Deino-specific core binaries. Similarly, the mpiexec binary for DeinoMPI differs from MPICH.
Look for new Deino-specific features coming in the future.
*other notes*
5.92 does not currently support 64-bit Windows. This is something we will work on in the future.
As with 5.91, we do not yet officially support running 5.92 as a service. It is possible to do this, but it requires setting several dependencies, etc. Other FAH donors may have helpful hints here.
Thanks for testing!
Comment/Questions/Feedback thread: http://foldingforum.org/viewtopic.php?f=8&t=1784
Linux & Mac OS X
new osx and linux v6.02 console clients to beta
by kasson on Tue Mar 25, 2008 6:30 pm
We are happy to release new versions of the OSX/Intel console and linux clients to beta. Version 6.02 contains one major improvement:
In addition to running with the -smp flag, you can now request a number of cores to use by using -smp <n>.
Several important notes:
Only projects using the A2 core support variable number of processes. The majority of our projects currently use the A1 core and are locked to 4 processes. So if you run with -smp 6 and get an A1 WU, the client will step down to using 4 processes for that WU. If your next WU is A2, the client will step back up to 6. We will be releasing more A2 projects as time goes on.
We currently support 4 <= n <= # of physical cores. (On a dual-core machine, n goes to 4). Using more processes than the # of physical cores in a machine degrades performance substantially.
***Do not change your value of n in the middle of a WU. This will likely cause loss of the WU.***
Please report any problems or feedback to this forum. Thanks for testing!
Grafiekjes
Afbeeldingslocatie: http://linuxminded.nl/tmp/daily-top.png
Afbeeldingslocatie: http://linuxminded.nl/tmp/daily-top-delta.png
Afbeeldingslocatie: http://linuxminded.nl/tmp/milestones.png
Welkom
Fossalta, JG & RedNalie d:)b
El Statso
DPC Folding@Home hitparade van 25 maart 2008
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 108 / 2.989 (3,6 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)29.663[DPC]_Team_ColdFusion10.394.344(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)13.760TEAM_JOE_BAR4.803.357(4)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)12.123[DPC]_Fatal_Error_Group4.150.415(6)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)11.965Bogaarts930.950(20)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.118BPE607.599(31)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.126chelloo.com5.728.606(3)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)3.577Schapie2.454.893(10)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.343PS3941.903(19)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)3.164DeApen599.598(32)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.784[DPC]NGS4.323.254(5)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.760SayWhatAgain155.568(87)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.517Big_Basje6.236(754)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif30)2.485DPC_Division_Brabant1.054.335(18)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)2.275gowron2.981.291(9)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.128snotaapje73.677(165)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.760Marktm113.718(120)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)1.760Waddenteam911.107(21)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.760pstalenh126.319(109)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.695PeaceNlove618.559(30)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.419RdamRobin748.735(28)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.256[DPC]Clan_Delft2.100.297(11)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.205esoteric1729.173(312)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif16)1.136Team_Pastis_513.448.907(8)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)937BananaTeam1.166.418(17)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)875BonkDeHond57.825(194)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)875Harmk-PS3165.586(82)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)875Nephilith2.547(1156)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)875[PS3]Masticina126.249(110)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)875biggie41.441(252)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)844Brobbel196.607(70)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.394.344[DPC]_Team_ColdFusion29.663(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.753.836Team4Fun.nl178(83)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.728.606chelloo.com7.126(6)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.803.357TEAM_JOE_BAR13.760(2)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.323.254[DPC]NGS2.784(10)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.150.415[DPC]_Fatal_Error_Group12.123(3)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.565.158Team_Elteor_Borislavj215(81)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.448.907Team_Pastis_511.136(23)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.981.291gowron2.275(14)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.454.893Schapie3.577(7)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.100.297[DPC]Clan_Delft1.256(21)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.897.849DPC_Los_Alcoholicos343(51)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.659.247www.onweer-online.nl0(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.616.363SandStar0(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.429.422Holy_Cow!0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.405.110Forza_Mucca0(-)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.166.418BananaTeam937(24)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.054.335DPC_Division_Brabant2.485(13)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)941.903PS33.343(8)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)930.950Bogaarts11.965(4)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)911.107Waddenteam1.760(17)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)896.0261KEY0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)810.919New_Folder165(88)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)807.258DPC_Team_Switch0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)801.733DukeBox0(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)774.767MaCCrunch0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)758.775Robbie_D47(99)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)748.735RdamRobin1.419(20)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)725.705STW165(89)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)618.559PeaceNlove1.695(19)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.105.916Maximum PC Magazine505.508.094(3)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)202.595Team Icrontic.com150.910.193(16)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)202.580SAGoons203.861.884(10)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)189.557NCIX.com Forum Folding Team77.217.766(29)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)189.090PC Perspective Folding Frogs (734)155.228.687(15)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)173.068Team 2ch76.700.656(30)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)168.845DSL Reports Team Helix127.586.322(17)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)167.556Team XPS - Folding@Home20.584.464(97)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)154.261Dutch Power Cows111.377.498(21)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)144.980Folding@SweClockers.com30.455.914(68)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)141.287ABXZone.com121.996.925(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)141.033Pande Lab45.235.674(50)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)140.900XCPUs.com23.139.461(84)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)138.451Blu-ray.com18.794.129(108)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)130.343Slickdeals13.725.738(135)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)129.493ClubLexus21.029.664(91)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)659.994.501Overclockers Australia837.690(3)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)156.276.519EOC Folding@Home Team233.422(16)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)155.228.687PC Perspective Folding Frogs (734)189.090(23)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)150.910.193Team Icrontic.com202.595(20)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)127.586.322DSL Reports Team Helix168.845(25)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)121.996.925ABXZone.com141.287(29)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)115.503.940p2p-community86.975(54)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)114.435.740Team Engadget257.405(13)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)111.377.498Dutch Power Cows154.261(27)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)105.975.094Team AnandTech223.974(17)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)104.136.466Overclock.net374.278(10)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)96.947.579OcUK212.159(19)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)92.242.0932ch@PS3249.108(14)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)87.145.205Overclockers Club104.609(44)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)85.474.951Team Hack-a-Day110.502(40)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)85.269.532SilentPCReview Folding@Home103.177(45)
More...
Megaflush Top 5
posTeamFlushDate
1.Team4Fun.nl202.70005-12-2005
2.markvanmook116.99631-10-2006
3.[DPC]_Team_ColdFusion89.74927-01-2008
4.Schapie29.66931-10-2006
5.chelloo.com26.83407-04-2007
More...
Mijlpalen
TEAM_JOE_BAR4.800.000
[DPC]Clan_Delft2.100.000
BPE600.000
Big_Basje5.000
Nephilith2.000
arg1.000
yanahabest1.000
JelleIV500
JeroenSmulders500
When do you get them
TeamAverageDays
p2p-community105.483109
ABXZone.com117.702416
Nieuwe Leden
Fossalta50
JG47
RedNalie1.760
Folding@Home Links
Folding@Home webpage
Folding@Home forum
DPCH Suggestiepagina
DPC FAQ
Bron
| [Folding@Home] Announce: Client monitor voor Linux (fci) | fci-1.8.4 | Fatal Error Group |
/me zijn pc heeft het begeven vannacht. opvallend is het wel. draait 2 jaar geweldig onder windows. staat nog geen 12 uur lang linux op en hij geeft de geest :) straks eerst op vakantie en na de vakantie koe wel weer reanimeren
Verwijderd schreef op woensdag 26 maart 2008 @ 08:51:
Reanimatie moet binnen 15 minuten anders word het fataal
  • JohFraEl
  • Laatst online: 23-08 22:15
JohFraEl
Slainte!
S2K: Nogmaals bedankt voor de info en de stats! d:)b
Fijn dat ze het stabieler hebben gemaakt, ben benieuwd...
Kan ik de nieuwe client nog net een keer uitproberen voordat ik ga stampen :)
TJB en Clan Delft feli met de behaalde mijlpalen _/-\o_
Overige mijlpalers ook proficiat *O*
:w @ Brabo's
Welkom Fossalta, JG & RedNalie bij de DPC vouwstal 8)
Verwijderd schreef op woensdag 26 maart 2008 @ 08:54:
Koeien kunnen reïncarneren hè :+
Soul gecondoleerd met de overleden koe }:| en alvast 'n prettige vakantie :w
[ Voor 29% gewijzigd door JohFraEl op 26-03-2008 08:59 ]
Winter | 1st T-net Review
  • WolterB
  • Laatst online: 03-11 07:53
5 teams/users boven de 10k, een prachtprestatie _/-\o_
Gefelcitieerd iederen :w
Desktop | MediaCenter | Server | Laptop
Als de stampede voorbij is; zet ik totaal vier cores erbij voor fah :)
  • jeronimo
  • Laatst online: 20:00
Thuigekomen en m'n linux SMP bak bekeken, blijkt deze stil te staan, gestruikeld over een P2619 en de A2 core.
29
30
31
32
33
34
[06:43:11] + Processing work unit
[06:43:11] Core required: FahCore_a2.exe
[06:43:11] Core found.
[06:43:11] Working on Unit 02 [July 19 06:43:11]
[06:43:11] + Working ...
[06:43:11]
[06:43:11] *------------------------------*
[06:43:11] Folding@Home Gromacs SMP Core
[06:43:11] Version 1.91 (2007)
[06:43:11]
[06:43:11] Preparing to commence simulation
[06:43:11] - Ensuring status. Please wait.
[06:43:29] - Looking at optimizations...
[06:43:29] - Working with standard loops on this execution.
[06:43:29] - Previous termination of core was improper.
[06:43:29] - Going to use standard loops.
[06:43:29] - Files status OK
[06:43:29] Error: Work unit read from disk is invalid
[06:43:29] Finalizing output
[06:43:32] (decompressed 68.4 percent)
[06:43:32] 85 (decompressed 68.4 percent)
[06:43:32]
[06:43:32] Project: 2619 (Run 8, Clone 434, Gen 0)
[06:43:32]
[06:43:33] Entering M.D.
[06:43:49] s  (0%)
[06:43:49] d 10 out of 125000 steps  (0%)
[06:44:02] CoreStatus = 1 (1)
[06:44:02] Client-core communications error: ERROR 0x1
[06:44:02]
Folding@Home will go to sleep for 1 day as there have been 5 consecutive Cores executed which failed to complete a work unit.
[06:44:02] (To wake it up early, quit the application and restart it.)
[06:44:02] If problems persist, please visit our website at http://folding.stanford.edu for help.
[06:44:02] + Sleeping...
Nu lees ik hier : http://foldingforum.org/v...89&start=0&st=0&sk=t&sd=a dat er meer mensen zijn met dit probleem. Een van de ruwe kantjes van de beta client....
Update van het folding forum:
by kasson on Thu Mar 27, 2008 12:24 am
As toTOW alludes, we've had a couple reports of A2 failures with AMD X2 CPU's. There may be a problem with the SSE testing code here. Or it may be coincidence. I'm meeting with one of the lead Gromacs developers in the next week or two; I'll try to ask him about it. The SSE code is pretty low-level...
Ik heb m'n koetje maar even uit gezet :'(
[ Voor 11% gewijzigd door jeronimo op 27-03-2008 00:41 ]
