Jvc Boombox welke adapter?
  • 1.265 views
Hey,
Ik heb een Jvc rv-b55gy boombox
Afbeeldingslocatie: http://www.avprime.co.kr/prod_image/rv-b550bu.jpg
Maar ik wil hem via adapter aansluiten
12volt dc (gelijkspanning)
Maar nu zie ik verschillende soorten adapters met Uitgangsstroom 300 mA of 400 mA of 500 mA of 800 mA
Wat is hier nou het verschil van en wat moet mijn boombox hebben? kan het nergens vinden op internet en nee heb geen boekje meer.
Alvast bedankt
  • Tyrian
Tyrian
It's Unreal.
Manual:
SPECIFICATIONS
CD player section
Type : Compact disc player
Signal detection
system : Non-contact optical pickup
Number of channels : 2 channels
Frequency response : 20 Hz - 20,000 Hz
Signal-to-noise ratio : 90 dB
Wow & flutter : Less than measurable limit
Radio section
Frequency range : FM 87.5 - 108 MHz
AM: (MW) 522 - 1,629 kHz
(LW) 144-288 kHz
Antennas : Telescopic antenna for FM
Ferrite core antenna for AM (MW/LW)
Tape deck section
Track system : 4-track 2-channel stereo
Motor : Electronic governor DC motor for capstan
Heads : Hard permalloy head for recording/playback, 2 gap ferrite
head for erasure (Combination head)
Frequency response : 60 - 14,000 Hz
(with CrO2 tape)
Wow & flutter : 0.15% (WRMS)
Fast wind time : Approx. 150 sec (C-60 cassette)
General
Speakers
(Impedance) Full range: 10 cm x 2 (4 W)
Power output : (Max.)
26 W (13 W +13 W) at 4 W
(10% THD)
20 W (10 W + 10 W) at 4 W
Input terminals : AUX IN (300 mV/47 kW)
Output terminals : PHONES (Output level: 0 - 12 mW/ch, 32 W, Matching
impedance: 16 W - 1 kW)
Power requirements : AC 230 V, 50 Hz
DC 12 V (“R20/D (13F)” batteries x 8)
Ext. DC 12 V (car battery via optional CA-R120E car
adapter)
Power consumption : 27 W (with SW ON)
3.0 W (with SW STANDBY)
Dimensions : 541 (W) x 215 (H) x 259 (D) mm, including knobs
Mass : RV-B55 GY/BU
6.2 kg (without batteries)
7.1 kg (with batteries)
RV-B55 LTD
6.3 kg (without batteries)
7.2 kg (with batteries)
Accessories provided : AC power cord x 1
Remote control unit (RM-RXVB55E) x 1
R6/AA (15F) batteries x 2
Shoulder strap x 1
Design and specifications are subject to change without notice.
Er staat dus alleen dat het DC 12v moet zijn.
http://www.hypercoop.tk | GW user page | GW2 user page
Specs
  • Gizz
  • Laatst online: 12:49
Gizz
Dunder-Mifflin, Inc.
Tyrian schreef op zaterdag 22 maart 2008 @ 03:16:
Manual:
Nee hoor (en moet je zo'n hele lijst in 1x neergooien? :P )
uit jouw quote:
Dus 27w/12v= 2,25 ampère.
jhup, dus maakt niks uit 300 of 800mA of 2ampere ??
Lezen bockkie, als je 'm goed wil opendraaien heb je een adapter van dik 2 ampere nodig...
zag het gizz had net erdergepost dan mij vandaar dat het een vage reactie werdt.
  • teacher
  • Laatst online: 12:28
teacher
Dysgaf!
mja.. los van de bovenstaande drankpost :+ is dit wel een hele erge RTM vraag.
Iets meer eigen inzet graag?
Wise enough to play the fool
