[XP] IRQL_NOT_LESS_OR_EQUAL
Ik heb een tijdje last van wisselvallige blauwe schermen, ik heb via widows debugger de fout code eruit gepakt. Ik snap er alleen niet veel van, hoe zou ik dit kunnen oplossen?
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000000A, {1add00, 2, 1, 804ffe44}
Probably caused by : ntkrnlpa.exe ( nt!KiTimerExpiration+84 )
Followup: MachineOwner
kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 001add00, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: 804ffe44, address which referenced memory
Debugging Details:
WRITE_ADDRESS: 001add00
CURRENT_IRQL: 2
FAULTING_IP:
804ffe44 893b mov dword ptr [ebx],edi
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: Idle
LAST_CONTROL_TRANSFER: from 8054197d to 804ffe44
STACK_TEXT:
80549a2c 8054197d 80552ba0 00000000 00009400 nt!KiTimerExpiration+0x84
80549a50 805418f6 00000000 0000000e 00000000 nt!KiRetireDpcList+0x46
80549a54 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x26
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!KiTimerExpiration+84
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrnlpa.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 471e0621
FAILURE_BUCKET_ID: 0xA_W_nt!KiTimerExpiration+84
Wie kan me helpen? Duid dit op kapot geheugen of wat?
Dank _/-\o_
  • Sebazzz
  • Laatst online: 12-10 13:02
Sebazzz
3dp
Ja, vaak wel. Zie de GoT search voor meer informatie over dit onderwerp.
Gooi er eens een geheugentest er over heen
Ik heb al memtest 16 uur gedraait. Had het op een cd gebrand en in me pc gedaan. Hij had de test iets van 10 keer gedaan. Is dit genoeg?
  • Kixtart
Kixtart
Destruction = Improvement
Nog resultaten ontvangen van die tests?
Verwijderd schreef op maandag 17 maart 2008 @ 15:57:
heb je ook rode dingen voor bij zien komen, zo ja dan geeft aan dat er 1 van de geheugen kaarten kapot is
Nee 0 fouten heb maar 1 geheugenbankje btw
  • lier
  • Laatst online: 21:57
lier
MikroTik nerd
Ik dacht dat de IRQL_NOT_LESS_OR_EQUAL meestal op een driver probleem duidt...?
Controleer eens of er driver updates zijn en of er een bios update beschikbaar is.
Verder zou je op Google kunnen zoeken naar deze foutcode, hij sis namelijk nogal sterk afhankelijk van de hardware (hint...die mis ik nogal een beetje in je TO)
[ Voor 33% gewijzigd door lier op 17-03-2008 16:09 ]
  • ik222
  • Wiethoofd
  • Laatst online: 30-09 23:41
Wiethoofd
Broadcast TOM
ik had ook deze fout, gewoon overklok iets terugzetten en voila, geen BS(OD)'s meer
welke geheugen heb je btw
aan het overklokken geslagen met te langzaam geheugen?
welke CPU heb je en de snelheden?
Ik heb deze melding een tijdje terug gehad bij een kennis, bleek aan een spelletje te liggen (Zylom games).
Maar ik was begonnen met de standaard dingen (memtest/prime) drivers updaten.
Hierna het spelletje eraf gehaald en is nog nooit weer voorgekomen.
  • Haaglander
lier schreef op maandag 17 maart 2008 @ 16:08:
Dacht ik ook.
Ik doe niet aan overklokken. Het is een standaart hp palivion pc net openieuw geinstaleerd. Heb het probleem nogsteeds:(
  • Wiethoofd
Wiethoofd
Broadcast TOM
Verwijderd schreef op maandag 17 maart 2008 @ 16:17:
probeer je geheugen eens in een ander slot(en), nog steeds fout, probeer een ander stipje geheugen, geen fouten meer, dan was je geheugen stuk
  • Kixtart
Kixtart
Heb je het via een recovery gedaan of clean windows install? In het 2e geval ben je misschien gewoon drivers vergeten te installeren.
Kan je verder nog aangeven wat je al gedaan hebt?
Wiethoofd schreef op maandag 17 maart 2008 @ 16:21:
Verwijderd schreef op maandag 17 maart 2008 @ 16:04:
[ Voor 55% gewijzigd door Kixtart op 17-03-2008 16:23 ]
geheugen heb ik al in een ander bankje gedaan. ook geen resultaat.
Heb een verse windows xp er op gezet zonder drivers, daarna drivers gedownload en geinstaleerd. Geen succes. Daarna nog via recoverymode van hp. Werkte ook niet.
Als ik men geheugen test. Hoelang moet het dan gebeuren en moet je bij memtest nog andere instellingen gebruiken?
  • Wiethoofd
Wiethoofd
Broadcast TOM
Verwijderd schreef op maandag 17 maart 2008 @ 16:26:
Memtest op standaard instellingen en voor 5 runs oid (zou bij mij 15 uur nemen)
probeer als eerstvolgende oplossing eens een ander stripje geheugen
  • Kosh66
  • Laatst online: 06-10 14:45
Wat is het laatste software-pakket wat je geïnstalleerd hebt, voordat het systeem problemen opleverde?
Toevallig de Video-/Audio-drivers? Kijk eens of er inmiddels updates van zijn...
(Installeer ook liever geen beta-drivers, deze kunnen zulke problemen opleveren...)
  • Kixtart
Kixtart
Is het trouwens SP2, want dan zou het ook dit kunnen zijn.
Stop error message in Windows XP with Service Pack 2: "STOP 0x0000001a: MEMORY_MANAGEMENT" or "STOP 0x0000000a: IRQL_NOT_LESS_OR_EQUAL"
Alles al laten updaten van XP autoupdate?
[ Voor 7% gewijzigd door Kixtart op 17-03-2008 16:42 ]
  • Nock372
  • Laatst online: 08-10 07:24
Ik had dit probleem ook dit was op een fatal1ty an8-sli moederbord en waneer ik de driver van de onboardnetwerkkaart niet instaleerde had ik geen BSOD's meer, Dit heb ik opgelost door een pci gigabit lan kaartje erin te steken.
34,06kwp installatie, full electric
