AMD 64 3200+/2048MB/MSI K8N/2x Seagate 200GB SATA/Seagate 160GB/Seagate 320GB/LG GSA4120B DVDRW/nVidia 6800 XT/SB Audigy 2 ZS/DSL:20/1 - Telfort/21" Samsung SyncMaster 215TW/ToUCam Pro/WinXP Pro
Ben je na windows begonnen met via usb filter??
How should I install the software for my new motherboard?
You should install Windows with only a basic system configuration - disk, graphics card, CDROM and memory. Nothing else. Follow the software installation order given below. Having achieved a stable system like this, you should then introduce all your other cards one-by-one. Please read "Thanks for theory, but which slots should I put my PCI cards in?!" in the instabilities section for AMD's advice on the correct order in which to introduce your peripherals. This gives useful advice that should prevent many problems.
A clean install of the operating system is recommended. The following installation procedure is known to work for Windows 98SE and Me, and can be easily adapted to Windows 2000:
For a really clean boot ... boot into DOS using a floppy, then:
- Use FDISK to create DOS partition on disk (!!this destroys existing data on disk!!)
- FORMAT C: /S to format disk (use /Q for quick format) (!!this destroys existing data on disk!!)
Install Windows
Install latest VIA 4in1 service pack
Install latest VIA USB filter driver (under all Windows 9x versions after Windows 95 OSR2 and above)
Install Microsoft VIA USB patch (on Windows 98 or 98SE)
Install latest DirectX and latest patches
Install latest video drivers
Add sound card and then install latest sound card drivers
Install latest HPT370 software (on the KT7-RAID and KT7A-RAID)
And other devices one by one, and Install their latest drivers, e.g. joystick, graphics tablet, etc
Install applications
Confirm the system is working and then tweak BIOS if required
Install Windows
Hmm.. nee.. alle USB apparaten zaten er al in en installeerden dus tegelijk. Heeft altijd gewerkt op mn vorige systeem (PII-300, Soyo BX mobo)...
Zo te zien zijn er geen USB filter drivers voor Win2k maar ik zal eens zoeken op de VIA site.. ik heb eigenlijk geen tijd/zin om weer van scratch alles te installeren (kost me weer ruim 2 dagen), maar als het moet...
ik ben met dat usb echt jaren bezig geweest.
uiteindelijk had ik m'n isdn kaart eruit gehaalt (deelde niet eens een irq) en het werkte opeens.
Argh.. die VIA USB drivers zorgen er in Win2k juist voor dat USB het helemaal niet meer doet!!
Ik heb de hardware in device manager uninstalled (alle USB devices + USB ports etc.) en opnieuw opgestart.. één voor één de USB devices er weer in, drivers opnieuw geinstalleerd.. en het werkt nog steeds niet
Ik ben de wanhoop nabij.. please anybody help?
wat ik altijd doe:
gooi alle kaarten behalve je video kaart (duh) eruit, en dan kijken of usb goed werkt. werkt het goed, kan je 1 voor 1 kaarten erbij gooien. installeer dan gewoon de via 4in1 en doe niks bijzonders aan usb.
dat probleem had ik eerst ook, moet je ff in de bios veranderen bij advanced setting's ofzo.
eerst de drivers, dan pas de apparatuur erin steken.
let maar op eind van t jaar, als WinXP er is, is zeer strict in dit soort zaken...
Ik heb ook heel lang zitten klooien met USB devices die spontaan uitvielen op mijn Abit KT7 Raid. Volgens een internet site (ik geloof http://www.usbman.com) was de beste oplossing bij VIA chipsets zoals deze en USB problemen om gewoon de onboard USB controller te disabelen en een (niet VIA) USB kaart te gebruiken.
Dat heb ik gedaan en het werkt prima nu!
