Hello,
I have been busy the last 2 weeks to unlock the Medion MD 96430.
I have created a new Shell called ¥0SHELL 1.3 with loads of new functionality:
  • GPS Gopal ME 4.0
  • Berlitz Travel Guide
  • TCPMP 0.72 Media Player: plays Audio, Photo's and Video: MP3/MP4/AVI/AC3/OGG/WMA/MPEG/DIVX/FLAC/JPEG
  • Picture Viewer
  • Alarm Clock
  • Scientific Calculator Q-Calc 0.95
  • Pocket Notepad 4.0
  • SpreadCE 2.02: Excel compatible SpreadSheet
  • File Explorer
  • Pocket XPDF 0.5 PDF Reader
  • MNote 1.21 MP3 Voice Recorder
  • XClock 1.1 Analog Clock and Calendar
  • Flash Player
  • Control Panel
  • Flashdisk SD Card and Memory Inspector
  • Task Manager 2.9 with registry Editor
  • Battery Status
  • Date/Time
Here are some screenshots:
Page1:
Afbeeldingslocatie: http://www.vanbarel.com/images/shell1.jpg
Page2:
Afbeeldingslocatie: http://www.vanbarel.com/images/shell2.jpg
Page3:
Afbeeldingslocatie: http://www.vanbarel.com/images/shell3.jpg
You can download the latest version of ¥0SHELL 1.3 here:
*weg*
Here is more information:
¥0Shell v1.3
Author: ¥0& 17-02-2008
about:
¥0Shell is a replacement shell for the Medion MD 96430 GOPAL ME 4.0 Pocket Navigator.
This shell replaces the default startup shell of the Medion MD 96430.
It adds some extra PDA and Multimedia functionality.
You can always reset to the Medion factory default shell.
Features:
-GPS Gopal ME 4.0
-Berlitz Travel Guide
-TCPMP 0.72 Media Player: plays Audio, Photo's and Video: MP3/MP4/AVI/AC3/OGG/WMA/MPEG/DIVX/FLAC/JPEG
-Picture Viewer
-Alarm Clock
-Scientific Calculator Q-Calc 0.95
-Pocket Notepad 4.0
-SpreadCE 2.02: Excel compatible SpreadSheet
-File Explorer
-Pocket XPDF 0.5 PDF Reader
-MNote 1.21 MP3 Voice Recorder
-XClock 1.1 Analog Clock and Calendar
-Flash Player
-Control Panel
-Flashdisk SD Card and Memory Inspector
-Task Manager 2.9 with registry Editor
-Battery Status
-Date/Time
Installation:
01-Connect your Medion MD 96430 via ActiveSync to your pc.
02-Make a backup of de Medion folder "My Flash Disk", since this folder will not be restored after a hard reset.
03-Note: After installing ¥0Shell, you can always return to the factory default Medion settings using the hardreset option (On/Off switch). The On/Off switch at the bottom of the Medion will reset to factory default, which means that all folders will we reset from Rom except the "My Flash Disk" folder.
04-Unzip ¥0Shell.zip to a temporary folder on your harddisk. You will find a folder called "Apps" with subdirs.
05-Copy the "Apps" folder to your Medion at "My Flash Disk\Apps". If you don't have enough free space, you can backup some .psf maps from the "My Flash Disk\MapRegions" to your harddisk.
06-Copy the folder "My Flash Disk\Apps\HardReset\Navigation" over the folder "My Flash Disk\Navigation". This will overwrite the SplashScreen from the Navigation program.
07-Copy the folder "My Flash Disk\Apps\HardReset\Windows" over the folder "Windows" in the root. This will overwrite some system files to enable ¥0Shell to start after softreset.
08-Rename \my flash disk\navigation\shell.exe to shell1.exe (so the Gopal shell does not start).
09-Soft Reset your Medion (Press Start button on top and Press the right most button on the screen).
10-¥0Shell will now start after softreset.
11-Finalise installation by setting some registry settings: Click the Folders Icon and navigate to "My Flash Disk\Apps\HardReset" and double click "RegReset". Close the Explorer.
12-¥0Shell is now ready for use. Enjoy!
Tip: if you want to use the multimediacapabilities, it is best to insert an SD card. Create the following folders on the SD card: Flash, Music, Notes, PDF, Photo, Sheet, Video.
Some Usage Tips:
-There are currently 3 menu screens:
You can jump to the next screen by touching somewhere in the bottom-right of the screen.
You can jump to the previous screen by touching somewhere in the bottom-left of the screen.
-There are 4 hotkeys defined:
Key1: Close current application
Key2: Start Explorer. If pressed for >1.5 seconds it will show/hide the Taskbar.
Key3: Rotate screen 90 degrees. If pressed for >1.5 seconds it will show the MoveWindow applet.
Key4: Toggle keyboard panel on or off. If pressed for >1.5 seconds it will start the Task Manager.
-If you press the bottom of the screen with your stylus, the Taskbar will show or hide. You can activate the Taskbar by touching the bottom-left corner (like Windows).
-Some windows, like the Voice recorder NoteM , will not show a close button. You have to close this window using Key1.
-Some windows may need text-input. You can show/hide the keyboard panel using Key4.
-If you start the Mediaplayer TCPMP, the function keys are redefined:
Key1: locks and blanks the touchscreen (useful when using your mp3 player in your pocket). Unlock by using Key1 again.
Key2: will jump to the next song, photo, ...
Key3: Volume UP
Key4: Volume Down
-If for some reason you need to hardreset your Medion, you have to redo the following installation steps: step 07, 08, 09, 10
-If you want to reset to factory default: do a hardreset (On/Off switch) and restore your backup of "My Flash Disk" you made in step 02
ToDo:
-Games are not yet functional: I am working on a GameBoy emulator for the Medion.
-Agenda is not yet functional.
-Flash player only plays one flash
-Navigation Splash Screen
[ Voor 0% gewijzigd door pven op 17-02-2008 19:14 ]
There is some more work to do, so feel free to make some suggestions.
Here are some ToDo's:
  • Games are not yet functional: I am working on a GameBoy emulator for the Medion.
  • Agenda is not yet functional.
  • Flash player only plays one flash
  • Navigation Splash Screen
Does someone have a good Agenda (Calendar+Tasks) running on Windows CE?
Feel free to comment!
¥0&
  • pven
Dutch please ...
[ Voor 32% gewijzigd door pven op 17-02-2008 19:07 ]
|| Unprompted (AI-blog) || slotje.com for sale || Dank pven! ||
