[SLACK] Flash-plugin installatie
  • Koentjá
  • Laatst online: 04-12-2025
Op mijn linux bak lukt het mij niet op Flash-player te installeren! Ik heb verschillende bestand extensies geprobeerd rpm ,tar.gz etc. Bij het Compileren lukt het al behoorlijk maar daar loop ik steeds vast bij het installatie pad van de browser want dan geeft hij een foutmelding terwijl het toch goed is :? . Ik laat wel zien wat ik allemaal gedaan heb! ;)
RPM
29
30
31
root@koen:~# rpm -i --allfiles flash-plugin-9.0.115.0-release.i386.rpm
error: Failed dependencies:
        /bin/bash is needed by flash-plugin-9.0.115.0-release
        /bin/sh is needed by flash-plugin-9.0.115.0-release
        libX11.so.6 is needed by flash-plugin-9.0.115.0-release
        libXext.so.6 is needed by flash-plugin-9.0.115.0-release
        libXt.so.6 is needed by flash-plugin-9.0.115.0-release
        libc.so.6 is needed by flash-plugin-9.0.115.0-release
        libc.so.6(GCC_3.0) is needed by flash-plugin-9.0.115.0-release
        libc.so.6(GLIBC_2.0) is needed by flash-plugin-9.0.115.0-release
        libc.so.6(GLIBC_2.1) is needed by flash-plugin-9.0.115.0-release
        libc.so.6(GLIBC_2.1.3) is needed by flash-plugin-9.0.115.0-release
        libc.so.6(GLIBC_2.2) is needed by flash-plugin-9.0.115.0-release
        libc.so.6(GLIBC_2.3) is needed by flash-plugin-9.0.115.0-release
        libdl.so.2 is needed by flash-plugin-9.0.115.0-release
        libdl.so.2(GLIBC_2.0) is needed by flash-plugin-9.0.115.0-release
        libdl.so.2(GLIBC_2.1) is needed by flash-plugin-9.0.115.0-release
        libfontconfig.so.1 is needed by flash-plugin-9.0.115.0-release
        libfreetype.so.6 is needed by flash-plugin-9.0.115.0-release
        libglib-2.0.so.0 is needed by flash-plugin-9.0.115.0-release
        libgobject-2.0.so.0 is needed by flash-plugin-9.0.115.0-release
        libgtk-x11-2.0.so.0 is needed by flash-plugin-9.0.115.0-release
        libm.so.6 is needed by flash-plugin-9.0.115.0-release
        libm.so.6(GLIBC_2.0) is needed by flash-plugin-9.0.115.0-release
        libpthread.so.0 is needed by flash-plugin-9.0.115.0-release
        libpthread.so.0(GLIBC_2.0) is needed by flash-plugin-9.0.115.0-release
        libpthread.so.0(GLIBC_2.1) is needed by flash-plugin-9.0.115.0-release
        libpthread.so.0(GLIBC_2.2) is needed by flash-plugin-9.0.115.0-release
        libpthread.so.0(GLIBC_2.2.3) is needed by flash-plugin-9.0.115.0-release
        libpthread.so.0(GLIBC_2.3.2) is needed by flash-plugin-9.0.115.0-release
root@koen:~#
Ben ik miss. wat vergeten ?
Tar.gz (compileren)
29
30
31
32
33
34
35
36
37
38
39
40
root@koen:~# tar -xzvf install_flash_player_9_linux.tar.gz
install_flash_player_9_linux/
install_flash_player_9_linux/flashplayer-installer
install_flash_player_9_linux/libflashplayer.so
root@koen:~# cd install_flash_player_9_linux
root@koen:~/install_flash_player_9_linux# cd ./flashplayer-installer
bash: cd: ./flashplayer-installer: Not a directory
root@koen:~/install_flash_player_9_linux# ./flashplayer-installer
Copyright(C) 2002-2006 Adobe Macromedia Software LLC.  All rights reserved.
Adobe Flash Player 9 for Linux
Adobe Flash Player 9 will be installed on this machine.
You are running the Adobe Flash Player installer as the "root" user.
Adobe Flash Player 9 will be installed system-wide.
Support is available at http://www.adobe.com/support/flashplayer/
To install Adobe Flash Player 9 now, press ENTER.
To cancel the installation at any time, press Control-C.
NOTE: Please exit any browsers you may have running.
Press ENTER to continue...
Please enter the installation path of the Mozilla, Netscape,
or Opera browser (i.e., /usr/lib/mozilla): /usr/lib/mozilla
WARNING: Please enter a valid installation path.
Ik ben trouwens newbie met linux !
(heb al research gedaan en oudere flash player versies uitgeprobeerd)
Groeten! 8)
  • u_nix_we_all
Je hoeft niets te compileren. Je moet de .so file in de plugins directory van je browser zetten. That's all.
Bij mij is dat (voor mozilla en firefox) ~/.mozilla/plugins/
[ Voor 22% gewijzigd door u_nix_we_all op 08-02-2008 13:28 ]
You don't need a parachute to go skydiving. You need a parachute to go skydiving twice.
  • Koentjá
Bedank u_nix_we_all het is helemaal gelukt !
  • ph0t0nix
  • Laatst online: 06-10 09:13
De genoemde methode werkt wel, maar omdat je het bestand in je home-directory hebt geplaatst werkt het alleen voor jou. Eventuele andere gebruikers zitten nog steeds zonder Flash. Om de plugin systemwide beschikbaar te maken moet je 'm naar /usr/lib/mozilla/plugins kopiëren.
Succes!
  • Cyphax
  • Laatst online: 19:43
Cyphax
Moderator LNX/AI
Dat RPM verder die dependencies niet kan vinden komt omdat Slack niet RPM-based is, en al die packages niet met RPM geinstalleerd zijn. rpm --nodeps als je iets wilt installeren dat alleen in RPM beschikbaar is (de laatste keer dat ik OpenOffice installeerde moest het met RPM en op die manier).
  • Koentjá
Om even terug te komen op mijn topic ! ;)
Ik heb een reinstall van slackware gedaan en toen dropline-gnome geinstalleerd. Ik weet niet of dat dit de oorzaak is dat de Flash-plugin het niet wilt doen in Firefox. Want eerst deed ie het wel. :?
Ook als ik kijk naar about:plugins in Firefox zie ik niks van mijn Flash plugin installatie.
Edit* what the hell nou doet ie het in een keer ? Sorry voor het kicken ! :? :)
[ Voor 12% gewijzigd door Koentjá op 30-04-2008 13:38 ]
