Info over platina cd-r (ricoh)
  • 124 views sinds 30-01-2008
  • tweakerbee
  • Laatst online: 22-09 18:44
Hier een gaaf stukje info over PLATINUM recordables. Ze zijn beter dan gold >:)
Beyond Gold - Ricoh Platinum
Ricoh introduced the first Platinum media in 1997. Platinum CD-Recordable technology is based on Advanced Phthalocyanine dye, enabling high resistance to intense light, heat and humidity which can result in loss of stored data. The tested archival life of the CD is over 200 years! The Ricoh Platinum compact disc is the highest quality, most compatible, most durable CD-R disk ever!
With its unique combination of features, Platinum is ideal for any and all applications - audio recording, high speed duplication, data archiving, data back-up and software distribution. Platinum media has a Hardcoat layer which allows flexibility in labeling. Apply pre-printed labels or write directly on the disk with a felt pen. A water-based receptive layer, for inkjet printing, provides fast drying and sharp images. A white inkjet printable layer allows high quality color printing.
You can't have everything. Where would you put it?
