Ervaringen firmware Philips LCD 32PF9541 (32PF9551 32PF9641)
  • rick77
  • Laatst online: 30-09 08:25
rick77
... get to the point!
Ik heb na meer dan een jaar nog de originele firmware versie 0.48.24 op mijn Philips 32PF9541 staan. Nu zie ik dat er nogal wat dingen veranderd zijn:
Main modifications
BX31E_100.0
• improved EPG stability
BX31E_96.0
• picture stability improvement for 1080i/50Hz for YPbPr and HDMI
BX31E_95.0
• software is released for production purposes only - no software
upgrade required by the customer
BX31E_93.0
• improvement Greek character set when using Teletext (only when
country is set to Greece)
• improvement logical channel numbers extraction for Australia
• improved stability while watching digital Australian streams
BX31E_89.0
• improved picture stability
• improvement audio behaviour when using HDMI with STB-box
BX31E_88.0
• improvement in picture while watching certain channels in France
• improvement for “Canal +” decoder in France
• improvement for sound interruptions when using STB-box with
1080 via HDMI
BX31E_0.81.4.0
• easier selection of favourite channel lists (preferred TV channels &
radio stations). Please download the user manual for more
information on how to use.
• the 4 favourite lists have fixed names
• a Time zone feature in TV menu installation is added (for Spain
country only)
• the monitor out function from EXT1 and EXT2 is adapted to
facilitate recordings from the DVB TV tuner on EXT1 and EXT2
• “Exit” item in TV menu is removed.The menu can now also be
removed with the local menu key on the TV
BX31E_0.48.30.0
• improved stability of HDMI input on DVD players
• improved performance of HDMI 1080i sources
BX31E_0.48.27.0
• HDMI can be linked to analog audio in (AUDIO IN L/R) to support DVI
devices
BX31E_0.48.24.0
• improved HDMI support of skynet HD decoder
BX31E_0.48.20.0
• improved installation of digital channels
BX31E_0.48.19.0
• Automatic Update Installation enabled
• improved brightness behaviour when lightsensor is On
How to upgrade the TV software
Software history
BX31E_0.48.17.0
• new added supported countries for DVB-T :The Netherlands, Italy,
Greece, Czech Rep., Denmark
• improved overall picture quality
• improved Ambilight performance
• update for Settings Assistant
BX31E_0.48.15.1
• improved TV channel behaviour in Sweden for non-digital sets
BX31E_0.48.14
• enabling of 7/8 days EPG feature for UK
• improved clock and date extraction for DVB-T Italy
• improved colour behaviour on HD inputs
• improved overall picture stability for 26” display
BX31E_0.0.39.22
• improved standby mode behaviour
BX31E_0.0.39.20
• Time Zone menu item removed
BX31E_0.0.39.18
• menu item “Reshuffle/Rename channels” changed to “Rearrange”
• improved Teletext
• improved overall audio behaviour
BX31E_0.0.39.17
• DVB-T improvements for Boxer Certification in Sweden
BX31E_0.0.39.15
• added subtitle item in option list in case of English language in
AP/China sets
BX31E_0.0.39.14
• improved colours in Ambilight
BX31E_0.0.39.12
• improved sound performance and updated Chinese translation
BX31E_0.0.39.11
• improved picture stability on 1080i 60Hz sources for 42PF9631D/10
BX31E_0.0.31.12
• improved French and Chinese menu texts for AP sets
In het kader van de archieffunctie van dit topic is deze informatie misschien wel relevant. Als de firmware upgrades niet meer volgens de door Philips omschreven manier werken, is er deze workaround (de informatie schijnt ook van Philips af te komen):
Haal de stroom van het toestel, druk kort op de DVD-toets van je afsstandsbediening. Druk op cursor naar beneden en houd deze vast.
Schakel de stroom weer aan (onder het vasthouden van de cursor down toets).
De tv komt in een alternatief software upgrade menu.
Zet de afstandsbediening weer op TV en steek je USB stick in de aansluiting.
De upgrade wordt geinstalleerd.
Volg verder de normale procedure (zoals beschreven door Philips) voor herstarten.
Echter ik lees ook nogal wat negatieve berichten over de slechtere werking van Ambilight en het niet beschikbaar meer zijn van bepaalde opties (bijv. digital natural motion) op deze TV (of TVs met dezelfde (?) firmware) na een firmware upgrade. Een selectie:
http://www.kieskeurig.nl/...90BC6C12571E300439583.htm
http://www.kieskeurig.nl/...3208FC125713100526153.htm
Slecht beeld na firmware update 37pf9631
http://www.hifi-forum.de/viewthread-152-2136.html
Vragen:
- Wat zijn de ervaringen van GoT'ers met de verschillende firmwares. Welke versie heb je zelf draaien/geprobeerd/weer gedowngrade?
- Voor ik update zou ik graag een 'oude' zeker goedwerkende versie hebben. Heeft iemand nog oude versies beschikbaar naast de nu beschikbare firmware versie 000.100.000.000 op de Philips site? Misschien een idee om hier een archiefje van aan te leggen?
  • rick77
rick77
schopje
[ Voor 3% gewijzigd door rick77 op 01-02-2008 10:14 ]
