Fout in javascript : null is leeg of geen object
  • 1.527 views sinds 30-01-2008
Ik zoek me nu al dagen suf naar de oorzaak van bovenstaande fout, hier is het deel brontekst waar volgens mij de oorzaak zit.
In FF werkt het en in IE(7) krijg ik bovenstaande fout op regel 27 teken 2.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
<html><head
<link rel="stylesheet" type="text/css" href="css/newhook.css"><script language="JavaScript">
// F. Permadi May 2000
function getFlashMovieObject(movieName)
  if (window.document[movieName]) {
    return window.document[movieName];
  if (navigator.appName.indexOf("Microsoft Internet")==-1) {
    if (document.embeds && document.embeds[movieName])
      return document.embeds[movieName];
  } else { // if (navigator.appName.indexOf("Microsoft Internet")!=-1)
    return document.getElementById(movieName);
function StopFlashMovie()
    var flashMovie=getFlashMovieObject("myFlashMovie");
    flashMovie.StopPlay();
function PlayFlashMovie()
    flashMovie.Play();
function RewindFlashMovie()
    flashMovie.Rewind();
</script>
</head>
<body>
blabla ....
<div>
  <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="140" height="100">
      <param name="movie" value="mov/evl.swf" />
      <param name="play" value="false">
      <param name="flashvars" value="variablenaam=20">
      <embed src="mov/evl.swf" name="myFlashMovie" quality="medium" wmode="transparent" play="false" loop="false" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="140" height="100"></embed>
  </object>
<form name="controller" method="POST">
    <input type="button" value=">" name="Play" onClick="PlayFlashMovie();">
  <input type="button" value="||" name="Stop" onClick="StopFlashMovie();">
  <input type="button"  value="||<" name="Rewind" onClick="RewindFlashMovie();">
  </p>
</form></div>
Het is waarschijnlijk iets heel stoms dat ik gewoon over het hoofd zie.
link : http://www.enormevleeshaken.nl
  • BtM909
BtM909
Watch out Guys...
Ik krijg geen error in IE6. Heb je al een harde refresh geprobeerd?
En een gesimplificeerde pagina waarin je het probleem probeert te isoleren?
  • RM-rf
  • Laatst online: 23:23
RM-rf
1 2 3 4 5 7 6 8 9
getFlashMovieObject gaat dus fout en retourneert de null..
dat klopt, want die retouneert 'getelementById' en je flash-object heeft ook geen ID:
Id="myFlashMovie" toevoegen aan de object moet voldoen.
Intelligente mensen zoeken in tijden van crisis naar oplossingen, Idioten zoeken dan schuldigen
Natuurlijk,
Thx
  • danslo
  • Laatst online: 22:25
Verder moet je even kijken naar XSS gaten in je website, onder andere:
Linkje
[ Voor 5% gewijzigd door danslo op 16-01-2008 15:28 ]
Ik kan op google niet 1,2,3 vinden wat je tegen XSS gaten kunt doen.
  • danslo
Verwijderd schreef op woensdag 16 januari 2008 @ 15:55:
Het gaat er vooral om dat je $_GET variabelen goed escaped, dit kan onder andere met de htmlspecialchars() functie :)
