[PS2] Memor32
  • 2.093 views sinds 30-01-2008
Deze vind ik aardig intressant. Hoef je niks te solderen / open te maken, en kan je toch je back-up spellen spelen. En met in de toekomst ook via HD spellen te spelen.
Wie heeft er hier al ervaring mee?
Afbeeldingslocatie: http://www.plextor.nl/components/com_virtuemart/shop_image/product/44bf6c287d9a501e4586ae78adc8d042.gif
PS2 Memor32
( Memor32 )
Prijs per Eenheid (stuk): €59.00 (incl. 19 % btw) (bij www.plextor.nl)
Nieuw je kan met je usb je save games opslaan op je pc en eigen gemaakte software uploaden
Memor32 Features:
Enhance your game experience with a full 32 MB Memory card, store all your savegames on one memory!
Load and save PS2 savegames to and from any PC.
Share and exchange your savegames with friends and on our community forum!
Memor32 F.A.Q
What is Memo32?
Memor32 is the first and only solution availble to store, copy and exchange PS2 save games with your firends and over the internet.
Where can I find it?
You can find it in all the best Web Web-Shops and retail stores around the world. You can also find a list of shops in the Resellers section on this site. With what PS2 models or regions is the Memor32 compatible?
With all the PS2 models ever produced, from the very first until the latest model, USA/PAL/JAP.
What is the space available on the memory card?
It is a full 32 megabytes of available space.
What I need to do the first time I use the Memor32 in my PS2?
Simply insert the Memor32 in the first slot of your PS2, go the browser, select the memory Icon. You will be informed that the Memor32 in your PS2 needs to be formatted. Choose yes and wait until formatting is complete. You are now ready to use your Memor32 with your preferred games. How do I connect my Memor32 to my PC? Remove the Memor32 from your PS2, and connect it to your PC using a standard USB/MiniUSB cable.
How do I copy Save games from my Memor32 to my PC?
Once connected to the PC (see above), download and launch the Memor32 management software that is available in the Downloads section of our website.
Leuk dat je hoopt illegale games te spelen met dit ding, maar het slechts een memorycard die je ook met je pc kan verbinden waardoor je je savegames op je pc kan opslaan (wat wel interessant is) en omgekeerd.
Dit product wordt aangeboden als alleen een save-game naar PC kaart om wettelijke problemen te vermijden, maar met een aangepaste firmware er op kun je inderdaad 'backups' spelen. Om er 'backups' mee te spelen moet je de ISO eerst met een speciaal programma omzetten.
Aangezien je er 'backups' mee kan spelen mag je er alleen hier op Tweakers verder niet over praten, tenzij je toestemming hebt van de mods. Het DS Lite backup topic is daarvan een voorbeeld, al mag je daar ook niet praten over het "arm7 patchen" van roms aangezien ze dat bekijken als het kraken van de beveiliging. Dat is eigenlijk hetzelfde als er met dit apparaatje moet gebeuren om roms te laten werken, dus waarschijnlijk zal dit topic dus ook niet mogen. Het hypocriete is wel dat het "arm7 patchen" anders binnen in de software van een dergelijke kaart gebeurt, maar dat schijnt voor de mods geen bezwaar te zijn om het NDS Lite backup topic open te houden.
Tenzij je het misschien alleen over het draaien van homebrew wilt hebben, waar er best wel aardig wat van is voor de PS2. Dan zou je een mogelijk topic daarover meteen wat breder kunnen trekken naar het gebruik van producten als Swap Magic, waarmee dat allemaal ook kan en ook de PS2 niet open hoeft, maar het gevaar is wel dat het topic uit draait op een topic over het spelen van 'backups', wat nu met het DS topic ook voordurend gebeurt. Het vraagt dus nogal wat moderating inspanning van de mods om zo'n grijs topic toe te staan. Eerst met de mods overleggen dus, zoals in de regels van dit forum staat.
Over de save-games kunnen we het natuurlijk wel hebben hier, dus er hoeft niet perse een slotje op dit topic zolang we het alleen over de standaard firnware van dit apparaat hebben en niet meer :)
[ Voor 25% gewijzigd door Verwijderd op 10-01-2008 12:59 ]
