Welk moederboard zouden jullie kiezen?
  • 268 views sinds 30-01-2008
  • MitchellOnline
  • Laatst online: 21:17
Ik ben aan het twijfelen tussen 2 moederboarden, dus mijn vraag:
Welk moederboard zouden jullie kiezen van de volgende 2?
(Ik gebruik het moederboard in combinatie met een AMD Athlon 64 X2 Dual Core 6400+ Processor en wil tevens goed kunnen overclocken en kunnen gamen)
Moederboard 1: ALiveNF7G-HDready
Afbeeldingslocatie: http://www.asrock.com/mb/photo/ALiveNF7G-HDready.jpg
Socket AM2 for AMD Phenom™ X4 / X2, Athlon 64FX / 64X2 / X2 / 64 and Sempron processors
NVIDIA® GeForce 7050 / nForce 630A MCP Chipsets
AMD LIVE!™ Ready
Supports Dual Channel DDRII800/667/533 with 4 DIMM slots, maximum capacity up to 8GB
ASRock AM2 Boost: ASRock Patented Technology to boost memory performance up to 12.5%
Integrated NVIDIA® GeForce7 Series (NV44) DX9.0 VGA, Pixel Shader 3.0, Max. shared memory 256MB
1 x PCI Express x 16 slot
Hybrid Booster - ASRock Safe Overclocking Technology
Untied Overclocking : During Overclocking, FSB enjoys better margin due to fixed PCIE/ PCI Buses
Dual VGA Output: Support DVI-D and D-Sub ports by independent display controllers
Supports HDCP function with DVI-D port, to enjoy better quality with High Definition HDCP Encryption contents
Supports 720p Blu-ray (BD) / HD-DVD playback
NVIDIA® PureVideo™ Ready
4 x Serial ATAII 3.0 Gb/s, support RAID (RAID 0, RAID 1, RAID 0+1, RAID 5, JBOD), NCQ, AHCI and "Hot Plug" functions
Supports Gigabit LAN 10/100/1000 Mb/s
Supports 2 x IEEE 1394 ports (one port on back panel, one header on board)
HDMI_SPDIF header, providing SPDIF audio output to HDMI VGA card, allows the system to connect HDMI Digital TV/projector/LCD devices.
Chipset embedded HDMI Audio which supports HDMI signal through DVI-D port by using DVI to HDMI adapter (not bundled)
7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
Windows® Vista™ Premium 2007 Logo Ready
ASRock DVI_1394 I/O: 1 x VGA/DVI-D Port, 1 x VGA/D-Sub Port, 1 x IEEE 1394 port
Moederboard 2: M2A-VM HDMI
Afbeeldingslocatie: http://www.cool-prices.nl/pictures/artikelen/art7560_1_6612_150x150.jpg
Socket: AM2 ( 940 pins )
Chipset: AMD 690G ⁄ ATI SB600
Aantal geheugen sloten: 4
Ondersteunde geheugen modules: DDR2 800 ⁄ 667 ⁄ 533, met een maximum van 8 GigaByte aan werkgeheugen.
Uitbreiding sloten:
1 x PCI Express x16 slot
1 x PCI Express x1 slot
2 x PCI sloten
1 x Parallel-ATA UltraDMA 133 ⁄ 100 ⁄ 66
4 x Serial ATA 2 ondersteunt RAID 0, RAID 1, RAID10
Aansluitingen:
1 x Parallel poort
1 x PS⁄2 Muis
1 x PS⁄2 Keyboard
1 x IEEE 1394a ( FireWire )
1 x DVI
1 x VGA
4 x USB 2.0
1 x netwerk, PCIe Gb LAN 10 ⁄ 100 ⁄ 1000 Mbp⁄s
1 x Audio In ⁄ Uit, 6 kanaals ALC883
Bijzonderheden:
ASUS MyLogo2
ASUS CrashFreeBIOS3
ASUS EZ Flash2
ASUS Q-Fan
ASUS O.C Profile
ASUS Muziek Alarm
ASUS PC Probe II
ASUS LiveUpdate Utility
Anti -virus software (OEM versie)
  • Sebazzz
  • Laatst online: 13:02
Sebazzz
3dp
Persoonlijke voorkeur: Onderste.
Maar voor de rest: Zie policy, een tweaker behoort zelf te kiezen.
  • Format-C
  • Laatst online: 12-10 12:04
Format-C
Tracing Rays
BalusC in "PMG FAQ"
Welke processor/moederbord/geheugen moet ik nemen?
Zie hiertoe ook de Voor alle "Hoe is dit systeem?" vragen. Hier vallen "Wat kan ik het beste hieraan upgraden?" vragen dus ook onder :)
Tweaker? het komt concreet hierop neer: er wordt immers van een echte Tweaker verwacht dat hij/zij zélf zijn/haar eisen kan opstellen en daarna zélf op zoek gaat:
* check de specs/info/compatibiliteitslijsten op websites van desbetreffende fabrikanten
* bekijk/download de online handleidingen
* hier kun je moederborden filteren naar specifieke eisen
* hier kun je de "beste" combinaties opzoeken
* kies eventueel fabrikant(en) cq merk(en) die je het meest aanspreekt
* zoek wat reviews op: www.tweakers.net en www.google.com zijn zeer handig
* struin op GoT rond naar probleemgevallen/ervaringen
* vergelijk de prijzen op Pricewatch
* kijk eventueel bovenaan de Pricewatch lijsten welke het meest populair is
* weeg de voor- en nadelen tegen elkaar af
* maak uiteindelijk als échte Tweaker zijnde zélf je eigen keuze :Y)
Zelf uitzoeken kan geen kwaad.
Edit; no offense uiteraard. ;)
Ducati 899 Panigale / CM MB511/ 7800X3D @ ML360R/ RTX5090 Phantom/ Gbyte B650 GAMING PLUS/ 32GB G.Skill Z5 6000 CL30 A-Die/ Team M2 1TB/ 990Pro M2 1TB/ MX500 1TB/ 5TB SATA / Gbyte WBAX200/ Corsair 1000w/ Scarlett Solo / AOC AG493UCX/ LG 65" OLED TV
  • MitchellOnline
Sorry, dan gooi maar dicht :)
  • Nitroglycerine
  • Laatst online: 19:34
Nitroglycerine
Autisme: belemmering en kracht
Als je raid 5 denkt te gaan gebruiken zou ik de eerste nemen, anders de 2e.
Hier kon uw advertentie staan
  • kenneth
kenneth
achter de duinen
gewoon die eerste gebruiken, nergens last van, goeie kwaliteit.
  • Admiral Freebee
Over het algemeen zijn chipsets met een ingebouwde grafische kaart wel geen geweldige overklokkers dus in dat opzicht: geen van de twee ;)
Je zegt echter bitter weinig over je eisen, je budget en wat je zelf al gevonden had. Gewoon een lijstje met specificaties kopiëren is niet echt handig ;)
  • ik222
Voor gamen heb je een losse grafische kaart nodig, dan is het dus niet nodig dat die ook onboard zit. Ik zou dus geen van beide kiezen maar op zoek gaan naar een moederbord waar geen onboard video op zit en die dan aanschaffen i.c.m. met een fatsoenlijke grafische kaart.
Want bordjes met onboard GPU zijn over het algemeen minder goed over te clocken zoals hierboven aangegeven.
[ Voor 16% gewijzigd door ik222 op 05-01-2008 09:22 ]
  • dion_b
  • Laatst online: 22:03
dion_b
say Baah
"Welke ... moet ik kopen?"-topics zijn niet de bedoeling. Dit kun je zelf prima uitzoeken.
Oslik, blyat! Oslik!
