postgresql-server-7.4.17-1 installeren op VPS met CentOS 4.2
  • 293 views sinds 30-01-2008
  • brainsalad
  • Laatst online: 22-08 19:19
Hallo Allemaal,
Ik heb even hier een topic aangemaakt ivm dat ik eerder in een verkeerde hoek een topic had gestart.
De titel zegt het al, ik wil PostgreSQL draaiend hebben. Ik log in als root en doe een wget-je daarna rpm -ivh postgresql-server-7.4.17-1.RHEL4.1.x86_64.rpm
nu verschijnt deze informatie:
1.RHEL4.1.x86_64.rpm: V3 DSA signature: NOKEY,        key ID 443e1821
error: Failed dependencies:
        libc.so.6()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_6        4
        libc.so.6(GLIBC_2.2.5)(64bit) is needed by postgresql-server-7.4.17-1.RH        EL4.1.x86_64
        libc.so.6(GLIBC_2.3)(64bit) is needed by postgresql-server-7.4.17-1.RHEL        4.1.x86_64
        libcom_err.so.2()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1        .x86_64
        libcrypt.so.1()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x        86_64
        libcrypt.so.1(GLIBC_2.2.5)(64bit) is needed by postgresql-server-7.4.17-        1.RHEL4.1.x86_64
        libcrypto.so.4()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.        x86_64
        libdl.so.2()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_        64
        libdl.so.2(GLIBC_2.2.5)(64bit) is needed by postgresql-server-7.4.17-1.R        HEL4.1.x86_64
        libkrb5.so.3()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x8        6_64
        libm.so.6()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_6        4
        libm.so.6(GLIBC_2.2.5)(64bit) is needed by postgresql-server-7.4.17-1.RH        EL4.1.x86_64
        libnsl.so.1()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86        _64
        libpam.so.0()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86        _64
        libpq.so is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_64
        libpq.so.3()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_        64
        libreadline.so.4()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.        1.x86_64
        libresolv.so.2()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.        x86_64
        libssl.so.4()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86        _64
        libtermcap.so.2()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1        .x86_64
        libz.so.1()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_6        4
        postgresql = 7.4.17-1.RHEL4.1 is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_64
Nu begrijp ik als leek dat er software mist om postgresql te kunnen installeren.
Daarna ik gegoogled naar "lib centos4" maar zonder succes. Kan iemand mij adviseren welk rpm pakketje ik moet downloaden en installeren zodat ik postgresql kan installeren en deze foutmelding niet meer zie?
tot zo ver,
Brainsalad
  • brainsalad
Hmmz
Nu loop ik weet tegen het volgende probleem op:
Gegeven:
CentOS 4.2, draait op Xeon (x_86 packages)
VPS systeem
Ik begin met in te loggen als root
cd~
wget http://linux.duke.edu/projects/yum/download/3.2/yum-3.2.8-1.src.rpm
rpm -ivh yum-3.2.8-1.src.rpm
dan ga ik postgreSQL installeren:
# yum install postgresql-server-7.4.17-1.RHEL4.1
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
   No module named yum
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.3.4 (#1, Mar 10 2006, 06:12:09)
[GCC 3.4.5 20051201 (Red Hat 3.4.5-2)]
If you cannot solve this problem yourself, please go to
the yum faq at:
  http://wiki.linux.duke.edu/YumFaq
ik krijg dus een foutmelding.
Ik heb dus Yum niet goed geinstalleerd blijkbaar. Ik snap er niets van.
