VPS
  • 75 views sinds 30-01-2008
  • brainsalad
  • Laatst online: 22-08 19:19
Hallo allemaal,
Ik heb een VPS servertje geroggeld om twee weekjes mee te klooien, gebaseerd op Xeon server.
Hoerip staat geinstalleerd: CentOS4.2, Plesk is user interface zegmaar.
Nu wil ik Postgre postgresql-server-7.4.17-1.RHEL4.1.x86_64.rpm package gebruiken. De "oudere" versie is nodig omdat de software die ik wil draaien niet compatible is met 8.0.3 of hoger.
Ik log in als root en doe een wget-je daarna rpm -ivh postgresql-server-7.4.17-1.RHEL4.1.x86_64.rpm :)
nu verschijnt deze informatie
warning: postgresql-server-7.4.17-1.RHEL4.1.x86_64.rpm: V3 DSA signature: NOKEY,        key ID 443e1821
error: Failed dependencies:
        libc.so.6()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_6        4
        libc.so.6(GLIBC_2.2.5)(64bit) is needed by postgresql-server-7.4.17-1.RH        EL4.1.x86_64
        libc.so.6(GLIBC_2.3)(64bit) is needed by postgresql-server-7.4.17-1.RHEL        4.1.x86_64
        libcom_err.so.2()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1        .x86_64
        libcrypt.so.1()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x        86_64
        libcrypt.so.1(GLIBC_2.2.5)(64bit) is needed by postgresql-server-7.4.17-        1.RHEL4.1.x86_64
        libcrypto.so.4()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.        x86_64
        libdl.so.2()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_        64
        libdl.so.2(GLIBC_2.2.5)(64bit) is needed by postgresql-server-7.4.17-1.R        HEL4.1.x86_64
        libkrb5.so.3()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x8        6_64
        libm.so.6()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_6        4
        libm.so.6(GLIBC_2.2.5)(64bit) is needed by postgresql-server-7.4.17-1.RH        EL4.1.x86_64
        libnsl.so.1()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86        _64
        libpam.so.0()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86        _64
        libpq.so is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_64
        libpq.so.3()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_        64
        libreadline.so.4()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.        1.x86_64
        libresolv.so.2()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.        x86_64
        libssl.so.4()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86        _64
        libtermcap.so.2()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1        .x86_64
        libz.so.1()(64bit) is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_6        4
        postgresql = 7.4.17-1.RHEL4.1 is needed by postgresql-server-7.4.17-1.RHEL4.1.x86_64
Nu begrijp ik als leek dat er software mist om postgresql te kunnen installeren.
Daarna ik gegoogled naar "lib centos4" maar zonder succes. Kan iemand mij adviseren welk rpm pakketje ik moet downloaden en installeren zodat ik postgresql kan installeren en deze foutmelding niet meer zie?
tot zo ver,
Brainsalad
  • benoni
Zit er niet een wat slimmere pakkettenmanager op: yum?
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
En wat heeft dit met WEB te maken?
Ik verzoek je vriendelijk om je topic, en dan meteen met een titel die de lading dekt, in het juiste forum te openen. Ik zou 'm moven en renamen als ik geen kerstborrel had nu :P
Waar hoort mijn topic?
Je eigen tweaker.me redirect
Over mij
