Upgrade hulp gevraagd
  • 430 views sinds 30-01-2008
hier mijn systeempje;
(staat ook in bijlage)
< Processor >
Model: 1x Intel(R) Core(TM)2 CPU 6300 @
1.86GHz
Speed: 1.86GHz
Cores per Processor: 2 Unit(s)
Threads per Core: 1 Unit(s)
Type: Dual-Core
Internal Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way set,
64 byte line size
L2 On-board Cache: 1x 2MB, ECC, Synchronous, ATC, 8-way set, 64
byte line size, 2 threads sharing
< System >
System: Packard Bell BV IMEDIA MC 9520
Mainboard: Packard Bell BV Cuba MS-7301
Bus(es): ISA AGP PCI PCIe USB FireWire/1394
Multi-Processor (MP) Support: 2 Processor(s)
Multi-Processor Advanced PIC (:No
System BIOS: Phoenix Technologies, LTD 255.255
Total Memory: 1023MB DDR2-SDRAM
< Chipset 1 >
Model: VIA Technologies Inc Standard Host Bridge
Front Side Bus Speed: 4x 266MHz (1064MHz data rate)
Total Memory: 1GB DDR2-SDRAM
< Video System >
Monitor/Panel: Monitor VT700 Packard Bell
Adapter: NVIDIA GeForce 7600 GS
< Operating System(s) >
Windows System: Microsoft Windows XP (2002) Professional
Media Center 5.01.2600 (Service Pack 2)
Platform Compliance: Win32 x86
< Benchmark Results >
Dhrystone ALU: 17085 MIPS
Whetstone iSSE3: 11924 MFLOPS
Results Interpretation: Higher index values are better.
< Performance vs. Power >
Processor(s) Power: 45.7 W
< Performance Test Status >
Run ID: cp985167-a on donderdag 6 december 2007 at 14:
32:37
NUMA Support: No
SMP (Multi-Processor) Benchmar:No
Total Test Threads: 2
Multi-Core Test: Yes
SMT (Multi-Threaded) Benchmark:No
Processor Affinity: P0C0T0 P0C1T0
System Timer: 1.9GHz
Number of Runs: 64000 / 640
< Processor >
1.86GHz
Speed: 1.86GHz
Type: Dual-Core
< Features >
SSE Technology: Yes
SSE2 Technology: Yes
SSE3 Technology: Yes
Supplemental SSE3 Technology: Yes
SSE4.1 Technology: No
SSE4.2 Technology: No
EMMX - Extended MMX Technology:No
SSE4A Technology: No
HTT - Hyper-Threading Technolo:No
is allemaal een beetje veel, maar als ik post wat ik heb post ik ook alles
op dit moment kan ik niet cod4 spelen, zelfs op lage instellingen wil het niet lopen.
nu dacht ik eraan om er een Geforce 8600GTS in te zetten, maar ik weet niet met welk merk deze het beste presteert, zelf d8 ik aan XFX.
ook weet ik niet of die wel in mijn case past. ik heb nog steeds een standaard case met luchtkoeling.
1x ASUS ventilator.
op dit moment ligt mijn temperatuur rondom de CPU 32-38 graden.
mijn bedoeling was ook om er nog een 1GB RAM geheugen bij te zetten en ook de CPU over te clocken met extra koeling.
(denk ook dat ik een modcase nodig heb...)
dit alles wil ik "LATEN" doen door een winkel of een gewoon iemand die er veel verstand van heeft
mijn budget is ongeveer 200-250 euro. (exclusief kosten van het monteren enz.)
wat raden jullie mij aan?
B.V.D
zou erg blij zijn als jullie me hierbij zouden kunnen helpen.
het is namelijk een kerstcadeau ^^
  • GENETX
  • Laatst online: 14:50
Leuk: een Packard Bell... Zijn we altijd zo blij mee op GoT omdat ze zoveel mogelijkheden bieden...
Je kan beter een ATI Radeon HD 3850/3870 nemen als videokaart. Die maakt gehakt van de voorgestelde 8600GTS en kost niet veel meer iig.
Verder hoef je over overclocken niet te beginnen. Waarschijnlijk heb je toch een standaard BIOS waar je alleen de boot sequence en de datum en tijd in mag veranderen.
Download verder ook even CPU-Z en kijk:
1. Hoeveel dimms geheugen er in zit (1x 1GB of 2x 512MB)
2. Hoeveel geheugensloten er zijn.
Wat ik ook aanraadt is om volgende keer geen Packard Bell te nemen, maar gewoon bij een deskundige computerwinkel binnen te stappen en samen met hun een degelijk systeem inelkaar te zetten naar je wensen. En daarmee bedoel ik niet de Dixons :X
[ Voor 18% gewijzigd door GENETX op 06-12-2007 16:02 ]
  • dion_b
  • Laatst online: 13:07
dion_b
say Baah
PMG Beleid
Geef een exacte omschrijving van de hardware (mobo, CPU, koeler, geheugen, opschrift geheugenchips indien geheugengerelateerd, voeding, videokaart, geluid/netwerkkaart, etc.), noem wel de officiële merknamen en type-aanduidingen en geef beslist géén ellenlange uitdraai van een of ander diagnoseprogramma.
Los daarvan:
Sorry, maar dit is Gathering of Tweakers. We verwachten sowieso dat een Tweaker zelf eisen kan stellen aan een upgrade, relevante informatie kan zoeken en dan zelf kan kiezen, maar als je a) dat niet doet en b) ook nog eens zelf de upgrade niet wilt doen, waarom ga je niet gewoon bij een winkel langs voor advies? :o
:Z
Nee, we zijn wel blij zeker met dit soort slecht gefundeerde stemmingmakerij :/
Oslik, blyat! Oslik!
