Carmageddon TDR max pack
  • 476 views sinds 30-01-2008
Ik heb onlangs op een 3th party getweakte versie van het spel gestuit.
Hier hebben ze allerlei addon cars geadd en het spel Hi-res gemaakt met extra instellingen om het grafisch niveau op te krikken.
Ook enkele nieuwe power-ups hebben un weg in het spel gevonden.
Namelijk hover car of meteor car...
Sommige auto's passen zelfs maar net onder een 'checkpoint' :o
OPGELET: Je moet eerst het spel installeren voordat je de 3th party Max pack in actie kan zien.
Changelist
Added components:
- 22 cars added (150 in total, see readme for full list)
- 52+ skins for 35 original and add-on cars (also see readme for full car/skin list)
- 7 FFA Pro multiplayer tracks (modified powerup configuration)
- Spectator Mode 1.2
- Advanced Car/Track Changer 1.1
- completed save by X-Ray.
TDRLauncher 1.14.1 changes:
- Multiplayer add-in
- trainer: options to modify car damage
- fixed: options set in TDRLauncher will be re-applied on startup
- fixed: setting auto update check no longer slows down startup
- various code optimizations.
Changes/Fixes:
- MAX-Pack logos will be removed now when uninstalled
- compatibility fix: Nosebleed registry entries
- several small fixes, removed some unnecessary files
- fixed erroneous carnames.
tweakers.net< DOWNLOAD>
HOW TO PLAY CARMAGEDDON TDR 2000 ONLINE
(ENGLISH VERSION by SuicideGLK, based in BaB Hamachi Tutorial)
0. Install TDR 2000 + Max Pack 1.14f
1. Install Hamachi - http://www.hamachi.cc/ -
2. Run it.
3. It shows a box called "Hamachi Quick Guide" that you have to close and other box with 4 zeros with 'offline' state
4. Click the top-left button that is like suspend button in windowsXP
5. Now, in the "Create an account" box delete "Anonymous" word, write your nick a click "Create".
6. Wait few seconds for connection.
7. When you have connected you can see that the 4 zeros are an identification number. Where it says 'offline' now it says your nick and the suspend button now is green.
8. Click the left button of the right-down button. It show a little menu where you have to select "Join existing network..".
9. Under the line that says "Enter the name of the network you want to join", write "Carma666" and the other space write "carmageddon" (without commas), later, click "Join".
Het carma666 netwerk is dood dus laten we ons eigen starten?
Carma@Got
tweakers
Laat even weten of je interesse hebt in het multplayer gedeelte.
Kortom een oud bekend spel met nieuwe graphics en physics.
[ Voor 0% gewijzigd door blaataaps op 01-12-2007 19:45 ]
  • Vuurvoske
  • Laatst online: 22:57
Vuurvoske
Nunquam cede!
Kan je misschien wat screenshots posten? :)
Beroeps brabander | Battle.net: Vuurvoske#2782 | GamePC: 9800X3D, 32GB DDR5, B650, 9070XT, Fedora 44
Ik zet ook wat download links neer omdat die site soms wat streken vertoont met opera.
IE doet het goed en firefox en andere weet ik echter niet.
http://files.filefront.co.../;6225634;;/fileinfo.html
Of
http://wasted.polygonized...=download&id=382&mirror=1 1/2
http://wasted.polygonized...=download&id=382&mirror=2 2/2
Voor wat plaatjes http://gallery.filefront.com/De4mon/20995/355729/
  • Rone
Rone
Moderator Tweaking
Ben je er eerder niet op gewezen dat dit niet is toegestaan?
PC1: 9800X3D + RX 9070 XT
PC2: 5800X3D + RTX 3080
  • blaataaps
Wat een week geleden niet mocht, mag nu gek genoeg nog steeds niet.
[ Voor 13% gewijzigd door blaataaps op 01-12-2007 19:45 ]
