[2003] FRS-staging directory niet aan te passen
Goedemorgen,
Momenteel ervaren wij het volgende probleem op een Windows 2003 SE server met SP2:
Er is een drive verwijdert waar de frs-staging directory op stond voor een DFS root (g:\frs-staging).
Dit hebben we getracht aan ta passen a.d.v. de volgdende pagina: http://technet2.microsoft...9b0c6191033.mspx?mfr=true
Deze beschreven acties (via adsiedit frs-staging path aanpassen en register aanpassen) hebben we uitgevoerd. Hierna zou in de logfile de melding moeten komen dat de staging directory is aangepast:
In the Value data box, type the new staging area path, and then click OK.
When the service detects a change in the staging path, event ID 13563 is logged with a series of self-explanatory steps on how to proceed:
Event Type: Warning
Event Source: NtFrs
Event Category: None
Event ID: 13563
Date: 3/6/2005
Time: 7:13:01 PM
User: N/A
Computer: <Computer name>
Description: The File Replication service has detected that the staging path for the replica set DOMAIN SYSTEM VOLUME (SYSVOL SHARE) has changed.
Current staging path = E:\Windows\Sysvol\Staging\Domain
New staging path = E:\Frsstage
The service will start using the new staging path after it restarts. The service is set to restart after every restart.
It is recommended that you manually restart the service to prevent loss of data in the Staging folder.
To manually restart the service do the following:
[1] Run "net stop ntfrs" or use the Services snap-in to stop File Replication service.
[2] Move all the staging files corresponding to replica set DOMAIN SYSTEM VOLUME (SYSVOL SHARE) to the new staging location. If more than one replica set are sharing the current staging folder then it is safer to copy the staging files to the new staging folder.
[3] Run "net start ntfrs" or use the Services snap-in to start File Replication service, followed by "net start ntfrs".
Echter deze melding komt niet.
Server is gereboot, aanpassingen zijn gemaakt terwijl frs service was gestopt. Dit maakt geen verschil.
Op internet kom ik dit probleem vaker tegen, echter staat er nooit een oplossing bij. Iemand die een oplossing weer _/-\o_
NB. FRS voor sysvol verloopt wel naar behoren.
Iemand een idee?
