Carmageddon TDR2000 Max pack
  • 114 views sinds 30-01-2008
Ik heb onlangs op een 3th party getweakte versie van het spel gestuit.
Hier hebben ze allerlei addon cars geadd en het spel Hi-res gemaakt met extra instellingen om het grafisch niveau op te krikken.
Changelist
Added components:
- 22 cars added (150 in total, see readme for full list)
- 52+ skins for 35 original and add-on cars (also see readme for full car/skin list)
- 7 FFA Pro multiplayer tracks (modified powerup configuration)
- Spectator Mode 1.2
- Advanced Car/Track Changer 1.1
- completed save by X-Ray.
TDRLauncher 1.14.1 changes:
- Multiplayer add-in
- trainer: options to modify car damage
- fixed: options set in TDRLauncher will be re-applied on startup
- fixed: setting auto update check no longer slows down startup
- various code optimizations.
Changes/Fixes:
- MAX-Pack logos will be removed now when uninstalled
- compatibility fix: Nosebleed registry entries
- several small fixes, removed some unnecessary files
- fixed erroneous carnames.
Het volledige spel met alle goodies kan je hier downloaden
*knip
Afbeeldingslocatie: http://static3.filefront.com/images/personal/d/De4mon/20995/vdguufanth.jpg/
HOW TO PLAY CARMAGEDDON TDR 2000 ONLINE
(ENGLISH VERSION by SuicideGLK, based in BaB Hamachi Tutorial)
0. Install TDR 2000 + Max Pack 1.14f
1. Install Hamachi - http://www.hamachi.cc/ -
2. Run it.
3. It shows a box called "Hamachi Quick Guide" that you have to close and other box with 4 zeros with 'offline' state
4. Click the top-left button that is like suspend button in windowsXP
5. Now, in the "Create an account" box delete "Anonymous" word, write your nick a click "Create".
6. Wait few seconds for connection.
7. When you have connected you can see that the 4 zeros are an identification number. Where it says 'offline' now it says your nick and the suspend button now is green.
8. Click the left button of the right-down button. It show a little menu where you have to select "Join existing network..".
9. Under the line that says "Enter the name of the network you want to join", write "Carma666" and the other space write "carmageddon" (without commas), later, click "Join".
Misschien zijn er nog wel andere die het willen uitproberen of mee helpen nieuw leven in het multiplayer te blazen.
Carma@Got
tweakers
Ik speel op een centrino 1.7 with een ati 9600 (laptop) en kan alles open op zeer hoge resolutie spelen. Ook force feedback zit erin.
Kortom een oud bekend spel met nieuwe graphics en physics helemaal gratis.
[ Voor 0% gewijzigd door Crash op 20-11-2007 15:46 ]
  • Vos
  • Laatst online: 23:09
Vos
AFCA
Oei, heb dat spel heel wat uren gespeeld. Zal het thuis eens installeren.
#36
  • CartmanMMA
  • Laatst online: 22-04 12:03
CartmanMMA
Fallus Giganticus
Zoveel gelachen om dit spel vroeger. Good old memories.
Misschien kunnen we allemaal eens online spelen.
Kheb via dat tooltje een netwerk opgericht.
Carma@Got
tweakers
Kheb namelijk nog nooit online gespeelt.
[ Voor 47% gewijzigd door Verwijderd op 20-11-2007 14:36 ]
  • not2secure4u
  • Laatst online: 08-10 21:32
Dus dit is gratis dit spel ? Je moet alleen maar de client downloaden als ik het goed op heb ?
NUC I5 256GB SSD
Het spel is automatish geupdate met addon cars en een tooltje om auto toe te voegen alsook een extra launcher waarin je nog wat setting kunt veranderen.
Als je online wil moet je beetje lager scrollen en die instructies volgen.
En helemaal gratis!
  • Crash
  • Laatst online: 21:47
Check je mail zometeen. Dit spel is _geen_ freeware, dus het complete spel aanbieden valt onder het aanbieden van warez...
