ChatZilla connect niet
  • Operations
  • Laatst online: 04-09 22:40
Ik heb ChatZilla geinstalleerd, ik krijg alleen maar connection refused op alle kanalen. Heb via me router poort 6660 tot 6670, en 113 al doorgezet.
De ChatZilla FAQ zegt:
Output
Connection to irc://irc.example.com/ (irc.example.com:6667) refused.
This error means that the server was found, but it did not wish to let you connect. This could be because the wrong port (6667 in this example) was used; verify that the server is not on a different port (especially if you are trying to connect using SSL) and try again. This error could also mean that the server is having a temporary technical problem.
Gaat om kanaal Freenode, kanaal werkt prima want vanaf me werk lukt het prima. Iemand een idee?
PC1: ASUS B850-Plus WiFi -- 9900X incl. X72 -- 64GB DDR5-6000Mhz -- Kingston Fury Renegade G5 2TB -- DELL 4025QW | Servers: 2x DELL R730 -- E5-2660 v4 -- 256GB -- Synology DS3617xs: 4x1,92TB SSD RAID F1 -- 6x8TB WD Purple RAID5
