[2003] MSMQ licentie vraag
  • 173 views sinds 30-01-2008
  • kwiebus
  • Laatst online: 22:45
Zijn voor het gebruik van MSMQ op een Windows 2003 Server met Windows XP clients bepaalde CALs nodig?
Het gaat hierbij om Window XP clients die niet in een domain hangen en naar een private queue op de 2003 server moeten schrijven, dus MSMQ wordt zonder AD integration gebruikt.
Onderstaande heb ik kunnen vinden maar ik kan er niet echt wijs uit worden:
Uit de MSMQ FAQ van MSMQ overview van Microsoft:
Q. How is MSMQ licensed and priced?
A. Because Message Queuing is a component of Windows, its use is covered by the Windows license. If you have a valid license to use Windows, then you can use MSMQ. There is no additional fee, above the cost of Windows itself, to use MSMQ.
Uit de MSMQ FAQ van MSMQ Technology Center van microsoft:
5.8 How does Message Queuing manage licensing? Does it consume Client Access Licenses (CALs) from the File and Print subsystem?
Message Queuing manages its own CALs. It does not use CALs of other subsystems.
Uit Microsoft Technet licensing considerations:
Licensing considerations
Message Queuing counts Windows Server 2003 family client access licenses (CALs). If no CALs are available, Message Queuing applications can fail to send messages and to open all queues. Message Queuing enforces the following rules for counting CALs:
• An independent client running on Windows XP Professional can have no more than 10 concurrent Message Queuing sessions and remote-read sessions with other independent clients running on Windows XP Professional.
• A dependent client does not count CALs, but its supporting server counts any sessions or queues opened on behalf of the dependent client. All Message Queuing sessions, remote-read sessions, and queues opened by dependent clients are counted. The number of dependent clients that can be supported is limited by the number of server CALs on the server.
• All sessions used by a Message Queuing computer are counted only once.
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Je moet net als bij elke andere service gewoon CAL's hebben: afhankelijk van je keuze voor device of user cal's zal je voor elke authenticerende user danwel machine die gebruikt wordt een CAL moeten hebben :)
Mijn spoorwegfotografie
  • kwiebus
Is er in de situatie zoals ik deze beschrijf dan sprake van authenticatie van een user danwel machine en zo ja hoe werkt dit dan?
Zoals ik het begrijp gebruikt MSMQ een eigen type CALs aangezien MSMQ geen gebruik maakt van CALs van andere subsystemen. Aan wat voor bedrag per CAL zou ik dan moeten denken als ik alleen dergelijke MSMQ CALs wil aanschaffen?
  • alt-92
alt-92
ye olde farte
kwiebus schreef op maandag 12 november 2007 @ 13:14:
Hoe maak je anders connectie met de server?
Daar zul je toch credentials voor moeten gebruiken.
  • kwiebus
alt-92 schreef op maandag 12 november 2007 @ 13:16:
Zou ik, als er authenticatie plaats vindt dit niet terug moeten zien op de server in de event viewer bij security? Waar kan ik die authenticatie informatie dan wel vinden?
  • kwiebus
Heeft verder niemand hier iets aan toe te voegen?
