[WSUS 3.0] Errors over database deadlocks en services*
  • 427 views sinds 30-01-2008
  • Turdie
  • Laatst online: 20-04 14:54
Hallo
Ik heb op een Windows 2003 Server WSUS 3.0 draaien. Ik krijg daar steeds
onderstaande errors. Heb ook dit kb-artikel al gevolgt tijdens het proberen op te lossen van de error maar ze verdwijnen maar niet.
Weet iemand hoe ik dit kan oplossen?Ook heb ik deze website heb ik doorgenomen, maar daar wordt ik niet veel wijzer van.
Ook heb ik de Softwaredistribution log doorgenomen. En daar vind ik dit:
2007-07-25 14:02:17.596 UTC Error w3wp.1 HistoryEventProcessor.ProcessEvents Error occurred while processing events in database. Exception: System.Data.SqlClient.SqlException: Transaction (Process ID 58) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
at Microsoft.UpdateServices.DatabaseAccess.DBConnection.DrainObsoleteConnections(SqlException e)
at Microsoft.UpdateServices.DatabaseAccess.DBConnection.ExecuteCommandNoResult()
at Microsoft.UpdateServices.Internal.ReportingDatabaseAccess.PostProcessActivityEvents(Int32& numEventsProcessed, Boolean& wasTableFull)
at Microsoft.UpdateServices.Internal.Reporting.HistoryEventProcessor.ProcessEvents(Object state)
at System.Threading._TimerCallback.TimerCallback_Context(Object state)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading._TimerCallback.PerformTimerCallback(Object state)
Event Type: Error
Event Source: Windows Server Update Services
Event Category: Web Services
Event ID: 12032
Date: 7-11-2007
Time: 17:46:33
User: N/A
Computer: ****
Description:
The Server Synchronization Web Service is not working.
Event Type: Error
Event ID: 12042
Date: 7-11-2007
Time: 17:46:33
User: N/A
Computer: ****
Description:
The SimpleAuth Web Service is not working.
Event Type: Error
Event ID: 12012
Date: 8-11-2007
Time: 19:05:56
User: N/A
Computer: ****
Description:
The API Remoting Web Service is not working.
[ Voor 53% gewijzigd door Turdie op 08-11-2007 19:34 ]
  • elevator
elevator
Officieel moto fan :)
Heb je eigenlijk ooit een werkende WSUS installatie op deze machine gehad? Mijn eerste ingeving zou namelijk zijn dat als je dat niet hebt, dat je gewoon even de database weggooit en overnieuw begint want het lijkt er op dat er daar iets niet helemaal lekker mee werkt :)
  • Turdie
elevator schreef op vrijdag 09 november 2007 @ 10:38:
Hij heeft ongeveer twee maanden goed gewerkt en het is geen upgrade geweest een verse nieuwe installatie. Hoe moet ik die database weggooien?
[ Voor 3% gewijzigd door Turdie op 09-11-2007 12:30 ]
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Wat is er in de tussentijd allemaal gewijzigd in IIS?
Mijn spoorwegfotografie
  • Turdie
sanfranjake schreef op vrijdag 09 november 2007 @ 22:08:
Ik heb in de tussentijd,toch maar heb op jouw advies WSUS 3.0 opnieuw geinstalleerd.Ik zie nu in iedergeval de error niet meer in event-logs. Had wel een paar security patches geinstalleerd,maar dat lijkt me toch geen invloed te hebben?
[ Voor 7% gewijzigd door Turdie op 10-11-2007 18:31 ]
