Cisco 1811 Router (NAT) probleem
  • 662 views sinds 30-01-2008
  • Ducktape
  • Laatst online: 15-07 00:50
Ik ben bezig om een router te plaatsen tussen mijn UPC internet verbinding (modem in bridge) en een LAN.
Alleen lukt het me niet om de Cisco 1811 router te configureren.
DHCP op WAN werkt (kan ook pingen).
DHCP op LAN werkt
Routeren tussen WAN en LAN met NAT wil niet echt werken.
Mijn huidige config:
Current configuration : 1873 bytes
! Last configuration change at 14:03:46 Berlin Thu Nov 8 2007 by administrator
! NVRAM config last updated at 14:04:02 Berlin Thu Nov 8 2007 by administrator
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname cisco1811
boot-start-marker
boot-end-marker
no logging buffered
enable secret x
enable password x
no aaa new-model
resource policy
clock timezone Berlin 1
clock summer-time Berlin date Mar 30 2003 2:00 Oct 26 2003 3:00
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1
ip dhcp pool LAN
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 212.142.28.66
   lease 5
interface FastEthernet0
 description WAN
 mac-address x.x.x
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 no ip route-cache
 duplex auto
 speed auto
interface FastEthernet1
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface FastEthernet2
 description LAN
interface FastEthernet3
 shutdown
interface FastEthernet4
 shutdown
interface FastEthernet5
 shutdown
interface FastEthernet6
 shutdown
interface FastEthernet7
 shutdown
interface FastEthernet8
 shutdown
interface FastEthernet9
 shutdown
interface Vlan1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface Async1
 no ip address
 encapsulation slip
 no ip route-cache
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
control-plane
line con 0
line 1
line aux 0
line vty 0 4
 password bla
 login
webvpn context Default_context
 ssl authenticate verify all
 no inservice
end
Iemand een idee waar ik de mist in ga? (Behalve op het feit dat ik nog geen CCNA / P ofzo heb...)
Wel handig:
Fast Ethernet LANs
SWITCH and FE9-FE6 (top), FE x and FE5-FE2 (bottom)
Fast Ethernet WANs
FE0-FE1
  • Bart
  • Laatst online: 08:39
Je mist access-list 1 die je in de NAT Overload regel definieert:
access-list 1 permit 192.168.0.0 0.0.0.255
I'm not deaf, I'm just ignoring you.
  • Ducktape
mm ja klopt. maar het werkt nog steeds niet...
ip http server
  • ChaserBoZ_
  • Laatst online: 09-10 14:11
en dan 'any' erachter ?
edit; ik maak 'm meestal zo;
access-list 101 remark NAT
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
[ Voor 45% gewijzigd door ChaserBoZ_ op 08-11-2007 23:02 ]
'Maar het heeft altijd zo gewerkt . . . . . . '
  • Ducktape
werkt niet, die any pakt ie niet achter die regel. dit wel:
access-list 1 permit any
nu heb ik dit, maar nog steeds geen internet:
access-list 1 remark NAT
hehe remark is natuurlijk alleen commentaar :+ ik snel overtypen....
[ Voor 34% gewijzigd door Ducktape op 08-11-2007 23:34 ]
Euh.. er staat 'no ip routing' in je config. Lijkt me dat je dat wel nodig hebt. :)
  • ChaserBoZ_
Ducktape schreef op donderdag 08 november 2007 @ 23:28:
Voor een router met 1 access-list is een remark niet zo handig, heb je er echter een stuk of 20, dan is het wel wenselijk ;)
Verwijderd schreef op vrijdag 09 november 2007 @ 20:42:
Dat zou weleens kunnen helpen ja :)
  • Ducktape
O+ als je een meisje was...
Het werkt. Super bedankt. (nu lekker verder pielen met de config mogelijkheden).
BTW wel een lekker regeltje om overheen te lezen.
[ Voor 7% gewijzigd door Ducktape op 09-11-2007 22:16 ]
