webcam HP dv9381ea
  • 122 views sinds 30-01-2008
  • irundaia
  • Laatst online: 05-05-2022
ik heb een HP Pavilion dv9381ea laptop met een ingebouwde webcam.
Ik probeerde zo net een filmpje te maken met quickplay wat prima ging.
Ik kan het filmpje ook met quickplay weer afspelen maar als ik het probeer met windows media player of iets dergelijks werkt het niet. Dan krijg ik de volgende foutmelding:
Windows Media Player Error Message Help
You've encountered error message C00D11B1 while using Windows Media Player. The following information might help you troubleshoot the issue.
Cannot play the file
Windows Media Player cannot play the file. You might encounter this error message for one of the following reasons:
Your sound device, such as a sound card or sound controller, requires an updated driver. To determine if an updated driver is available, see Windows Update at the Microsoft Web site, or see the sound device manufacturer's Web site.
Your sound device is not functioning properly. Try using Device Manager to check the status of your sound device.
To check the status of your sound device
1.
Do one of the following:
o
If you are running Windows XP, click Start, right-click My Computer, and then click Manage.
o
If you are running Windows Vista, click Start, right-click Computer, and then click Manage.
2.
In the pane on the left, click Device Manager.
3.
In the pane on the right, expand Sound, video and game controllers, and then look for the name of your sound device.
4.
o
If your sound device is listed but the icon includes a red "X," the device has been disabled. To enable the device, right-click the icon, and then click Enable.
o
If your sound device is not listed, in the pane on the right, expand Other devices. If Multimedia Audio Controller appears in the list, right-click the icon, and then click Update Driver or Update Driver Software. Follow the on-screen instructions to find and install the driver software.
If you are not able to find and install the correct driver software, see your computer manufacturer's or sound device manufacturer's Web site for further assistance.
You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again. For details, see your computer manufacturer's or sound device manufacturer's Web site.
You are trying to play a file on the Internet and the server might be temporarily unavailable or there might be a network issue. Try again later.
You are trying to play an MP3 file that contains compressed ID3 headers. The ID3 header is a portion of the file that stores the song's album information (for example, the song name, artist name, album name, and genre). This information is sometimes called a "tag."
To fix the problem, make a copy of the file and then use a non-Microsoft ID3 tag editing program to remove or reset the file's ID3 headers. After you remove the ID3 headers, Windows Media Player should be able to play the MP3 file.
Attempting to remove ID3 headers might damage the file and make it unplayable. Therefore, always make a copy of the file before you edit it.
If this solution does not resolve the problem, the file might be corrupted.
aangezien ik elke update gedraait heb en zeker weet dat ik mijn drivers geinstalleerd heb ga ik er vanuit dat de file corrupt is..
kan ik dit op een of andere manier voorkomen??
mvg Han
