[XP/vista] reboot naar XP start niet door, koude start wel*
  • DMP.cc
  • Laatst online: 03-10 17:26
DMP.cc
They call me DM
Ik heb op een computer waarop Vista al geinstalleerd staat, een Dual boot XP geinstalleerd.
Dit heb ik gedaan volgens deze methode:
Below is the way I installed XP on my computer, after Vista was already installed... creating a dual boot.
First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive.
Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit.
Next, insert your Windows XP CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP.
Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating system files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive.
Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component.
Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to.
And now you should be able to dual boot between Vista and a previous OS.
Alleen hiervan werkt iets niet helemaal lekker:
Als ik de computer opnieuw opstart naar XP komt ie niet verder dan de bootmanager. waar dan het XP logotje zou moeten komen met de bewegende groene blokjes, blijft het scherm zwart en is er na een paar seconden geen schijf activiteit meer.
Als ik dan de uitknop indruk gaat de PC ook direct uit, als ik dan weer opstart en in de bootloader weer XP selecteer gaat alles perfect, en start de computer XP direct op.
Ik heb dit probleem niet met vista.
Weet iemand hiervoor een oplossing?
Alvast bedankt! _/-\o_
  • alt-92
alt-92
ye olde farte
Volgens mij is iedereen de laatste tijd een beetje inspiratieloos als het om titels aankomt...
"probleem" is zo ongeveer het minst concrete onderdeel wat je kan gebruiken daarin.
Bij deze neem ik dan maar de vrijheid om er wat anders van te maken, neem nog even een kijkje in de Windows Clients - Policy:
Probeer in ieder geval een duidelijke topictitel te verzinnen, zoals een beknopte omschrijving van je vraag of je probleem.
Anyways: je kan als je XP eenmaal loopt ook een extra entry aanmaken in de boot.ini met de /bootlog switch, misschien dat je dan nog iets nuttigs kan ontdekken.
