[XP] Geen toegang tot stations
  • lazbahadir
  • Laatst online: 05-07-2023
Als ik in mijn C, F of G station wil krijg ik steeds dit scherm dus kom ik hem niet binnen..
Afbeeldingslocatie: http://img89.imageshack.us/img89/6809/naamlooscc8.jpg
Heb de virusscanner (McAfee) laten draaien hij heeft wel een virus gevonden en verwijderd maar ik heb nog steeds hetzelfde probleem..
  • BtM909
BtM909
Watch out Guys...
Kan je ook een printscreen maken van je rechtermuisknop op een schijf?
  • Tags NL
  • Registratie: December 1999
  • Laatst online: 13-09 00:15
Tags NL
Harmful or Harmless?
Lijkt wel alsof er een autorun op je drives zit, had dit op internet gevonden:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del f:\autorun.* /f /s /q /a
del g:\autorun.* /f /s /q /a
c, f, g each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
https://powershellisfun.com
  • Kixtart
Kixtart
Destruction = Improvement
Hierin staan nog wat opties:
[XP] My Computer: drives "openen met..." ?*
  • aramdin
  • Laatst online: 24-07-2024
Wanneer begon dit op te treden & wat het laatste wat je toen veranderd had (voor zover je je nog kan herinneren)?
Een quote uit het topic van Kixtart:
waarschijnlijk stond er een autorun.inf op je partities (kwam ik toevallig ook tegen via google)
mooi dat het probleem iig opgelost is
[ Voor 46% gewijzigd door aramdin op 24-10-2007 14:46 ]
Instagram / YouTube
  • lazbahadir
@BtM909 : Afbeeldingslocatie: http://img401.imageshack.us/img401/9500/naamloosbn4.jpg
@-={Fred_Perry}: Geprobeerd maar helaas..
@Kixtart: Ik heb alles wat daar staat geprobeerd behalve het opnieuw installeren maar het lukt nog steeds niet.
@aramdin: Nadat ik AVG had geinstalleerd begon dit ineens op te treden. Volgens mij nadat ik met AVG een stuk of 10 virussen had verwijderd (weet ik niet zeker).
  • lazbahadir
Ach ik ga mijn pc maar opnieuw installeren.. Weet ik tenminste zeker dat hij schoon is..
  • Hotdog
  • Laatst online: 26-12-2024
wat als je opstart in veilige modus?
(tijdens startup de f8 induwen)
  • BtM909
BtM909
Watch out Guys...
Werkt Verkennen wel?
[ Voor 3% gewijzigd door BtM909 op 25-10-2007 17:20 ]
